Question about Standard 2020 Shredder
Need wiring schematic
Our shredder fell into the container and the wires came apart from the top and the motor casing. I need to find a schematic for the different color wires and where they connect. Can anyone help me???
Thanks!
How to pack
The top of the unit that contains the motor comes off and after you have emptied the basket you can set the unit into it sideways. If you still have the packing material use it or just put some crumbled newspaper for protection.
This video on YOUTUBE shows a new shredder being unpacked and it will give you a better idea.
Fellowes 20 Paper Shredder Unboxing
Jul 11, 2014 | Royal Office Equipment & Supplies
Need schematic for electrical on am780 emglo
I would suggest contacting Master Tool Repair, great web site to get information on these little machines, I know you can get owner manuals from them that may contain wiring diagrams with them.
Dec 13, 2009 | Dewalt d55151 factory reconditioned emglo...
Need wiring diagram/info for Tech Solutions TS2550 Paper Shredder
Thank you so very much for going into so much detail about my shredder that wouldn't pull paper thru it. You were SO NICE to do all that & I sincerely wish I could send you a picture of the wiring. HOWEVER, I threw it away months ago when I got no answer to my problem. Guess I'm not patient enough :-) I sincerely appreciate your reply and wish that I could help you out. If I still had it, I'd just mail it to you :-)
SWALynn
Jan 03, 2009 | Tech Solution TS-2550 Shredder
Model 12x royal paper shreddewill run in reversre but not forward
move the control button on top of the shredder to the oppoiste direction.
Nov 28, 2008 | Royal CIA 12X Shredder
TS2550 shredder
I have the same shredder with a different problem. Maybe we can help each other.
If you can describe the pieces I can find them inside my unit and tell you where they go.
My problem is that after I opened mine up, I turned it over to shake out shreds of paper. When I did this, the entire works fell out of the case and all of the wires disconnected from the 3-way switch. Can you look in yours and describe how the wires are connected to the 8 contacts on the switch. (a digital photograph would be GREAT!
I hope we can help each other.
wcbyers
Oct 06, 2008 | Tech Solution TS-2550 Shredder
NoviTech Paper Shredder will not feed paper forward.
I had the same problem with my Novitech Model: PS-026/B2 only working in reverse but not forward. So I decided to take it apart and see if I could find any loose wires, broken parts etc. Keep in mind I am not a paper shredder mechanic, but I was able to fix it, at least for the time being, and here is how:
1. Unplug the machine, and I mean it. Make sure you unplug the machine before you start any fixin'. Unplug the machine!
2. I unscrewed the 7 screws located at the bottom of the case
3. I carefully separated the cases and made sure I did not allow any tension on the few wires that span the case halves
4. With the can of electronics duster I use for my computer keyboard, I sprayed all of the electric contacts, making sure I did not spray any of the grease at the gears. I poked the straw in all of the switch housings and the motor.
5. If you feel a little adventurous, you can remove the 6 screws that hold the cover and safety switch in place. At this point pay attention to how the safety switch arm is positioned ( take a picture if you have to) so it will be in the correct position during assembly. Remove the cover and look for anything that could be caught in the shredders. Remove any foreign matter with tweezers or needle nose pliers. Replace the safety switch and cover, make sure the switch arm is in the same position before you took it apart.
6. Put the two case halves together making sure there are no wires pinched inbetween. Put the seven screws back where they belong and tighten snugly ( do not over tighten cause you will break the plastic, guaranteed!)
7. Place the machine on the waste bucket and plug it in. And voila the motor should start buzzing and humming like it was brand new.
Aug 27, 2008 | Fellowes DM15C Shredder
Wiring toggle switch royal 9512x
Did you get wiring diagram for Orca 9512X shereder swithc.
Wiring is as follows.
Looking down on switch from the back with the forward facing the feed. and control on top
Top left has two yellow wires one to bottom right of switch other to control box/board
Top right has orange going into control box/board
middle left has black going to motor
middle right has red going to motor
bottom left has smaller red going to control box/boafd
bottom right has yellow from top left.
Hope this helps. I'm still trying to find a manual for mine.
Jun 10, 2008 | Office Equipment & Supplies
Office max shredder om96431
For me, the problem was the sensor connections. I took the unit apart (7 phillips screws, I'm not sure why I didn't have to remove the 8th.) Then I took the paper sensor unit off (2 more phillips screws.) Then I removed the little black box that both sensor wires are connected to (1 more phillips screw.) Then I pried that box open with a flat head screwdrive. Some parts fell out. I put it all back together and it worked.
If you don't want to mess with it, just remove the two wires and tie them together. The unit will always be on when turned on to Auto, but that's better than not working.
May 17, 2008 | OfficeMax 0M96431 Shredder
NEED WIRING HELP FOR NIGHT OWL OPTICS
No. Night Owl Optics in El Paso, TX. want send me schematics, parts, etc. Get back to in about a week I might be ability to find hand drawn wiring diagrams. Now I am saying I can look, I am not I do, OK. stewbison
Sep 07, 2006 | Night Owl Optics Discovery NODS3 Monocular
Standard 2020 Shredder Logo
65 people viewed this question
Top Standard Office Equipment & Supplies Experts
Steve P
Steve P
Bill Boyd
Paul Delaney
Paul Delaney
Are you a Standard Office Equipment and Supply Expert? Answer questions, earn points and help others
