Question about GE Refrigerators
Freezer door has gap on top.How can I adjust - GE Refrigerators
  • 943 Answers
HI thanks for your question if you pull the gasket back you will reveal screws, loosen the screws at the top and the sides. put your foot at the bottom of the freezer door and force the door toward the top. hold there and tighten the screws. this should solve the problem. thanks the appliance doc
Posted on Oct 15, 2008
joboo1
  • 256 Answers
SOURCE: Refrigerator Door not closing properly
Hi, No the door is not adjustable like you might think Since it is smaller than the other door any alignment problem is really visible. First do check the bracket to make sure you didn't lose a screw and that the brackets are solid and don't move. The problem is the level of either the refrigerator or the floor. If you have a 3 ft bubble level put in on the top of the refrigerator along the front, NOT on the door. There are feet on the bottom front corners of the refrigerator, you may have to remove the plastic grill to access them but depending on the model and age of your refrigerator it should be attached with clips. The feet screw in and out but with weight they won't move easily so you may have to jack the front a little, remove some stuff or try a crescent wrench. Once the front is level check the front to back, the refrigerator needs to tilt slightly to the rear so the door when partially open will close by itself. Again you didn't give a model so on some the rear feet are not adjustable and some are. I suspect you may have adjustable and the box is not squared up. If after adjusting the front and the entire refrigerator tilts like an uneven table leg then you have to adjust the feet likewise. Use your level diagonally across the top both directions, it should be exactly the same. If you have non adjustable and they are uneven it is the floor and you have to use shims under the low foot. Good Luck!
Posted on Jan 30, 2009
  • 6 Answers
SOURCE: Bottom freezer door on our LG is out of
The easiest way to fix that is to pull the freezer door all the way out and give it a good little tug, you will see the plastic covers on the side rails there will be a little gap about one inch on each side make sure those gaps are even. Your door should be aligned
Posted on Jul 30, 2009
reddyanantha
  • 205 Answers
SOURCE: freezer and refrigerator doors are mis aligned
can you see the rubber gasket which will be fixed all the four sides of the door,it should be uniform when you close the door.
Posted on Aug 07, 2009
  • 113 Answers
SOURCE: Refridgerator door sags
Its a two person job. One person has to looses up the two hidges holding the door just slightly while the other person holds the door in place. Once in place tighten the screw/bolts for the hidges back up and check. If not aligned, redo it again until it is aligned and seals properly..
Good Luck!
Posted on Sep 15, 2009
SOURCE: Smeg Fab 32 door problem
The Door on my SMEG Retro Fridge keeps opening on its own accord ? There's nothing inside poushing up against it so why does this keep happening ?
Posted on Dec 13, 2009
The 2 doors on my Maytag SXS aren't even in the front when they close. The refig side sticks out. The doors are otherwise level and even in all respects. I adjusted top & bottom hin
Hello Joe;
My name is Peter. I am a retired field service refrigeration technician.
This was your first time setting the gap between the doors. So, I will share with you the various ways to adjust the doors gap.
1.) On the bottom of some doors there are adjustment screws for pitching the door left or right to set the gap. This was a good design idea, but there is not locking nut to hold the setting. Opening and closing the door will remove the setting. So, if you have these adjust screws, we will forget them.
2.) Lets try this: Adjust the front leveling bolts. Loosen the top of the door hinges. If the gap is smaller at the top, lower the leveling bolt up on the left hand side. Turn the bolt counter clockwise to raise. Pound on the doors to free them to adjust. If the gap is smaller on the bottom, on the right jacking screw, raise the jack bolt by turning the jack bolt clockwise. Once again, pound on the door to free for the adjustment. Then tighten to top door hinges.
3.) OK, This did not set the gap. The gap between the door is different depending on the model. Determine the gap which you would like to set. Using something solid like pieces of wood (do not use cardboard it will crush), loosen the top hinges, evenly space the wedges and tape them to the door. Now tighten the top hinges and remove the wedges.
4.) Ok, This did not set the gap. Look on the bottom of the door at the hinge. You have a matching set of grommets. These grommets interlock when the doors close to keep the doors closed. These are high wear components. The doors rest on these components. One grommet set may be more warn than the other affecting the door gap
Dec 04, 2014 | Maytag MSD2542VE Side by Side Refrigerator
Gap in large freezer door seal
if you cant adjust the door, ger some weather striping, some that is some what thin. so it can mold to exsisting area
Aug 04, 2012 | Gladiator Freezerator Top Freezer...
There is gap in the bottom part
a gap in the bottom part of what ? if its the freezer door just adjust the door up if its the two top doors with a gap at the bottom of the two doors adjust and the hinge's and ajust both the same .. mm //
Aug 17, 2010 | Amana AFB2534DE Bottom Freezer French Door...
Our side by side freezer door opens slightly
That is a common occurrance for side by side refrigerators. Closing the fresh food door is like having your car windows closed and closing the door. You can feel the air pressure on your ears. In the refrigerator, the air passes through the duct and into the freezer pushing the door open. The magnet on the door gasket should keep it closed. But it may be the freezer door needs the hinges adjusted to the door seats better when closed. Take the plastic cover off the top hinge and you can loosen the screws (don't take them out) and adjust the door slightly (so it looks even between both doors) and tighten the screws up. The top of the door should be level with the top of the unit, and the gap between the doors even the whole way down.
Jan 03, 2010 | GE Refrigerators
Good Luck!
Sep 15, 2009 | Amana ATB1832AR Top Freezer Refrigerator
I have a kenmore upright freezer model #253.9266411 there is a gap in the upper left side does anyone know how to adjust the door? The seal is fine
I'm assuming you don't want to replace the door seal. Open the freezer door. Stand "inside" the open door and place your foot at the right bottom corner (looking from the inside). Place your hand in the top right corner and pull it very slightly toward you. Do this in small amounts until the gap closes making sure you don't open one at the bottom.
An alternate method is to warm the gapped section of the door seal with a hair dryer to soften the rubber enough to allow the magnet within the rubber to pull the seal gap closed. This has worked for me numerous times by making small adjustments at a time. Good Luck
Sep 02, 2009 | Kenmore Freezers
Top freezer door does not close tight
Sounds like the top hinge is loose. If the hinge has a cover, remove it then hold the door in the correct position and tighen the hinge screws.
Aug 31, 2009 | GE GTS22KBP Top Freezer Refrigerator
Freezer and refrigerator doors are mis aligned after move. gaps where you can see into both compartments. are doors adjustable to fix this problem?
Jul 31, 2009 | Kenmore 64802 Top Freezer Refrigerator
Bottom freezer door moves top to bottom by moving handle in & out
Hi, most models have adjustment screws near the track connected to the door if this is a slide out door. If this is a swing out door, you might be able to twist the door back in shape.
If the gap is only in the corner of the door, try inserting a piece of paper towl rolled/folded up behind the gasket to help stretch it.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 05, 2009 | LG LRBC22544 Stainless Steel Bottom...
Will not seal. new from sears.
The description below is for a gap at the top of the door. Adjust the procedure for gap at bottom by "twisting" the door in the opposite direction.
May 06, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Refrigerators Logo
97 people viewed this question
Top Refrigerators Experts
Gere knutson
KJ4QOB
Da Doc
