Question about GE 16.7 cu. ft. / 473 liter Upright Freezer FUF17DMRWH
Not cold enough
I was away on holiday and my electricity ran out, my dad cleaned it all out but i thinki he has touched the little dial and i'm not sure what number i should have it at, can you help?
  • 943 Answers
HI thanks for your question. start the cooling cycle in the middle so start at 4 or 5 and let fridge cycle, a few times. thanks.
Posted on Oct 15, 2008
Model LFC25776SB/00 one side of freezer not cold enough
There should be a fan inside circulating the air...
Jun 13, 2016 | Freezers
Yesterday, my dad brought me a working GE upright freezer from his house, transport time about 45 minutes. The freezer was working fine before he left his house, he did tip it little bit to load, unload...
You should try to un-plug the freezer and let it stand up-right over night to re-settle the freon back down inside of the compressor.
The compressor should normally get hot if it is doing it's job right, and there is a starter for the compressor motor (usually it looks like a large capacitor) that could have failed, or the defrost timer (if it has one) could be stuck, and you should be able to see the small dial on the defrost timer slowly turning, and if it does not turn, then replace the defrost timer.
Jun 07, 2010 | GE 13.7 cu. ft. General Electric Upright...
We have a 21 cu ft 2009 chest freezer. It is not
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 08, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
Freezer is not cold enough.
Turning it to the right will make it colder. It will only regulate the temp. by few degrees, so if your thinking there will be a big change there won't be.
Jul 31, 2009 | Viking Freezers
Running non stop!
Sadly these old freezers use way too much electricity. You will be better off junking this one and purchasing a good used or brand new one.
Apr 02, 2009 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Freezer runs continually
Hello jyount130960
Welcome
This is a bad thermostat that if not repaired will cause the compressor to burn out prematurely.
You should service it right away!
Thank you,
for using Fix ya.
Please remember to leave a solved rating before you sign out!
Dec 22, 2008 | Freezers
My GE upright freezer does not get cold.
Sounds like the system is low on freon. The other common problem is a dirty condenser. Insure the condenser is clean, if it is. You will need to charge the system with freon. Which only a qualified refrigeration tech should do.
Nov 28, 2008 | GE 13.7 cu. ft. General Electric Upright...
13 months old Kenmore compressor very hot.
lacdoi,
huuum At your service!
You said,
The warranty just ran out, Sears came out told me needs a control board ($210 for just labor to replace) not sure about part price. I though a new freezer is about twice his labor and parts, so I sent him away minus $65.
I did some troubleshooting today, pull the plug for 2 days. Plug it in, temp alarm goes on all the time. Turn alarm off, left the freezer running for 4hrs.
Not cold at all, some cool air. Fan is on, compressor is on (can hear humming noise and is vibrating). Compressor is very hot to the touch, could burn finger.
Should I call Sears again, wonder how much to fix all the problem? Or just give up, look for another brand new one (not Kenmore).
MY ADVICE:
Sounds like a big repair bill and multiple problems
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliance are so much more efficient today that they can save you a lot of money in energy!!!!
Replace it.
You will be fine
Bless You huuum
Please give me the best rating for my fine advice before you sign off.
Thank you
Sep 17, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Freezer and fridge stop working when home temp is cold
ketner1 what you are looking for is an old style freezer. They ran so hot that they didn't care what the temps in the garage was. Here is a suggestion. I am not sure what kind of freezer you have had, but look for one that doesn't have a coil on the back of it. Freezers with the condenser in the cabinet work well at the temps you are looking for, however they don't work well in garages at 90 degrees, then they just transfere the heat to the inside of the freezer. This is the style my parents use and theirs is in a storage shed with no heat.
Feb 02, 2008 | Freezers
Freezer Not Cold Enough/Ice Maker not working
If that doesn't work make sure the fins are clear of dust and debris. Then you try recharging the freon in the unit. The compressor unit might be getting weak. Most of the time with parts and labor it's cheaper to replace the freezer.
Jan 05, 2008 | Freezers
GE 16.7 cu. ft. / 473 liter Upright Freezer FUF17DMRWH Logo
115 people viewed this question
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
