Question about Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 will not print or copy
I received a fax this morning and it was fine. I tried to print a paper and it would not print the page. I canceled the print job but it says "print" on the printer screen. I tried to copy and it scanned the paper but would not copy. Screen says "copying". I hit the stop button and it went back to saying "printing". I have unplugged the printer and turn off the computer and rebooted. Nothing helps.
  • jselph Oct 15, 2008
    After choosing premium on here and going through the same things for 30 minutes.. I found my paperwork from Brother and called them (should have done that first). Brother fixed it in 2 seconds. Told me to unplug it, hold stop button, plug back in while continuing to hold the stop button.. viola.. I can copy and print again.
  • jselph Nov 06, 2008
    Thanks for the solution, I had already figured that out by calling the maker of the printer and posted it here more than two weeks prior.
  • 3 Answers
YOU HAVE TO RESET.
TURN OFF THEN PRESS THE STOP /CLEAR BUTTOM THEN TURN ON KEEP PRESS ABOUT 10 SECOND THEN IT WORK .
Posted on Nov 04, 2008
5 Suggested Answers
SOURCE: brother mfc 8440 "printing" problems
Hi
I recently had this problem - tested fuser and all sensors.
The fix is to reset the memory.
To do this, enter the Maintenance mode. Menu, * 2864
(enter the number quickly)
then type 01 ( zero one ), this will reset all memory including the user settings.
Finally type 99 to exit Maintenance mode.
The printer will restart and the error will be gone. Test out with copy and printer reports
Hoping this fixes your problem
Regards
Lindsay
Posted on Nov 25, 2007
Crankstart
  • 696 Answers
SOURCE: Brother MFC-8440, send fax ok, but no receiving fax
The manual has step by step instructions, I'll include a link for the online version. Section four runs through setting up recieving, if it's on a dedicated line follow the first set of instructions to set up automated answering. If it's a shared line(phone/fax) then continue down to the next section.
Note: for a shared line you may need to contact your line provider for a second number that has a "dedicated ring"
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000219/MFC-210C_UsaEngUsr_B.pdf
Hope this helps FixYa,
Chris
Posted on May 13, 2009
pineworks
  • 4041 Answers
SOURCE: I am a first time user of the scan function. Brother MFC 8440.
Hi there
I myself would just scan the one first and send it to your PC and then scan the other part and send it to your pc and then just copy the first 1 in to the Microsoft word program and then copy the second one and past it into first under it so it becomes as 1 then upload it to your email and send, this is what I do.
Or of cause you can upload 1 first to your email then upload the other one to your email and send.
All The Best Pineworks
Posted on Feb 18, 2010
SOURCE: MFC-8440 All-In-One Laser Printer: how to clean the drum for Brother MFC-8440...
who's corona in drum for MFC-8440 brother , can cleanse it ?
Posted on Jul 05, 2010
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Brother MFC-8440 Check Originals
Check original normally means that there isn't an original in to copy. If it says that when there is an original it probably means that the paper sensor is jammed in some way.
Jun 26, 2009 | Brother MFC 8440 All-In-One Laser Printer
Two fax machines on one line, one won't send
Buy a double outlet RJ-11 adapter.
Set the one you use for sending only to MANUAL RECEIVE.
Jun 22, 2009 | Brother MFC 8440 All-In-One Laser Printer
Sends blank fax
Dirty scan glass
Clean slit of glass extremly well, it is a small slit rectangler section of glass before copy glass on the scanner.
Glue, Liquid paper are common finds on the glass in this area, While you have the lid up, clean white reference area (on lid directly on top of scan glass when lid is closed)
Feb 04, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC6800 not printing
To answer more effectively - how is the printer connected to the iMac? Is it a USB connection, a printer cable, is the MFC 6800 connected to a print server, an AirPor, etc? A second question I have is if you are trying any kind of tricky printing such as manualduplex printing.
Also, a shot in the dark...Is the Auto Reduction set to on or off? To check:
1. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 4 (Auto Reduction).
2. Press the up or down navigation key (keys located above and below the
MENU/SET key) until the display shows "Reduction: ON?".
3. Press MENU/SET.
4. Press STOP/EXIT.
Another item to keep in mind:
You can use three sizes of paper for printing your faxes and
copies---letter, legal and A4. When you change the size of paper you ha
ve loaded in the Brother machine, you need to change the setting for the paper size so your Brother machine can fit the incoming
fax on the page. To set the Paper Size:
1. Press MENU/SET, 1 (General Setup), then 1 (Paper Size).
2. Press the up or down navigation key to select LETTER, LEGAL, or A4.
3. Press MENU/SET.
4. Press STOP/EXIT.
Nov 20, 2007 | Brother MFC 6800 All-In-One Laser Printer
Brother mfc 8440 "printing" problems
Hi
Regards
Lindsay
Nov 15, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
Printer thinks its out of paper when its not. Displays messsage "Check Paper - Reload Paper." Have emptied and replaced paper stack several times. No visible jam. Have shut down and restarted. Still not fixed.
Oct 30, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
314 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
