Win XP: At every startup or reboot VOLUME goes back to zero requiring reset to get any audio.
  • 103 Answers
Hi
Try reinstalling your audio driver. I helps in many cases.
Genius Guy
Posted on Oct 16, 2008
Advanced configuration settings for the Belkin wireless G Plus mimo network adapter
Enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
Jan 22, 2013 | Belkin F5D9050 Wireless G Plus MIMO USB...
50pq12...lg hdtv... my volume stays at zero
If the display for volume goes up but there is not sound--a number of simple things to do.
Does the set have sound with a DVD etc hooked to one of the rear audio/video inputs?
If using a box for signal, a receiver etc--unplug each one at a time and after a short wait plug them back to allow them to reboot.
In set look to see speakers did not somehow get switched OFF.
Cable, Sat and receiver all have volume controls so make sure someone did not turn one of them to zero sound.
You could have a audio problem in the set itself but that is fairly rare.
May 23, 2012 | LG Televison & Video
Laptop wont start windows xp pro. goes to a blue
Take one memory stick out and test. Then do the other. Also checking each memory slot.
If not solved. When the computer starts, continually press F8 until you get startup menu- select SAFE MODE and fix the driver or software that is in startup
or
Roll back to last known configuration that worked.
While you are there- disable Auto Reboot on Failure.
May 02, 2010 | Computers & Internet
Startup switch on PB G4 17 not getting apple sound, takes numerous times to boot up. Using Tiger OS, upgraded to latest. Works fine, otherwise.
If a Mac is shut down while the volume is set to zero, the standard Apple startup chime will not sound, so it is impossible to say whether or not this symptom indicates a problem.
For a startup issue such as this, I would recommend zapping the PRAM and resetting Open Firmware.
To zap the PRAM, start with a powered-down machine, press the power button, then immediately hold down the four keys: command, option, P, R. After ten seconds or so, you should hear the optical drive reset, and then the startup chime (because the volume is reset to full by this procedure). Ten more seconds, another reset, another chime. After the second time you hear the chime, release the keys.
Shut the machine down again (if it doesn't start up successfully, hold the power button until the power goes off). Press the power button, then immediately hold down the four keys command, option, O, F. You will see some tech-speak on the screen, then it will wait for input. Enter the following three lines, pressing the "return" key at the end of each:
reset-nvram set-defaults reset-all
After the last line, your Mac will reboot itself. It should now boot much more reliably. If it doesn't, chances increase that you have a hardware problem. You may want to run the Apple Hardware Test from the DVDs that came with the PowerBook to check your memory and logic board. Failing this, you are in for a trip to the shop.
Oct 05, 2009 | Apple PowerBook G4 Mac Notebook
Getting a Blue Screen after upgrading with Win. Vista Business Upgrade from Win. XP Pro.
Restart the computer is Safe Mode (press F8 when booting to get a menu of options). This will start the computer with the minimum number of drivers and "extras" being loaded. From here you can press Win+R to bring up the Run command and enter 'msconfig' and press Enter. From this tool, you can allow your normal startup programs and device drivers to load. You will want to keep anything related to your DSL drivers disabled for the time being. Then restart the computer normally. If everything loads as it should, you can keep going back to the MS Configuration utility to add other drivers and programs one-by-one and retest (reboot again) to make sure everything is working properly. Once you know what the culprit is, you can uninstall that program and reinstall the Vista version if required. (If it is just software for your DSL modem, it probably is not required under Vista.)
Apr 14, 2009 | Computers & Internet
SP3 screws up zero volume knob range?!
Fixing the wrong problem perhaps? May I suggest that installing SP3 to fix an unstable SP2 XP install is just wrong, masking the problem,
- not fixing it. Buy a new Hard Drive - install a clean Win XP and I bet all of your Edirol problems ( and others ) will vanish. Don't touch your old drive, But once you are happy with the build install it as a slave data drive.
Oct 14, 2008 | Edirol UA-25 External Sound System
Low volume
Assuming you are running XP.
uninstall and reboot then restart
device should autofind and self install
Let me know how it goes thanks
Please rate me ,,,Cheers
Jul 21, 2008 | M-Audio Audiophile 192 Sound Card
Sound problem
If you're talking about Windows XP, the volume control is available from the Control Panel under Sounds and Audio Devices; place a check-mark by the Place Volume in Task bar.
If you don't have Win XP, you can try to reinstall your sound icon by going to Control Panel -> Add / Remove Programs, Windows Setup tab and then double click the Multimedia icon and place a checkmark on Volume Control. If it's already there, take the checkmark off, then click OK. Then go back in again and place the check mark on.
This will hopefully reset it.
Mar 24, 2008 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
