Question about Garden
Poulan 2600 chainsaw
Chain tightens up and bogs saw down imediately after starting. New bar and chain. New sprocket and bearing. New oiler last year. I took the bar and chain off and started it. It seems to be getting plenty of oil. The chain doesn't seem to be binding on the sprocket or in the bar.
  • 6 more comments
  • dbkribbs Oct 15, 2008
    no chain brake on this model
  • dbkribbs Oct 16, 2008
    any other ideas
    no, it isn't new. I bought it used. it isn't the wild thing. it is a poulan model 2600 45cc clean burn. The chain oiler works fine but the chain acts as though it get short. I set it so there is about half the thickness of the chain rides in the bar. when I start it it runs around the bar fine. 2 minutes later it is tight. I try loosening the chain and it does exactly the same thing. I just cut a tri axel load of firewood with it and it ran fine. I changed the sprocket and put a new bar and chain on it and now I have this. I have tried 3 different chains and bars. They are all the right part for the saw.
  • dbkribbs Oct 21, 2008
    sprocket is correct. part number matches the one one the parts list. I bought it from a poulan dealer. It looks just like the one I replaced. Saw is for sale as a parts saw. I cant figure it out either.
  • xy2000 Nov 03, 2008
    I have a similar problem. I own a Poulan 18" wild thing. I just put a new chain on it and found that it is tightening and bogging down the engine. In fact I will start cutting and the engine will start to bog down, to the point my chain will stop. So I stop check the chain and it is so tight that I can not move it. My saw has all original parts except a new bar and chain. If I can not fix the problem I will have to purchase another chain saw.
  • Anonymous Mar 18, 2014
    End bearing and chain feed seized.
  • Anonymous Mar 26, 2014
    oil leaking down bye chain sproket on final drive/
  • Anonymous Mar 27, 2014
    seems that maybe the brake lever may have to be reset
  • 24 Answers
Check and make sure you have the correct sprocket.is your chain .325,3/8?sprocket has to match as well as chain and bar
Posted on Oct 20, 2008
    Problem Solver:
  • 6 Answers
Sounds like the chain brake may be causing it.
Posted on Oct 15, 2008
  • Jim Oct 16, 2008
    It must be very old cause all chain saws made in the last several years have a chain brake that prevents injury if the saw "kicks back". Is it the Wild Thing model?
  • Jim Oct 16, 2008
    This is becomming a challenge! Does it bog down without the chain? Measure the bar from the sprocket before and after it bogs down. Has it moved? Maybe the tension adjuster is defective. Maybe it's haunted. Halloween is near.
Tryed to put on a chain cant get it back togather right
Completely loosen the chain tensioner. When looking at the saw from the sprocket side(bar to the right) the chain WILL travel clockwise. Fit the chain on the bar.(ensure that the chain travels in collation with the sprocket at the end of the bar if equipped). When looking at the saw from the sprocket side(bar to the right) the chain WILL travel clockwise. With the chain still in the bar, fit the 5 or so links in the sprocket on the powerhead, engage the bar with the bar nuts, then lastly engage the chain in the tensioner. Place the sprocket cover and nuts. Tighten nuts then loosen about .5 turn. Adjust chain tensioner. Retighten nuts. See that tightening the nuts made your chain tighter, loosen nuts readjust chain, tighten nuts. With gloves on and the chain brake disengaged please ensure the chain travels around the bar. Put on your chaps and start cutting.
Sep 11, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
The automatic chain oiler does not get oil to the chain. Yes, it has chain oil. The black tube to the top chamber at the bar, seems to be plugged and I cant get it off to clean it out. Thanks, Steve
I have never seen an automatic chain oiler that worked. Even new ones don't seem to work. Just pour a little used engine oil on the bar once in awhile like everyone else does.
In theory there is a small piston that rubs on an eccentric at the chain sprocket, and that sucks in oil and pushes it through a hole, into the center groove of the bar.
But if the piston is dry, it won't pump.
If the holes are clogged with sawdust, it won't work.
Here is a video that may help:
http://www.ehow.com/video_4756894_a-chain-saw-bar-oiler.html
Mar 12, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Why would a drive sprocket on a poulan wild thing 18" chainsaw wear completely out in less than 35 hours use?
This will happen if your bearing goes out or if you install a chain that is damaged on your saw. If the chain is in bad shape, it puts extra stress on the sprocket, thus making it wear out quicker. Same goes for your bar. Although noone normally does, it is "best" to replace all 3 items at the same time. Usually, though, if there is no visible damage, it's ok to replace just the worn out piece.
You can find replace bars, chain & sprockets for your saw at partsbuggy.com.
Dec 21, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
When cutting wood saw will not oil chain whats the problem
make sure oiler jet under the chain tightener plate is clean even take bar and chain off and start saw
Dec 12, 2010 | Poulan 18" Wild Thing Chainsaw
Brand new poulan pro 4620avx--bar oil is coming out of oiler but not getting onto chain
Hello. Thin your bar oil just a wee bit with some kerosene. If you have a gallon of bar oil add 1/4 cup of kerosene, stir it up and you will be fine. For starters also, directly apply some bar oil to the chain so that you are always using a well lubed chain. Joe
Oct 03, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain smoking while cutting,hard cutting,and pull string hard to pull new saw.
too much oil in the fuel, or set screws are not mixing air fuel properly. have the set screws looked at, and listen for a bearing to be gone, there are two un related issues here.
Dec 15, 2009 | Poulan Garden
How do you put a chain back onto a chainsaw
on one side of the saw are two nuts and a chain tightener screw. loosen the nuts but don't take them off. turn the tightening screw counter clockwise. the bar should slide backwards. the chain goes over the clutch disk and the tangs go into the bar groove. just keep pressing the tangs into the bar all the way to the tip and around the tip sprocket. now turn the adjustment screw clockwise which will tighten the chain. don't tighten it too much! leave a little "play" - tighten down the nuts. plug in the saw and start it. if the saw has a chain oiler press the oiler a few times. as you use the saw the chain will expand and loosen. loosen the nuts and tighten it again just a little.
Oct 25, 2009 | Electric Garden
Chain oiler does not seem sufficient
The chain oiler injects oil into the rear of the bar where the cover mounts over the sprocket. Take the bar off and clean out the oiler hole. There is usually some buildup of sawdust in the hole. Clean out the grove that the chain guide runs in all the way around the bar. You can see the injector nozzle under where that bar was when you removed it. Sometimes there is an ajusting screw there to increase oil flow.
Sep 12, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan pro series chain saw 20" bearings seizing up on bar
check sprocket isn't worn it may be pulling on chain than over heating bearing. check pitch of chain ,bar , sprocket are the same.
Dec 29, 2008 | Poulan Garden
Garden Logo
579 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
