Question about Brother HL-2040 Laser Printer
Paper comes out in horizontal folds. Red lite stuck on. Paper stuck on roller.
I 've already paid two times $14.99. I thought problem was fixed but I was wrong. Now another paper is stuck under the red roller. And the red "Paper" light is on continually. Last time we cleared the stuck paper and green lite went on. I thought it was fixed but then I tried to print & the copy came out folded as before. The next paper after that got stuck under the red roller.
    Brigadier General:
  • 6,966 Answers
To your concern of twice paying and problem still exists, you could always email premium.support@fixya.com and bring this to their attention. I am sure that they will be more than happy to attend to your requirements.
Alternately, you could click on the "Ask Me" button of the expert that assisted you and seek further assistance.
As to your printer problem, may I kindly ask what has been done in terms of repair, adjustment or anything to try and correct the issue.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 15, 2008
Pasta roller squeaks when dough is not going through
The others had good solutions but I thought I would add mine as well.
I put vegetable oil on both outer edges of a folded paper towel that fits the entire width in the narrower roller settings of the machine. I run it through 3-4 times as if it were a piece of dough. It takes away the squeaking.....at least until it is needed again.
Dec 30, 2010 | KitchenAid Pasta Roller / Cutter Set
Konica Minola 2300DL laser printer. When I try to print, it jams at the printer rollers just before the paper ejects. It fan folds in the top rollers There is no paper stuck anywhere?
I would closely examine the exit roller. When the paper fans; it's sticking on something. Typically, stuff will ":hide" on rollers; or maybe stuck on a sensor. Using a good flashlight will help.
Oct 27, 2010 | Konica Minolta magicolor 2300DL Laser...
In my 3530 single side copying is ok but when i am trying for back to back my A3 paper is getting jam with z fold pls guide
are you talking about ir 3530 b&w copier?
"Z FOLD" of jamed paper is usual when paper goes from cass. towards registration roller, and registration clutch doesnt operates.
Do you have problems with A4 double sided too?
Where does the jam occures? In wich section?
I had few cases, when the paper stucked above fixing unit in small inner door, wich guides paperout or back in duplex, for second side copying.
The problem was in spring and solenoid wich lifts the paper guide plastic with finger.
It also could be case that you need to replace paper pickup, feed and separation roller in cassete where is A3 paper, and clean other rollers.
Try to put paper in "good" cassete, from wich you do not have problems.Just swap papers, and set correct paper sizes, and if it works then the problem is 70% in rollers.
On the place where the paper stucks, clean the paper rollers, by rotating it and cleaning with alcohol or water and dry it verry well.
Hope that helped.
If you have more questions or want service manual, write on emma.servis@gmail.com
Jul 09, 2010 | Canon Office Equipment & Supplies
After printing first page, the second page gets folded as envelope
Hello sir; It seems like registration roller clutch defect, replace it!
May 06, 2009 | Konica Minolta PagePro 1350W Laser Printer
HP Laserjet 4M makes accordion folds in the paper before jamming
I have found that with laser printers that have an occasional "crinkle" problem that "fanning" the paper does alleviate the problem ... but it will not if there is an actual feed/hardware problem with the rollers
Mar 13, 2009 | HP LaserJet 4M Printer
Paper coming out from the tray is folded for richo 2015
You do have a fuser problem. There are a set of stripper fingers that are supposed to keep the paper from wrapping around the heat roller. One of them may be damaged and is catching the paper. The Pressure roller can also cause problems if it is torn. You need to have the fuser looked at by a tecnician to determine the problem. Hope this helps.
Jan 26, 2009 | Ricoh Aficio 2015 Copier
Brother 2040 paper light .. continuous red
If you removed a piece. But more remains it must also be removed. Look closely along the paper path for something that will release to provide access to the path.
May 03, 2017 | Brother HL-2040 Laser Printer
Won't print.
can u pls rated this solution as fixya
bcuse i solved your problem
Oct 11, 2008 | Brother HL-2040 Laser Printer
Martin Yale Paper Folder Problem
Im not familiar with a paper folder but if its anything like a printer, it probably has a maintenance kit you can buy or you may have to replace the rollers. Alot of the times they have a rubber grabber that wears out or a roller that gets dirty and doesnt catch the paper evenly and pulls it through at an angle, crinkling it. Check for debree or paper particles that may be floating around inside.
Jan 02, 2008 | Computers & Internet
Dell 1700n Laser Printer Jam trouble
If it?s always in the same spot then you can narrow your search for the problem. -Look where the leading edge of the paper is getting jammed up for an obstruction, especially if the paper is folded in an accordion fashion. Look closely, I?ve fixed many a paper jam by pulling out a corner of a page stuck in a recess. -If the paper path is clear then the next thing I would suspect is the paper you are using. -Try new paper that isn?t bowed, folded or curled. Before inserting into the paper try flex it back and forth along the width and length, then insert making sure to slide the two side guides and the back guide until they fit snugly against the stack of paper. -Other things to check are the rollers where the leading edge of the paper is getting stuck. Make sure they are clean. -Also make sure your toner cartridge is inserted into the printer correctly. If you have a spare try using that, sometimes cartridges can drag on the paper.
Feb 25, 2007 | Dell 1700n Laser Printer
Brother HL-2040 Laser Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
