Technical Support, Instructions, & Repair Service
Ask our Experts
Ask
Find a Solution
Most Common Problems for:
Bosch Dishwasher repair
By Hart - usenet poster
Our 3 year old Bosch dishwasher has developed the following fault:
At the end of the cycle, the pump will run continually, even with the
door open. Tried a reset, by holding down two of the programme buttons,
and this has no effect, other than the "end" LED lighting up. Pulled
the unit out to have a look at the pipes etc, and this cured the pump
problem, until the end of the next wash cycle, where the problem showed
up again. Is the pump on a "timed" cycle at the end of a wash, or is
there some sort of sensor that tells the controller when the machine is
empty of water?
Cheers
Sponsored Links
I have a similar problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Same Problem
Nov 15, 2007
-   I am having the same problem where is the float located?-   mike9161
Best Solution
posted on May 27, 2006
Very Helpful)
Beresford
Rank: Apprentice
Rating: 0%, 0 votes
there is a float that rises and operates a microswitch, have you found the
cause of the leak ?
Was this helpful?
Yes
No
Solution #2
Helpful)
Cato
Rank: Apprentice
Rating: 0%, 0 votes
Its the anti flood system it will have water in the plastic base, remove it
find the leak and the problem will be cured
Peter
Was this helpful?
Yes
No
Solution #3
Somewhat Helpful)
Grant
Rank: Apprentice
Rating: 0%, 0 votes
Thanks for the replies, pulled the machine out, drained the water, and
bingo! Does anyone know how the anti-flood system works? i.e. how does
the control system detect that there may be a flood problem?
Ta
Popeye
Was this helpful?
Yes
No
Solution #4
posted on Dec 04, 2008
Not Rated)
madferret
Rank: Apprentice
Rating: 0%, 0 votes
I had this problem. Its the anti-flood mechanism
Here's what to do if the water light is flashing:
Drain the machine manually, turn it off at the mains. Put an old towel behind the machine and lift it up at the front until all the old water comes out at the back.
turn machine on and press reset. It should then work.
Was this helpful?
Yes
No
Related Problems
Bosch dishwasher model SMU4052UC/14, Timer clicks and...
My Bosch 2005 Integra dishwasher won't latch. It hits in the...
Our 3 year old Bosch dishwasher has developed the following...
there are no indicator lights on the control panel. There is...
The range hood when turned on, won't **** air and has a loud...
Can you Help with these Kitchen Hood problems?
I have a three speed range hood by...
Solve
I have a three speed range hood by thermador/it uses three seperate windings with a common capacitor... (More)
how to take off fan from motor
Solve
How do I clean the hood? Having...
Solve
How do I clean the hood? Having problem removing grids.
installation instructions
Solve
i have a bosch dishwasher...
Solve
i have a bosch dishwasher SGS69L02GB/17.The door handle is broken,got the spare handle but cannot... (More)
Sponsored Links
Describe your Appliance problem:
Top Kitchen Hood Experts
Rank: Guru Guru
Solutions: 9503
Experience: Do it-your-selfer for a lifetime, 35 years of electrical and mechanical professional exp.
Ask Me
Find more Kitchen Hood Experts
Top Ranges & Oven Repair
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(410) 609-0006
A Leader In Kitchen Equipment Sales,...
Allegro Restaurant Repair
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
