Question about Kenmore Refrigerators
Water on floor in the morning front of refrigirator
I think the drain for the defrost water is stopped up, but i can't find it!
  • widebelt Oct 15, 2008
    is the drain tube in the freezer compartment, and open to view?
  • 943 Answers
HI thanks for your question. the drain tube is under the freezer. the drain hose goes to the drain tray at the back by the compressor. pull fridge from wall, remove the back panel, clean all the dust on the coils. find drain tube, by the drain tray. turn fridge off. let thaw. clean out the drain tube. if you need more assistance. please don't hesitate thanks
Posted on Oct 15, 2008
Freezer door is leaking water at the bottom of the door
This sounds like the defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle.
If you can see ice on the bottom of the freezer floor, then this is likely your problem unless your ice maker is leaking from the top of the freezer.
Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Kenmore 57029 Side by Side Refrigerator
Water on floor freezer side front left facing, could be frozen defrost line, where is it?
I think you are right.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
Nov 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Occassional water dripping from right front corner to floor. Defrost tube is also dripping into tray as it should. Door gasket seems intact.
The defrost water should pour not just drip in the pan. I believe the drain tube is probably partially stopped up.
Nov 12, 2009 | Refrigerators
WATER LEAKING FROM THE FREEZER INTO REFRIGIRATOR
Remove back wall from the inside of the freezer. Some models you have to remove the floor first, others you don't. There will probably be a lot of ice so have plenty of towels and hot water ready. It may take quite a while to get the ice to melt completely, but in my experience it is ALWAYS ice. Just keep refilling the pan with super hot water, and poke into the drain hole with a cable tie or pipe cleaner. When the water feels like it has gone cold, wipe it up with a towel, and refill the pan with hot water.
Jul 27, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Water at bottom of refrigirator
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
Jun 19, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water pools on floor
Check for a blocked defrost drain. Take the panel off at the back of the freezer section and find the small hole at the very bottom center below the cooling coils. Use hot (but not boiling) water and a turkey baster to flush it out until water runs through it. (it will go into the defrost drain pan, where it will evaporate)
May 24, 2009 | GE Refrigerators
My Maytag side by side freezer/refrigirator MODEL MSD 2554AR is having ice frozen at the botton of the freezer basket.This later melts and form water on the floor of my kitchen.
Ukoni, the drain tube for the defrost is frozen over or clogged. When the unit goes into defrost the water is running out through the front instead of down the drain tube. You can try to pour some real hot water with a baster to clear the tube. Remove the lower basket and at the bottom of the freezer panel in back is where the drain line is located. Catriver.
Jun 10, 2008 | Maytag Refrigerators
Whirlpool Refrigirator
water is probably caused by ice blocking the drain for the auto defrost. take off the back panel and you may see ice accumulating at the bottom of the evaporator. switch off, clear the excess ice with a hair-dryer used carefully and make sure water runs down the drain freely. ice in the drain may take some clearing - boiling water and patience are needed
Apr 14, 2007 | Whirlpool GS6NBEXRQ Side by Side...
Refrigerators Logo
123 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
