Question about GE Washing Machines
GE Washer WSKS3040EWW top load won't spin
I can hear a click click once the washing machine drains the water out but the washer won’t spin. It beeps and the code dr appears on the pad.
I opened the black plastic plug at the back bottom of the machine called the coin catcher. I put my finger in but I don’t feel anything. I tried again but the machine still won’t spin.
Do I need to do something else to the coin catcher?
jsrock516
  • 5911 Answers
SOURCE: washer will not drain, seems to be plugged
Try using a wet/dry shop vac and see if you can pull water through the drain hose in the back. If you can, duct tape the vacuum nozzle to the drain hose to make a good seal. With the vacuum on, watch the drain hose under the tub. If it collapses, you have a clog somewhere. It may be easier to remove the hoses from the pump, first to see if there is anything stuck in the impeller. It doesn't take much to restrict water flow. If you need to remove the hose from the bottom of the tub, try to get as much water out using the method I mentioned. It may be slow, but as long as it can pull water, try to drain. This will save you from a big mess later. If there is a clog in the hose, all that water will gush out with the hose disconnected. You may want to have a few towels handy. Now...in some models there is a plastic ball valve in the drain hose connected under the tub. This needs to stay there, but may also be jammed with crud. Sand and dirt is notorious for clogging at this point in the drain system. This hose should come off with a simple clamp tightened with a screw. If you go through all the effort and find the lines clear, you may have a failed drain pump.
Posted on Aug 10, 2007
Jimster
  • 240 Answers
SOURCE: Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Posted on Sep 09, 2007
JULIANFIX
  • 975 Answers
SOURCE: GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Posted on Apr 16, 2008
  • 71 Answers
SOURCE: Washer will not spin
My mum had this problem. I think it had something to do with the barrel coming loose.. - get a plummer ;)
Posted on Sep 29, 2008
localwonder
  • 6784 Answers
SOURCE: I have Frigidaire Affinity washer that beeps and blinks "dr"
Hi. the "dr" represents a faulty door mechanism. you will need to replace this device asap.
Click here to purchase your new door mech.
Posted on May 24, 2009
My GE washer #WDSR2080DEWW washer won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | GE WDSR2080D Top Load Washer
Ge washer won't let water spin out
heatman101
Aug 11, 2011 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
GE Washer will wash but won't drain?
heatman101
Jul 24, 2011 | GE Washing Machines
My Kenmore washer 20432990 will fill and agitate but won't drain or spin. When I push down on the lid switch I hear nothing but when I let it go I hear a faint click.
heatman101
Jun 15, 2011 | Kenmore Washing Machines
My ge front end loader washer won`t spin water or pump water out
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 29, 2011 | GE WSXH208A Front Load Washer
My ge wbvh6240fgg front load washer will not spin or pump the water out. I have pulled the plug and waited a minute then pluged it in again. No success. It goes into pause. I can hear a quied moterized...
heatman101
Sep 07, 2010 | GE Energy Star WCVH6260F Front Load Washer
Hi. my ge wjse3110a won.t spin unless is start spinning it first by hand
The motor is going bad...
heatman101
Sep 07, 2010 | GE WJSE3110A Top Load Washer
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Washer filles with water can hear timmer then drains never spins
you have transmission problems. When your washer is empty and off you should be able to turnthe agitator by hand if you can't then the transmission is bad.
Apr 03, 2009 | GE WDSR2080D Top Load Washer
Washing Machines Logo
44 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
