I have a 913t monitor and about 3 months ago it started to go to a black screen with an error message "not optimum mode recommend 1280 x 1024 60 hz" any help???
  • 749 Answers
Click START-SETTINGS- CONTROLL PANEL - DISPLAY - select the SETTINGS tab at the top - click onthe ADVANCED button (bottom right)- select the monitor tab- in the screen refresh rate dropdown box select 60htz- click on apply & ok - back at the display properties page , slide the slider for screen resolution to 1280x1024- click apply and ok. restart the computer. this show resize your desktop to the correct resolution and refresh rate recommended by your information.
Posted on Oct 15, 2008
SAMSUNG SYNCMASTER 226BW WHEN TURNING ON MONITOR, IT SHOWS BLACK AND WHITE LINES THEN IT SHOWES A BOX THAT SAYS "NOT OPTIMUM MODE, RECOMMENDED MODE 1680 x1050 60HZ " AND IT IS STUCK ON THIS...
hi dear
start your computer on safe mode and go to the display property change to as per mentioned rresolution on your screen.
best of luck
regards
raj
Sep 06, 2011 | Samsung Computers & Internet
My monitor keeps going blank with a window that pops up saying "Not optimum mode. Recommended mode 1280 x 1024 60Hz" then there is a question mark box. I can't get the display back, no matter...
check you video graphic card option and select or fight the right resolution,otherwise update your video card and you can use this :
CLICK ME
here's the serial : JCCQ-MAKC-KACK-6TSE-BN35
Jun 05, 2011 | Samsung SyncMaster 912N 19" Flat Panel LCD...
Floating box non optimum mode recommended mode
You need to adjust the Display screen resolution.
  1. Control Pannel
  2. Display
  3. Settings
  4. Screen Resolution
Sep 22, 2009 | Samsung Computers & Internet
Monitor problem: not optimum mode recommended mode: 1280x1024 60 hz ? cannot click on screen. Samsung model 913T s
It appears your display adapter is set to a different refresh frequency or resolution,
either accidentally or due to some power glitch.
If you cannot set the resolution because this message is preventing you from getting to the
display settings window, try rebooting your PC in Safe Mode. It'll take a while longer
than usual, but when you're finally running, try setting your display adapter to the
1280x1024 60Hz settings. This is available under "Advanced->Adapter->List all modes".
To reboot in safe mode, try pressing the PF8 keys repeatedly after the POST messages
disappear just after turning the power on. This only works if this key is enabled to
operate from the BIOS settings.
To get to the BIOS setup, Look at the first messages displayed on your screen indicating what key to press. It's usually the Delete or PF2 key, but different BIOS manufacturers use different keys.
Once inside the BIOS setup, find the way to enable the PF8, PF9, PF10, keys. Save your
settings and reboot.
Now you may try PF8 again to go to Safe Mode.
Good Luck!
Aug 19, 2009 | Computers & Internet
Samsung Syncmaster 710n monitor - screen goes black for no reason. All cords connected properly. Computer works with other monitors. Switch on front of computer is on - green light on. Get floating...
in safe mode adjust the resolution lower than 1280x1024
then restart and then install the driver again the driver is crrupted than install the right driver problem could be solved
May 16, 2008 | Computers & Internet
Not optimum mode
change windows resolution and refresh rate to 1024 X768 and 60 Hz.
start->control panel->display->settings-> change the screen resolution to 1024 by 768 pixels-> advanced-> monitor->change refresh rate to 60 Hz-> ok-> yes -> ok.
Mar 03, 2008 | Samsung 710V 17" LCD Monitor
Error message
Kathryn, In the lower left, under the screen there is a row of buttons... One is labled "AUTO" have you tried pressing auto and if so does anything happen?? If not try pressing "MENU" first and then "AUTO"... What we are attempting to do is to get the monitor to accept the current settings so we can get the screen up and then deal with changing the resolution... In a Windows operating system the resolution is changed by going to "START" - "SETTINGS" - "CONTROL PANEL" - "DISPLAY" and in that window click on the "SETTINGS" tab and reset your resolution. This one might take some better communication that emails - because it would be easier to know in real-time how the monitor is reacting as you input various things... You can give me a call at 360-642-4993 or we can set-up a live chat. I'm assuming since you were able to place this post you have a second computer to work from? Bill
Jun 06, 2007 | Samsung SyncMaster 913N 19" LCD Monitor
Computers & Internet Logo
138 people viewed this question
David Payne
David Payne
