Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Keypad codes how do I change my code on my keypad
My ditec keypad does not have a square button, it has a 0 - 9 and a #
Posted on Apr 26, 2013
  • 504 Answers
Press and release the square button on the circuit board. You then have 20 seconds to input the new code and press enter.
Hope this helps
Posted on Oct 04, 2010
Changing code on keypad
i have a lift master chamberlin garage door opener and need to change the code on my key pad outside, k\my problem is i have no enter button when i put my new code in on my key pad, does anyone know how to help me change my code on my keypad without the enter button....there is a pound and star button
Jan 04, 2014 | Sears Craftsman LiftMaster Chamberlain...
Hello I have an Access Master Chamberlain garage door opener and i never had to change the garage code. Can u assist me in changing the code?
Well I have to assume you want to change the code for the keypad because that is the only code you can actually change. Locate the smart/learn button on the rear of the motor unit near where all the white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Jun 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
I don't remember how to change the code
If you mean you want to change the code of your keypad do this:
Locate the smart/learn button on the back of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in any 4 digit code and press enter.
Dec 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
I need to change to code for a model 1250lm
If you are trying to change the code for the hand remotes you can't.
If you want to change the code for the wireless keypad do this:
Locate the smart/learn button on the rear of the motor unit. Press and immediately this and then walk over to your keypad and key in any 4 digit code and press enter.
Oct 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do I change my garage code to my chamberlain keypad?
Locate the smart/learn button just to the left of all those white wires. Press and immediately release it and then key into your keypad any 4 digit code you like and press enter.
Jun 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to change keypad code, but lost instruction manual
The key code transmitter for your unit should be 53776 multi key panel:
you must have access to the operator to reset. The programming keys are as noted below:
1. Open the Touch C.ode Transmitter cover to access the keypad.
Decide on a 4-digit code number using numbers from
0 to 9. You can use a number more than once. (For
example, 4, 0, 4, 1).
2o Press the 'SR' code button on the opener panel. The
indicator light atongside the push button will turn ON.
3_ STAND AWAY FROM THE DOOR. Press the selected code
numbers on the keypad and then press the ENTER key.
The indicator light on the opener panel wiil turn OFF and
the door witl begin to move, The opener receiver has been ._
programmed with your code selection. (_
NOTE 1" If the indicator light turns OFF before the code _ . "_ _'
digits and ENTER key are pressed, repeat Steps 2 and 3. _._t,_-_ J t_
NOTE 2' During programming, be sure the,k/_ca_i_n push :---'-"_"
button (if your opener has that feature) is OFF and the
Infrared Sensor (if you have installed that accessory) is
free of obstruction. THE DOOR WILL NOT MOVE AND THE
INDICATOR LIGHT WILL NOT TURN OFF in either case.
To change your code at any time, repeat Steps 1, 2 and 3.
Hope this helps
Apr 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door will only close with keypad code it will not open
UNPLUG THE UNIT AND WAIT 5 MIN.
WHEN YOU PLUG IT BACK IN CLAER ALL CODES BY HOLDING DOWN THE PROGRAM BUTTON FOR 20 SECONDS.
NOW TRY TO PROGRAM EACH REMOTE AND KEYPAD - IF THERE IS STILL A PROBLEM CHANGE THE BATTERIES AND REPEAT THIS PROCEDURE.
I HOPE THIS HELPS
Mar 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to change keypad access code for Sears garage door opener
To change the code, you need to hit the LEARN button the back of your machine. You will see a yellow light flash. Enter a 4 digit code on the keypad and press enter. The lights on the opener should flash and you should hear a click. Your keypad is programmed.
Feb 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
How to lock the keypad with security code for sony ericsson?
I DONT WANT THE AUTOMATIC KEYPAD LOCK..BUT I WANT TO KNOW HOW TO MAKE KEYPAD SECURITY CODE SAME AS NOKIA..PLEASE HELP ME..
Dec 26, 2008 | Sony Ericsson S710a
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
94 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
