My lg direct drive is taking longer to wash than the displayed time
  • 1,543 Answers
The displayed time is only an estimate. Load size, load type, water fill rate, and pump out issues all effect the actual time.
Posted on Oct 15, 2008
Error le on lg direct drive washer what can be done without a repairman
often that is a hall sensor-motor speed/position sensor. common issue. easy replacement. part under $20. check out youtube or repairclinic.com or appliancepartspros.com for how to video. part readily available at above sites or on eBay. just plug in your model number and the parts list will come up. takes about 30 mins tops
Oct 22, 2016 | LG Washing Machines
My lg direct drive front loading washing machine display ooanel and lights does not common but the sound is present
You need to remove top and check for 12v and 5v,( put multimeter leads on wires one at a time) going into display panel from main board. If you see 12v and 5v than display board is very bad.If no voltage at all then main b. is bad or the noise filter fuse is bad.
Apr 10, 2014 | LG Washing Machines
LG Inverter Direct Drive 7.5kg Front loader WD12020D
purchase a couple of washing machine cleaners from a local supermarket or homeware store. there will be on the console two buttons with a * next to them, turn the machine on and press both these buttons. the machine will display "tcl" normally, insert 1 cleaner into the drawer where detergent goes and press start. run a couple of times to make sure it has all flushed through
Apr 10, 2014 | Washing Machines
Lg Washing Machine Manualmy washing machines just started coming up with 1E in the display part what does that mean.. i have a lg direct drive 7.5 kg front loader, WD12020D
there is a problem in water inlet valve.....first turn off the water tap.then remove water inlet hose from washer end.after that see the inside of the valve.there is a small water filter in the valve.....take it out it using plier ...then clean it wel....now replace it correctly....now your problem will ok
Jun 02, 2013 | LG Washing Machines
LG inverter Direct Drive 7kg WD11020D - what is "ue"?
UE is the error the washer will display if it detects an unbalanced load. If your LG washer was a model that contained the Ball sensor, it could be a bad part.
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=800
Mar 06, 2011 | LG Washing Machines
My LG1285 FHD washing machine will not complete final spin
Are you using the correct amount of the correct soap?
These machines struggle with soap overdose.
My notes:
You MUST use "HE" (High Efficiency-Low Suds) type detergent--but to use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Washload
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
This reduces/prevents:
1) Musty Odor
2) "LE" Error/Interrupted Cycle
3) L-O-N-G Cycle Times (longer than time displayed)
4) Insufficient Cleaning Results
5) Small Water Leaks from the air vent behind the washer or at the
front door gasket
6) Damaged Hall Effect Sensor (on 2007 or older LG washers)
7) Reduced Spin Speeds (laundry not spin-dried effectively)
Most consumers were doing what is *normally* the right thing to do, which is to follow directions on the detergent label. In this rare case--those directions should be entirely disregarded.
Additionally--in many LG washers--the liquid dispenser cup (blue cup) has a "MAX" line on the white siphon cap.
This was a very big *faux pas* on LGs part--this "MAX" line has NOTHING to do with measuring detergent and should never be used as a guide for determining correct detergent amount.
The "MAX" line indicates how much liquid must be in the blue dispenser cup before it DISPENSES from the bottom of the cup.
This is a very,very frustrating mistake that gives owners much grief.
After three months of incorrect type of detergent or incorrect amount of the correct detergent used--musty odor begins to occur.
After more than two years--a significant amount of soap scum/curd has accumulated in the washer. Odor-causing bacteria flourishes on this build-up.
It is imperative to remove this slimy residue. Tide sells a product called "TIDE WASHING MACHINE CLEANER" which is very effective.
Once a tub has become heavily contaminated--normal methods of performing a TUB CLEAN cycle won't "cut it".
Add the entire packet of "TIDE WASHING MACHINE CLEANER" directly into the tub (no laundry) and close the door.
Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent useage.
After this--use the correct amount of "HE" detergent & perform a "TUB CLEAN" cycle every (4) months using the *tub clean* option on the control panel.
Most digital-controlled front load washers have a software feature that consumers are unaware of.
If excess suds is detected by the MAIN BOARD (which monitors motor electrical load during rinse & final spin) the "suds kill mode" will be enabled.
This causes the washer DISPLAY CLOCK to stall.
The washer makes an attempt to reduce/remove suds--usually a futile attempt--and ends the cycle much longer than was originally shown on the DISPLAY.
Jun 30, 2010 | LG Washing Machines
The cycles take longer than the timer says. The display may say 26 minutes but the actual time is more like 35 minutes
I am having the same problem . Please if you get a answer please forward to me .. Thanks
hlittle3@yahoo.com
May 05, 2010 | LG WM2016C
Washing Machines Logo
Top Washing Machines Experts
