Question about Gateway Computers & Internet
Enthernet is not working
I have a gateway 2000 computer I bought about 10 years ago, but it still works. I need to hook ethernet wire to my router from my computer, but it did not work. I am told that I should dowload a ethernet network adapter or something else. I don't know where I can get it. MY computer model is
G6 - 400 My e-mail is: wgu@interact.ccsd.net
Thanks a million.
  • 108 Answers
If you are still using Windows 98, I would suggest getting winsockfix and running that on the old PC.
I would assume you DO have a network interface. Which is or can be ethernet.
It may very well be a software issue, if you have the hardware.
G'luck
Posted on Oct 24, 2008
Older Li-ion notebook,model3620
As long as there is a driver for the Ethernet built in card or you have a dongle, plugging the router into the Ethernet in socket with the correct cable, it should recognise the Ethernet link.
Sep 11, 2014 | Computers & Internet
I've got an old Gateway desktop I need to connect to a wireless router for my job. I just bought a new, much stronger NetGear router and it still won't connect. I no longer have a laptop and I'm DESPERATE...
Unless you've installed a wireless card in your old desktop you will never connect wirelessly.
Desktops don't come equiped to do wireless communications. And an "old Gateway" surely does not have those capabilities.
You have 2 options
1) Purchase and install a wireless card for your Gateway
2) Use it hard wired... Purchase an "Ethernet cable" of sufficient length and plug it into one of the open ports on the back of the router and into the only place it will fit on the back of your computer
Jan 31, 2011 | Gateway Computers & Internet
Please help me install the above router. I bought
First connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
If you cant access it with above link then reset it to defaults.
For that check in back panel of router you find reset button press it for 10 seconds so all settings goes to defaults.
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page for router.
Enable dhcp if you want to get ip from router.
check wireless settings .
Check wep password if it is enable for security.
Let me know if you need further assistance.
Thanks.
Oct 26, 2009 | Linksys Wireless-G Broadband Router
1 of the 2 computers cant get online
Pleaase check if the PC connects when plugged directly to the DSL or cable connection whatever you have without the router in between. That would ensure the functionality of the ethernet card on the other pc.
Feb 10, 2009 | NetGear MR814 Wireless Router
ATT/SBC gateway router....
Take the ethernet cable from modem to PC and hook it into the router(modem to router)...run another ethernet cable from the router back to that PC(router to PC). All you machines should be fine then.
Jan 25, 2009 | 2wire 2700HG-B Router (2700HGB)
My DSL was installed. I am trying to hook up my linksys wireless router, when I do the internet does not work. What am I doing wrong?
modem type ? make sure it is on modem-only mode if it is a home-gateway type.
connect modem ethernet to router internet port (located next to the power port).
press & hold for 10 secs. the routers reset switch (until all lights blink).
launch the internet connection wizard & select "computer is connected to a gateway / internet connection is always ON"
Jan 14, 2009 | Linksys Wireless-G Broadband Router
I bought a new desk, so i had to redo my internet, because it quit working on main computer when i hooked my computer back up, so i had to call my internet provider and i got main computer back up, and now...
you may need to reset router to factory settings. look in documents or their website for instructions that apply to your router.
Also, I assume you have everything powered off when switching cables.
Jan 02, 2009 | Computers & Internet
Dynex 4 port ethernet router
When the TCP/IP is set to dynamic or "Obtain Automatically", the default gateway is supposed to blank. The default gateway address of your network is actually the router's IP address.
What is the IP address that you get when you performed step 3?
Nov 17, 2008 | Dynex 4-Port Ethernet Broadband Router...
2 wire 2700 hg-b
The 2Wire 2700 is a residential gateway, a modem and router in-one. There is an RJ-11 jack in the back of the gateway and this is where your dsl phone cord plugs in. There are four RJ-45 jacks in the back for connecting devices using ethernet cable. As a router is can operate both wirelessly and wired. For wireless operation you'll need the WEP key which is located on the tag on the bottom of the gateway. It's the number enclosed in brackets, between the two bar codes.
Redneck Geek
Sep 09, 2008 | 2wire 2700HG-B Router (2700HGB)
Enthernet connection
Ethernet connection is a LAN or a CAT cable
One end of that cable will connect at the back of ur router box that u will have with u or u will get it from ur ISP .
and the other end of that cable goes to the back of ur pc in the jack which says LAN or try to plug it in any socket which fits properly.
u will a light that will start flashing at the back of ur back when u plug that cable in
to check whether u system supports ethernet connection or not
1. right click on my computer
2. goto properties
3. goto hardware
4. goto device manager
5. u will find network adapters there
click on the plus sign on the left side of network adapters
plus sign will change to minus
under network adapters look for an ethernet adapter or network controller
or 10/100 or 10/1000 fast ethernet NIC ( network interface card )
if u have one , then ur pc supports ethernet connection
U just have to connect the ethernet cabel to ur router box and at the back of ur pc and u just have to open internet explorer and ur internet would start working...
if u dont have ethernet cable with u or ur system does not have an ether net socket in ur system , u can goto any computer shop and get an ethernet cable and a socket for ur system
If u dont want to do that , u can go for a USB cable connection with ur pc or a wireless connection....
reply back if u face any further problems
Feb 19, 2008 | Computers & Internet
Computers & Internet Logo
106 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
