Question about Epson Stylus C46 InkJet Printer
Epson c46 printing
Hi, Basically i have run out of black ink, and have loads of colour, is it possible just to use the colour cartridge without using the black. Many thanks in advance
  • JDTec
    JDTec May 11, 2010
    No, the printer needs boot of the Ink cartridges in to operate.
  • Epson Master
  • 541 Answers
You can if you tell your printer you are only useing back
Posted on Nov 17, 2008
Can i print without using my black ink
Unfortunately, you cannot print without using black ink on Epson, and most other, printers. Some printers allow you to use a combination of the color ink to create a "false black". But, the Epson Stylus C46 cannot do this.
Time to pick up some ink!
Thanks for using FixYa
Jul 13, 2011 | Epson Stylus C46 InkJet Printer
Hi i have a epson stylus sx400 ansd when im trying to print pictures the faces are coming out purple???
It is possible that the colour ink cartridge needs to be replaced. Be sure to use original Epson cartridges as Generic ones give problems.
damnor01
Apr 04, 2011 | Epson Stylus C46 InkJet Printer
Trying to print n a epson printer without black ink carthiage
Unfortunately the Epson stylus needs both ink cartridges to print. I've tried useing an emty cartidge to "fool" the printer,but that won't work. When my Epson was ready for replacement I bought a printer (Lexmark) that prints with one cartridge empty.
Dec 27, 2010 | Epson Stylus C46 InkJet Printer
Printer will not print in black. Colour ink appears to be out. Should this effect it
Yes for sure If your colour ink is down there is the possibility that the print may vary in colour.As the colour ink level decreases you might have got the error to change the ink. Hence it will tend to change the printing commands. To further confirm on this you can disconnect printer, uninstall and reinstall the printer software,then connect the printer for hardware detection and installation. now do a head cleaning maintenance and a test printing. If there is still no change it will be better to replace the colour cartridge after using the menu for ink cartridge changing so as to get the ink indication correct after installation. Hope you try this out. Good day
Aug 13, 2010 | Epson Stylus C46 InkJet Printer
I have no way of changing the ink cartridge in my printer.
Hi, the information you need is here:
http://support.epson-europe.com/onlineguides/en/sc46/index.htm
Just click on the replacing ink cartridges on the left hand side, follow the instructions and pictures there.
Jan 13, 2010 | Epson Stylus C46 InkJet Printer
EPSON C46 problem with color cartridge
The Epson does not like Generic Cartridges. It must be Epson Genunine Cartridges. After going thru alot of ink cartridges, finally I went back to Genuine, and it started printing fine. ! Go Figure. !!!
I have about 2 dozens cartridges. hahaha want them?
Good Luck :0)
Nov 16, 2009 | Epson Stylus C46 InkJet Printer
Epson C46 - is it possible to set the printer so that it combines colours to produce black. My black cartridge just won't print, I've replaced it, cleaned it, power cleaned it. I know that when the black...
Printing black through color mixing is very expensive!
Try this:
Remove the cartridges and print head.
Make a moxture of 15-20% ammonia and warm water solution.
Soak the head for an hour then completely dry it ,especially the electrical contacts.
Run a cleaning cycle and see if your nozzle check pattern improves.
If so run another clean and recheck or soak it again.
Thanks for using FixYa.
Jun 20, 2009 | Epson Stylus C46 InkJet Printer
Bypass using any colour ink with Epson D120 printer? Possible?
Yup that's Epson for you. I had the same. bought the black one but to get it to work you must have ALL the ink cartridges full. no way around it.
Jun 10, 2009 | Epson Stylus DX6050 All-In-One InkJet...
My printer wont print, and i think theres dry ink in the dispenser, but i dont know how to take it out, because the cartridge holder doesnt come out. i have an epson stylus colour 760. btw, i DID change...
Hi
Try running the head cleaning cycles from printer utility. then try reprinting. You can press ink button for 3secs as well to auto clean printhead.
Hope this helps
Nov 29, 2008 | Epson Stylus C46 InkJet Printer
Epson Stylus C46 InkJet Printer Logo
624 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
