Question about Canon imageRUNNER 105 Copier
Canon IR105 and IR8500 Load paper Problem, Tray Suspend Problem, Paper Pickup and Jam Problem
We are using a number of Canon IR105 and Canon IR8500 machines and face the following teething trobles :
1. We regulalry face problems related to trays not being able to sense paper available ie in each of the machines only one or two trays out of the four present trays will be sensing the availability of paper. In "Paper Select" option where we select the tray from which the paper is to be picked up then for the selected tray the "Done" button remains greyed out ie cannot be selected even if the tray has been loaded with paper.
2. Often we get message "Tray Suspend" also for which we do not know what to do. The concerned Tray is highlighted with a red icon and the message displayed is "Suspend" and the machine stops. In these cases we open the tray, remove 1-2 pages and the machine starts to work. But in many a times this problem gets repeated so often that no effective prits can be taken form the machine.
3. Another very frequent problem is related to paper pickup where the paper does get picked up but the paper jams at the location above Transfer / Separation assembly ( Transfer Corona Assembly in regular parlance) where the registration rod is there (the registraion rod has the registration clutches at both the ends.)
4. Please also throw some light on the paper sensors / tray sensors available in these machines and their connections also to help solve this problem. Pl. alo provide some link to relevant pdfs, URLs on Internet where we can gain more information on these machines. We do have service manuals for these but do not have any document which explains the functions of the componenets and sensors in these machines.
5. What is the correct height and tension of the corona wires in Transfer/ Separation Corona Assembly and Primary Corona Assembly.
6. Sparking is observed in Transfer Corona Asembly and Primary Corona assembly and this has resulted into pit marks on several drums in our machines. Please advise us on how to prevent sparks at these places.
7. What are the functions of Pre Transfer Corona Assembly . We have been operating these machines without this corona. Does this affect the performance of these machines in any way? If we use the Pre Transfer Corona Assembly we get E065 error too often and hence we are running these machines without the Pre Transfer Corona Assembly.
8. Many a times the image on the paper is skewed / tilted by an angle. This error comes and after some time and a few hundered printout goes off. The position of tilt varies with the prints taken out. As the paper cannot be tilted in the paper path (as far as we can understand these machines) we are surprised to see a tilted image on the prints taken.
Please help usin this regard. We have tried to contact several Canon Engineers but to no avail.
Thanks and regards
Rohit
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
WOW !!!! that is a list, but I will try to shed some light.
1-are the trays not being sensed in the paperdeck (optional paper tray capacity)
and the ones that work in the copier?/ a) the bord may be bad b) the connector may not have good contact
2-tray suspend
3-registration jam, a) the registration assembly is probably shorting out b) notenough sep causing the paper to rise up on the drum and then jam,
4-the paper sensor in the trays are in the pick up assembly tires, the ones that come down topick up the paper, there is a sensor that is loose but when it hits paper goes up, when no paper the metal plate goes up but has a hole for the sensor to fall trough and does not go up, giving paper empty.
5-I do not have any info on the specs for the corona wires, this is in the service manual
6-Sparking in the coronas is bad and can result in paper jams and holes in the drum, sometimes putting whiteout on the very ends of the coronas help, but it's better to replace, you can get the end blocks seperate.
7-Pre-corona assy' is to charge up the drum for fater copies, some techs do take them out, if all the wires are arcing then it may be your HVT (high voltage transformer) for the coronas going bad.
8-image is skewed only when using ADF if you put it on the glass it should be fine, the problem is the glass is too dry, try spraying some WD40 on the glass and wiping it off, leaving no residue just a slick smooth surface. the paper turns due to the dryness when fed on the glass.
9- Yes you are right there is no room for the paper to skew it would tear or get jammed if it did
hope I was of some help
Posted on Oct 15, 2008
Out of paper problem on cannon
Posted on Nov 02, 2008
HP P3015N tray two paper pickup issue
Issue is worn out feed rollers. There are three. One in the tray itself and two after you remove the tray. Look up into the printer from where you removed the tray and replace those two rollers
Jan 09, 2013 | HP LaserJet Enterprise P3015d BW laser...
