Question about KitchenAid KGRT607 Gas Kitchen Range
F2:E1 Error - Now Panel Not Working
I recently bought a home that had one of these appliances and until a month ago it was working ok. I started to get the error code F2:E1 once in a while and then it would disappear a moment later. Now the electronic panel is not working at all. I turned the breaker off and on and it came on for a bit, but then stopped working. If anyone knows what the problem may be so that I can call someone and say this is the problem, that would be great so that I don't have to pay someone $100 an hour to figure it out.
  • 906 Answers
Good day,
hope this link below will solve your problem.
kitchen
Posted on Aug 04, 2010
What does E1 and F2 mean?
The F2 E1 error on Whirlpool-manufactured ranges means that there is a communication error between the touch pad and the control board. One or both parts could be bad or the wiring between them has been damaged or not secured properly. If you press Cancel, does the error return in under a minute? If the range is under warranty, contact the manufacturer.
IF you want to try repairing the unit, first unplug (or trip your circuit breaker to off) your appliance. That will a) reset the error and b) allow you to safely access the control panel from the back of the range. If you are handy and willing to take the time, you can disconnect the wires and watch for continuity as you press various parts of the keypad. (If you don't see any response, try reversing the leads.) Make sure that the wiring harnesses are seated correctly. They can become crooked and not make good contact at either the keypad or the control board. If you get a response from some keys and not others, replace the keypad. If the keypad is working, skip directly to replacing the control board.
If you aren't handy, start with replacing the keypad. Then replace the control board if the problem persists. (Some vendors will allow you to send back a part if it doesn't solve the problem.) Please add a comment with the model of your range for the part numbers and price lists.
I hope this helps.
Aug 16, 2015 | Kitchen Ranges
E1 F5 sign on panel control
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%^&*
Apr 20, 2010 | Whirlpool GR399LXHS Electric Kitchen Range
Whirlpool electric oven stopped working after using the auto clean feature. The control panel did display F5 E1, but now is blank. Reset breaker with no success. Model # RF368LXKB1. Thanks in advance
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%&*TR
Dec 08, 2009 | Whirlpool RF368 Electric Kitchen Range
F2:E1 Code
F-2 is oven temp too high, which would be a bad thermostat or thermistor.potentially. It could be the oven control module (which is probably what the guy changed out already).
Here is the code for kitchen Aid:
F2 - E0
or
F2 - E1 Keypad not connected Check keypad connector for firm connection.
Sep 20, 2009 | Kitchen Ranges
My Kitchenaid KERC506HBS stopped working, displayed E1-F5 and oven door is locked and won't open. Started smoking so we shut it off at the breaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.******
Jun 13, 2009 | KitchenAid KERC506HBS Electric Kitchen...
Start button does not work on whirlppol range
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$%^&UG
Feb 15, 2009 | Whirlpool GR448LXPQ Electric Kitchen Range
Kitchenaid YKGRT607HS6
F2:E0 is shorted keypad, and F2:E1 is no keypad connection, you need to replace the keypad.
You can find schematics and find replacements by entering model number here.
Dec 14, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Error code f2-e1 kitchenaid superba
I had this problem 2 days ago. Shut the electrical power of the range for 15 sec, than press cancel. Otherwise, call Houston!
Oct 21, 2008 | Kitchen Ranges
F5E1 error
Whirlpool-KitchenAid-Roper Appliances: Oven Fault Codes:
>>Exception Note:<<
Chart below does not apply to Whirlpool Models using the "Y" line in the products model numbers. Applies to models using 4 digit displays only.
F0-E0 Analog to Digital failure
Disconnect panel for 30 seconds
Should the above error re-appear, replacement of the control is required.
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
May 11, 2008 | Whirlpool RF378 Electric Kitchen Range
KitchenAid KGRT607 Gas Kitchen Range Logo
163 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
