Question about Canon imageRUNNER 1630 Copier
How to get in service mode on Canon ImageRunner 1630
I have a Canon ImageRunner 1630 displaying error code e000. How do I get into service mode? How do I reset?
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
there is a problem with the fuser, if you reset it most likely it will melt the rollers in the machine.
check the lamp (burn out), and thermofuse. replace
Posted on Oct 16, 2008
Canon copier error code E000 and i can't clear it
The errors E000 to E004 refer to a fuser problem. There may be a problem or it may just be a random error which can be reset in the service mode.
I am terribly sorry but as i am Canon engineer i am forbidden to tell you how to activate the service mode. I am sure you can find it somewhere on the net.
Good luck.
Jul 23, 2011 | Canon imageRUNNER 2000 Copier
I have imagerunner 1630 has code e000 how can i fix it
If the machine detects an error in the fixing assembly, the DC controller PCB operates
as follows:
[1] It causes the FSRDRV* signal to go '1' to cut power to the fixing heater.
[2] It causes the RLYDRV signal to go '0' to turn off RL1, and indicates 'E000' through
'E004' on the LCD in the control panel.
When 'E000' through 'E004' is indicated, the NVRAM on the DC controller
PCB remembers an error in the fixing assembly even when the
power switch is turned off and then on. After turning on the power, be
sure to execute the following in service mode to remove the error information:
Jul 06, 2011 | Canon imageRUNNER 1630 Copier
System error E000
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Mar 24, 2010 | Canon imageRUNNER 2010F Copier
My canon printer is showing system error E000
What they are talking about is to reset the printer. You should be able to do that by pressing the #7 and then the printer reset button.
Jan 14, 2009 | Canon imageRUNNER 1310 Printer
Canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
Getting a eooo mesage
E000 error is due power surge or electrical fault within the copier. you can clear the error in service mode.
Sep 30, 2008 | Canon imageRUNNER 1630 Copier
Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
May 17, 2008 | Canon imageRUNNER 1600 Laser Printer
e000 is fuser temperature too low could be disconnected or the over heat senser has to be replaced and this code must be reset in service mode to allow copier to function.
May 12, 2008 | Canon imageRUNNER 1630 Copier
Canon imageRUNNER 1630 Copier Logo
929 people viewed this question
old marine
old marine
