Question about Panasonic KX-T7730 Corded Phone
Seems to be locked into a program - do not have a manual
When handset is lifted line automatically lights up and gives me a line. I used to have to press the line button. I try and get into my extension numbers and can only do this by pressing intercom then the number of the extension. I think that the problem arose when the phones were diverted to another number. Feel that either program or auto dial might have been pressed when diverting. would appreciate if anyone has a spare manual that i could copy or can help me out with this problem
  • 113 Answers
If using the KX-T7730 phone on a Panasonic 308/616/824 system press Program 11 and then AUTO DIAL / STORE . Press Program to exit programming mode.
If this answer was helpfull please vote
Thank you.
Posted on Mar 23, 2010
How to edit speed dial feature KX-DT333
To Program:
Lift handset. Press * 3 0 , then enter the desired 2-digit code (00-09), enter the line access code (generally “9”) followed by the telephone number, then #.
To Use:
Lift handset. Press AUTO DIAL/STORE * plus the 2-digit code (00-09).
To Use System speed Dial:
Lift handset. Press AUTO DIAL/STORE plus 3-digit (000 - 999)
The User Guide can be found at the link below. Hopefully this helps.
http://www.manualslib.com/manual/853264/Panasonic-Kx-Dt333.html
Jul 23, 2016 | Panasonic Lands Phones
I have been trying to change our company greeting on the Panasonic KX-T7731 and can't figure out how. I have searched all the manuals. I also wasnt sure if I need to be on a certain phone/extension to
It's not part if the phone but deoends upon which switch (exchange) you are using and also if your using an external voicemail system or on the KXTES824 if you're using the built-in AA (Automatic Attendant)
Jan 15, 2015 | Panasonic KX-T7730 Corded Phone
Why do I need to push a line to dial out
Since the system can make both intercom calls and external calls it is factory programmed to consider a number dialled to be intercom hence need to pick a line before you can make an external call. However it is also possible to program your phone to automatically access an outside line on lifting your handset in the installation manual
Feb 27, 2014 | Panasonic KX-T7730 Corded Phone
How do you set the phone to automatic pickup a ringing phone line when you lift handset?
If the ringing line is programmed into one of your dss/blf buttons it should answer when you lift the handset. Else, if it is someone else's phone ringing, lift your handset and dial 40. That will only work if allowed in the pbx programming. Hope that helps.
Mar 07, 2013 | Panasonic KX-T7453 Corded Phone
How do i program your 20200-1 hand set telephone. it has 13 number memory. that i wold like to program?
To program one of the three emergency buttons:
1) lift the handset and wait for dialtone
2) press the STORE button
3) dial the phone number
4) press the STORE button
5) press one of the three emergency buttons
6) replace the handset in the cradle
To use; lift handset and press an emergency button, the phone dials the number stored for that button
To program one of the ten memory locations:
5) dial a one digit number(0-9) to store the number in that location
To use: lift the handset, press the MEMORY button, dial the memory location digit(0-9), the phone dials the number stored in that memory location
Here is a link to download the manual.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Feb 11, 2011 | Lands Phones
Programing
Try Googling (comdial)(8124S)(manual) without parens to get instructions.
Sep 30, 2017 | Comdial Impact 8124S Corded Phone
Line programming
That is a feature under system programming for your set. your admin person would need to make that change fir your extension.
Dec 01, 2008 | NorStar Meridian M7310 Phone
HOW TO CHANGE THE AUTO LINE SELECTION WHEN PICKING UP HANDSET
Sounds like you have two seperate line groups programmed in the system, Program 32 " Automatic Preference " controls the lines the phone will automatically be connected to when the telephone handset is taken off hook or the Spkr button is used.
Apr 24, 2008 | Toshiba DKT-2010 Corded Phone
Vodavi Triad 1
You will have to reprogram the "line selection" from a defined line to first line available. This will require reading your instuction booklet, line selction sould be listed in the index. I'm sorry but I don't have the specific programming information you will need to reset the phone. Thank You. Jerry
Feb 08, 2008 | Lands Phones
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
Panasonic KX-T7730 Corded Phone Logo
152 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
