Question about Akai CTS2550 25" TV
AKAI MX 150 - connection with DVD
I am trying to connect a DVD player to my Akai MX 150 TV. I have the AV cables in and the DVD player does power up and the display indicates that the DVD is playing (the numbers show on the display); however the picture does not appear on the TV screen. Do I need to have my TV tuned to a certain channel or is there another cable that I need to connect? Hope somebody can help. Thanks.
SOURCE: Screen powers up then goes blank after 2 seconds
Hi, was there a resolution to this? I am experiencing the same problem with LCT3285TA purchased at Radio Shack in Media, PA. Radio Shack has refused to service the unit and has put me over to Akai for the manufacturer's warranty. I'd like to know what to expect and if this problem with the Logo coming up and the unit shutting off/restarting can be easily fixed, thanks.
Posted on Jan 29, 2008
  • 152 Answers
SOURCE: AKAI Black TV screen, but still have audio
I think your Video Drum needs to be replaced since it's bad. You can get replacement Video Drums on the Internet.
Posted on Jun 07, 2008
  • 163 Answers
SOURCE: how do i tune tv channels?
I am afraid thatyou need the original remote to access tuning universal remotes will not give you this option. An original remote will probably be very expensive check with your local TV dealer.
SUPER8
Posted on Jan 05, 2009
SOURCE: i am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Posted on Jan 31, 2009
  • 5 Answers
SOURCE: finding AV channel without a remote control
Hi, I brought a EmersonTV model EWF2004 without a remote control and I can't find the AV channel to watch DVD's I hope you can help me
Posted on Feb 07, 2009
Trying to take tv off of av screen without the remote lost it
Turn off the device connected to the av output, then turn TV off and on again!
Aug 05, 2015 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
I am trying to Connect my TV no: ALT2260M to Geepas DVD but not connected how can i start functioning?
Check its connecting wire [AV cord] first for any internal breakage to its conductor strands. Try with a new AV cable. After connecting the cable with TV and DVD player, switch the input to TV to AV. Power On the DVD player. If all connections are OK, you should see the brand emblem display of the DVD on TV screen. If not, make sure that there is some fault, either with TV or DVD player. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 04, 2014 | Televison & Video
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
Hook up to view dvd's to tv video cables with yellow white and red plug ins.
Hello, here is a sample for auxilary connection for the chdvd300: . Use the AV (Audio/Video) cable
provided to connect the DVD player to
your TV as shown in the diagram.
. Your TV must be equipped with AV
inputs like those pictured to the right in
order to connect this unit.
. If your TV does not have AV inputs, you
will need a RF Modulator to connect this
player to your TV's antenna/cable input.
RF Modulators are available at major
electronics retailers.
Connect the DVD Player to
your TV
CH-DVD 300 Quick Setup Guide
. The goal is to see the DVD player's splash screen on your
TV. To do this, select the Video Input channel on your TV
that corresponds with the input the player is plugged into.
This procedure differs among TVs, but is normally done by
pressing the VIDEO IN or INPUT button on the TV's remote
control to select the Video Input.
. When the DVD player's splash screen appears on your TV,
you're ready to go!
4 Select the VIDEO INPUT on your TV
TM
Pr/Cr
PROGRESSIVE SCAN
COMPONENT VIDEO OUT
Y Pb/Cb
VIDEO
S-VIDEO
L
R
COAXIAL
TV
ANTENNA / CABLE IN
CH-DVD 300
VIDEO R - AUDIO - L
. Plug the DVD player's electrical
plug into a wall socket or power
strip.
2 Plug-in the Power Cord
3 Turn on the DVD Player and your TV
. Press the POWER BUTTON on the front panel to turn the
DVD player on. The POWER LED should now change
from RED (STANDBY MODE) to GREEN (ON).
POWER LED
You can find an quick install wiring schematic at retrevo.com, just type your model number in the search window.
Aug 11, 2010 | Cyberhome CH-DVD 300 DVD Player
Connected DVD Player to TV using HDMI cable doesn't work
Have you changed the input of your TV unit to AV1, AV2 or component...or what ever? If so and yet the problem prevails, then try to Plug the AV cable to the input of your Cable Box, if it has so.
If i was helpful, kindly do Rate!
Jul 21, 2009 | Toshiba XD-E500 DVD Player
How to connect (yellow, red & white) to component video
Connect either DVD player or DTH with the TV. There is only one input on your TV.
May 27, 2017 | Akai DVD-3850S DVD Player
I'm confused how to connect my DVD player with the TV. which cables connect where. I dont have a user manual.
Mukhhe,
good day,to connect your DVD to TV screen follow this steps.
1) prepare your RCA cable ( 3 colored cable yellow/red/white)
note: always remember this
yellow = video
red and white = Audio (left and right)
2) at the back or front display of your TV screen you'll see RCA socket marked as "AV1 input" "AV2 input" etc... if your screen is only mono sound you can only see two sockets Yellow=video white= audio
3) at the back of your DVD player connect the RCA cable following the color code yellow to yellow white to white and red to red. after you connect the cable to your dvd player now connect the other end of thr RCA to your TV screen input.
make sure you'll connect it to "A/V input" not "A/V out" then after connecting all the cables, from the remote commander of your TV screen press a button indicating "A/V" some mark as "TV/AV" press this button until your screen display the back ground display of your DVD player.
cheers,
mark
Jan 30, 2009 | Spectroniq PDV-70X
NO sound and NO cable signals
Is your tv connected to your cable box through HDMI, AV, or component?
_____________________________
If its through HDMI then your cable carrier needs to load updated frimware in your box to communicate properly with your 2005 tv. The firmware loaded in your cable box needs to be "reverse compatible" for first generation HDMI from your 2005 tv. If your using AV or component hook-up and there's no sound then re-check all of your audio settings within the tv's menu. Also recheck the cable-wire your using and proper input/output ports.
ON your dvd player, is your tv connected through component, AV(rca) or HDMI?
If its through "component" then you need an extra audio cable to and from the DVD and tv.
May 07, 2008 | Akai LCT2060 Television
My philips dvd player has stopped playing CD's and DVD's and on the display screen it shows "root". i have had this DVD player for 16months. Can you help me?? cheers
Usually "ROOT" is an indication that the player has read the DVD.
ROOT means that the DVD is in the main menu screen.
Sounds like the DVD player is ok, but you may have a loose connection somewhere.
Check all of your AV connections between the TV and DVD.
Also make sure that the TV is set to the same AV channel as the connection you are using.
E.G. if you have connected the DVD to the AV 1 socket of the TV, make sure that the TV is set to channel AV 1.
Apr 29, 2008 | Televison & Video
LASONIC DVD PLAYER NOT WORKING WITH COMCAST BOX OR SOYO TV
you have to plug everything to the tv. only thing them are good for is recording to some other unit. like dvd recorders
Mar 05, 2017 | Lasonic DVDP | DVD-7050 5.1CH
Akai CTS2550 25" TV Logo
47 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
