Question about Kitchen Ranges
Installing fire bricks in rayburn supreme
I would like advise on fire cementing the relavent fire bricks in place
I have a rayburn - probably 1950s - with the vertical bakelite handles and am not sure whether there should be firebrick at the back of the firebox agains the water jacket.
I had a rayburn once before and thought there were. Can you help please?
Posted on Feb 22, 2011
I have a 2 story brick home. The bedrooms are extremel hot in the summer even though I just replaced my air cond system.. Is it possible to put that expanding foam insulation in the outside walls without...
i doubt building regs will allow that (if you're in the UK), but drilling holes through the cement between bricks every few layers and every couple of bricks apart, then pumping the cavity with polyurethane foam........ and you'll need ALOT of PU foam!!!
you should really try asking in the right place first though, not here (problem with Nikon Coolpix Camera)?????
Jun 16, 2014 | Nikon Coolpix S9100 12.1mp Digital Camera...
Build a pizza oven in the back yard
Hi.
All you need is bricks and cement.
Use perforated bricks or regular 65mm bricks for the support. A light oven may be built on an U shaped support (you will need to make some structural considerations about the weight). Moreover the U shaped support on top requires an armed concrete slab adequate to support the chamber. If you are not sure about structural performance, build a solid support block of bricks.
Make sure that the support is adequate for the weight of the heavy chamber. If the oven is big, then lay basic foundations or build the oven straight on the ground.
For the chamber you must use refractory bricks (fire bricks). You have different choices of design. A common shaped that do not require armed concrete parts is the igloo style chamber. Leave space for the chimney on top of the chamber.
Mar 24, 2013 | Ovens
I am renewing the fire bricks to a Baxi Brunell open fire. What compound is used to fill between the new fire brichs and the chimney construction.
In the UK they sell small tubs of "fire cement" which is a white pre-mixed cement in a tub. I'm sure that will do the trick!
Jan 03, 2011 | Heating & Cooling
What is minimum temperature able to lay brick
well if your fingers stick to the cement its very cold? however iv layed bricks in the frost using frost profer in the cement and i coverd the bricks with sacking to keep off the frost over night,,,you cant lay them very high three rows tops in a day,,,but if you use accelerator in the cement mix it will still set before it freezes ,,,,you still build houses in winter you know? it just takes a lot longer to get them up?
Nov 28, 2010 | Garden
Inside Walls of Pool Heater are broken
u can find fire brick at stores that sell fireplaces,boilers,woodstoves or on line places such as hi temp refractories manufacture all different sizes and shapes,or can notify laars at 1800 900 9276 ext 4 they dont sell to consumers but can advise of a laars distributer near u who can order replacement brick liner
Jul 19, 2010 | Jandy Laars Lt 400,000 Btu Heater
Rayburn cookers
http://www.rayburn-web.co.uk/DirectoryList.asp?SD=Rayburn obsolete cookers/Rayburn Royal MF/
paste all that to go to the rayburn manuals download site i have seen this manual and it shows what you need
Feb 12, 2010 | Kitchen Ranges
High running costs for gas fired Rayburn central heating
these are now a redundant range parts are no longer available and a good thing too as they cost the earth to run. gas ones cost more to run than oil. try "top of the range ltd" for a solution
Dec 20, 2009 | Kitchen Ranges
Kitchen Ranges Logo
1,406 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
