Printer connected to more than one computer.
How do I install a printer to more one computer so they all can print of it? I dont have a clue of how printer servers work or how to set them up, so is anyone able to instruct on this?
  • 477 Answers
Hello
I gonna try to help you.
1. you need all the computers connected to same network.
2. you need to share your printer from the computer where the printer is connected to.
to share
a. go to control panel->printers and rightclick on your printer click sharing.
b. then share that printer and give it a share name and then OK.
click here to see pictures exact information about sharing.
c. you also need to know what your computer that shares the printer is named.
to find out go to control panel->system settings and tab computer name. write that down
a shortcut to this windows is "windows button flag" + Pause Break button.
3. go to the computer you want to install the printer on.
this computer need to be in the same network as the one with the printer.
4. click start menu then ->run and write "\\computername" and press enter. computer name is that name you write down in c.
5. then a window should appear and you can now double click on your printer that you shared, then it should auto install. done.
6. if you can find your computer with the printer, check your firewall settings on the computer that shares the printer so the connection doesn't been blocked.
good luck, if you need more help don't be afraid to get in contact with me. true fixya forum or fixya live chat
good luck
Dell-Net
Posted on Oct 15, 2008
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
The problem with my printer is that dont print.I shive papers to try to print the print dosent work
Please check the connection between your printer and computer, check cables if properly connected. Check if printer is showing on printer and faxes and make sure is set as the default printer. You may also download and install the correct print on your computer. For set up instructions please refer to the user manual which is available from support. lexmark.com website.
For further assistance, please contact Lexmark Technical Support.
Feb 13, 2011 | Lexmark E120n Laser Printer
I have brought a lexmark x4975 printer with no manual or disk.... and have not got a clue how to set up wireless printing... please help
Wireless printing happens in conjunction with your wireless router. You need the access information for that. Then go to Lexmark website and download and install the software for that printer, and follow the directions exactly. Each computer will need software installed in order to connect.
Sep 26, 2010 | Lexmark X4975 Wireless Color Multifunction...
Brother MFC-490CW Won't Print
If you have installed something since yesterday you might want to use system restore. the program might be causing the flaw. If not dont worry. You will need to uninstall the printer from your printer page and reinstall it. depending if it is a networked printer or a usb connected. If networked all you have to do is follow the install wizard. but if it is a usb you will have to go to the company's website and download a printer driver. after that it should work. dont forget to restart your computer. sometimes that can help too.
Jun 30, 2009 | Brother MFC 490cw Color Inkjet...
My printer software isnt english and I havnt a clue what it says.
click start--> settings ---> printers and faxes
uninstall the already existing printer. and try with new installation while installing selec the correct language
Apr 11, 2009 | HP DeskJet D2560 InkJet Printer
Samsung CLP 300 - Drivers keep disabling
The printer is probably not getting the same IP address every time. Set a static IP address outside of the range being used for DHCP addressing. If the entire range is set for DHCP, you will need to adjust that range so the printer's IP is no longer in it.
Nov 09, 2008 | Samsung CLP-300N Laser Printer
Lex. x 5495 won't print from pc.It worked up to a short time ago.Will print from laptop.Driver,cables. connections are good, occosionally will print a remaining document from previous attempts first thing...
check all this possible problems and solutions:
-Check the printer status lights, or the status LCD screen. If there's a flashing light, or if the status screen shows an error, then it's your first clue to a problem. Most printer manuals have a diagnosis process for alerts.
common problems are related to toner or toner cartridges. If the problem is toner-related, check to see if the toner cartridge is empty or low. The printer warning should indicate this. Swap it for a new one and the unit should work.
check to be sure that it is connected to your computer. Personal printers connect via either a parallel or USB (universal serial bus) connector to the back of the printer. Follow the cable from the back of the printer to the back of the computer to make sure the connection is good.
When a printer acts up and there is no hardware problem, the solution is often driver-related. A printer driver is a piece of software that allows a computer to "talk" to a printer. It's a kind of translator. Occasionally, if a printer has worked previously, but suddenly doesn’t work with a newly installed program, there could be driver problems. To remedy this, download a driver from the printer maker's website, remove the old driver, and install the new driver. Drivers are normally available under the "support" area of a website.
Sep 16, 2008 | Televison & Video
Only printing tasks from some computers
Print the Menu Setting out on printer and menu setting out on pc. Match sure emulation matcheds on both sides. If using serial make sure serial settings match on both sides. If parallel, check the bois on the PC, change parallel port type to EPP instead of ECP or SPP.
Feb 13, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Printer Busy message
check your mac connection settings, change if needed, try install new printer.
Dec 07, 2007 | Konica Minolta bizhub C250 All-In-One...
62 people viewed this question
jasbo
jasbo
