My dvd player wont work
Every time you put a dvd in the dvd tray it says its loading when the disc doesnt even spin. i think the thing that makes the dvd spin is broken, how would i fix this and would i have to buy any parts for it
  • sndezz Oct 16, 2008
    same problem here
I'm having the same exact problem with my daughters disney princes tv DVD combo! What a POS!
Posted on Sep 27, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Not worth fixing. Just buy a reliable brand that doesn't have that problem or a cheap machine for $20-$40 and get a new one every two yrs or so.
Posted on Oct 17, 2008
I have a 5 yr old liteon LVW5005 dvd recorder.I am a light user and this unit did recorder around 100 dvds. Now the recorder wont read any discs I have been using -r have tried +r no good as well the...
Hello
According to your description, it seems that the disc tray is not loading into it porperly i thinks. Just do one thing. Without any disc in tray, close the tray either by using remote control or the front panel opn/close button of the system. If the tray closes first, and then reopens again without any command, make sure that the disc tray mechanism does not working properly, and the disc is not loading into it in place.
If this is alright, place a disc in the tray, set close, and push the tray with your finger slightly as it closes, and see whether it loads properly and play the disc. If so, loading belt inside the loading mechanism is worn out, ans should be replaced. In most cases, this may be the fault. Check it.
You can do the repair work, if you have some knoledge in electroncis, and its mechanical function. If not, get it repaired by an experienced service technican. Most of them can do this work, as it is simply a mechanical one. OK.
Mar 31, 2011 | Lite On LVW-5005 DVD Recorder
I have a digital labs model K715 dvd player. when i put a disc in, it spins, screen say its loading but will spin, stop, spin and stop again. Wont play the disc.
Try doing the following...
Making sure the "line select" has been switched from "in" instead of "out". Once you switch it back to "out", the player should work normally.
Mar 05, 2011 | Insignia NS-PDVD8 Portable DVD Player
It Loads but doesnt spin and said "no disc."
Try cleaning the lens with a DVD Disc Cleaner or Methylated Spirit and a Q-tip, rub the lens slowly in a clockwise motion, leave to dry and put in a DVD, if it doesnt work try a CD but make sure they dont have any scratches or dust on them, if a CD works ( or not ) then your lens is knackered.
jon
Aug 12, 2009 | Polaroid Portable DVD Player PDM-0822BD
Xbox 360 open tray error.
This actually concerns the entire loading dock assembly and optical lens. this is an all in one piece. you can separately, replace the optical lens but, if the tray is not operating smoothly,i recommend replacing the entire DVD drive. You can order a new DVD drive at this link below. http://www.videogameall.com/repair-part-xbox360-samsung-toshiba-dvd-drive.html
Jun 03, 2009 | Microsoft Xbox 360 Console
Player won't load any discs
I don't have a solution at this time. I have the same DVD player and mine stopped working this past weekend. It is doing the same thing as yours. I opened the case and loaded a disc and watched the mechanism. The disc won't spin. if you tap the disc it will start spinning and load and start playing. I thought I had fully fixed it. It will load most times but now the video and audio stutters as if the discs is spinning at varying rates.
Apr 06, 2008 | Sony DVP-NC85H Multi-disc DVD Player
Philips dvd783c wont spin.
It sounds like one of the hindge/wheels are off set. Most of the time that can also cause the lazer lense not to come up all the way in order to properly read the disc. When you keep the door open and press start does it allow the lazer lense to come up all the way? That is the small circle glass peice you will see when you look in--some you can see it some you cant.
Let me know.
Thanks.
Mar 31, 2008 | Philips DVD783CH Multi-disc DVD Player
Says no disc
I have experienced the same problem. When I put the disc in I give it a spin in the clockwise direction. It works everytime!
Sep 24, 2007 | Durabrand DVD-1002 DVD Player
Disc won't spin
I hate to be the bearer or bad tidings, but it sounds like the previous owner tried to repair the DVD tray and failed. You might want to take the unit apart and see if there are any internal screws missing. If there are any missing, it can definitely cause issues with the spin up on the DVD tray. If everything is intact, you may have to replace the DVD tray. Hope this helps. Good luck.
Jun 10, 2007 | Sony PlayStation 2 (PS2) Console
After trying to read a disc it says cannot read
I had the exact same problem - I bought this DVD player TODAY at a garage sale for 5 bucks, they said it wouldn't read the disc, so I looked it up and found this thread. I did what that other person did, in that I had a DVD loaded into the player, then I took the top off. The DVD worked perfectly! I actually didn't even have to touch anything inside. I then put the top back on, making sure not to tighten the screws too hard. I think what it was is that this is a very slim unit, and there really isn't much room for the motor to spin the DVD, especially if there is even a 1 millimeter bend in the casing - it prevents the DVD from spinning around. I would reccomend never putting anything on top of this DVD player.
Jan 14, 2007 | Sony DVP-NS501P Progressive Scan DVD...
Televison & Video Logo
203 people viewed this question
Top Televison & Video Experts
Electro Med Services...