Canon ir3300 showing paper jam in 2nd tray but thre is no paper jam in it
i m using canon ir3300 , showing paper jam at left side , but i checked there is no any paper, although there is showing jam. what to do.
Jul 17, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
CANNON IR2016R WHEN I START AFTER INITIALIZING IT
7.2 Detecting Jams 7.2.1 Delay Jams 7.2.1.1 Delay Jam in Pickup Assembly 0010-4883 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Delay Jam in Pickup Assembly The registration sensor cannot detect the leading edge of paper within the jam detection time interval after paper pickup started. T-7-2 7.2.1.2 Delay Jam in Delivery Assembly (Paper Leading Edge Jam at First Delivery Sensor/Wound Paper Jam at Fixing Assembly) 0011-0712 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Leading Edge Jam at First Delivery Sensor The first delivery sensor cannot detect presence of paper within the prescribed time after the registration clutch has been turned on. T-7-3 Wound Paper Jam at Fuser The first delivery sensor has detected absence of paper within the prescribed time after it detected presence of paper (within the prescribed time after the registration clutch had been turned on). T-7-4 7.2.2 Stationary Jams 7.2.2.1 Stationary Jam in Pickup Assembly 0010-4884 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Stationary Jam in Pickup Assembly The registration sensor does not detect absence of paper within the prescribed time before the next leading edge of fed paper reaches the registration sensor. T-7-5 7.2.2.2 Stationary Jam in Delivery Assembly (Paper Trailing Edge Stationary Jam at First Delivery Sensor/Stationary Jam at First Delivery Sensor) 0011-0733 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Trailing Edge Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after the registration sensor has been turned off. T-7-6 Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after it has detected the leading edge of paper. T-7-7 7.2.3 Other Jams 7.2.3.1 Door Open Jam 0010-4886 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Door Open Jam The door is opened when paper to be printed is in the paper feed path. 7.3 Cassette Pick-Up Unit 7.3.1 Overview 0010-4887 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i The paper picked up from the cassette is fed to the registration roller using the vertical path roller driven by the main motor (M204). The registration roller is not rotating when paper reaches there, so an arch is formed at the leading of the paper to prevent skewing. The DC controller PCB turns on the registration clutch (CL203) at the prescribed timing to transfer the main motor rotation to the registration roller, thus feeding the paper to the delivery tray through the transfer, sepa- Sensor/Solenoid Registration sensor (SR209) Pickup solenoid (SL202) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203
Jan 04, 2010 | Canon iR 2016i Black and White Copier
NP6050 false paper jam at doc feeder
When you put documents in the feeder and you push start do you see 2 black arms swing out to count the number of orignals? If yes, dose the doc tray begin to go down and then jams? If yes, you can try something.... OK, turn the copier off and move the 2 paper guides of the doc tray toward the middle. You need a #2 philip's head screw driver. Remove the 2 silver screws that will be sunk in a bit on the top of the doc tray. Once you remove the screws, remove the top part of the doc tray and you will have one connector toward the front. Unplug it and replug it back in and see if that works, if so return the 2 screws and you should be OK.
Dec 12, 2008 | Canon NP 6050 Copier
IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Aug 19, 2008 | IBM Infoprint 1332 Laser Printer
Paper won't load from both cassettes
is the copier seeing the paper in the cassette, if yes then your pick up assy. connectors could be loose or your pick up assy s. are bad. try switching the assy first before replacing also check your connectors
Jun 19, 2008 | Canon CLC 1150 Color Copier
Paper Jam Problem in Canon LBP 2900
I have a same problem .... somebody help us. :(
May 23, 2008 | Canon LASER SHOT LBP-2900 Printer
Paper jam
Sounds like the pickup roller is worn or dirty. Try cleaning the pick up roller for the tray. If this doesn't work the pick up roller will need to be replaced.
Jan 14, 2008 | IBM Infoprint 1412 Laser Printer
Paper tray pickup failure
If it's not working all the time then the lifting mechanism is bad.
if it is and jams then the tire is slipping and causing the jam.
clean tire with alcohol and try is it really smooth or does it feel rough? if smooth then replace
Dec 03, 2007 | Canon CFX-L4000 Plain Paper Laser Fax
Canon imageRUNNER 105 Copier Logo
1,560 people viewed this question
old marine
old marine
