Question about Acer AL1916W 19" LCD Monitor
Acer al 1916w blacking out ?
Hi was wondering how to determine my problem ? every now and then my screen will totally blackout for a second. the power light on the monitor does not go on and off or anything. this is sparatic and does not do it all the time . is the monitor on its way out ? ( only a year old ) or would it have somthing to do with the cpu tower ? thanks to anyone that can help in advance :)
  • nancyU Nov 20, 2008
    While in use, the screen blacks out and the "acer" screen saver comes on. The power indicator stays green, so I know it's still connected to the computer ok. After clicking the mouse a few times, it goes away, and I can use it again.
  • Acer Master
  • 5,568 Answers
That problem could emanate from either the video card or on-board video circuit. The best way to separate the two possibilities is by substitution; connect your monitor to another PC and a borrowed monitor you your PC.
If you can swap with a friend for a few hours, have either monitor connected to a PC that is turned off, then turn on the monitor(s) first, start the PC.  This should force Windows to 'find' the different monitor and install the appropriate driver.
When swapping back, you will need to do that again to restore the PCs to their original settings/drivers.
The problem is most likely the monitor and it sounds like a main power supply in the monitor is headed toward failure, probably due to one or more failed electrolytic capacitors like so many others in recent times.
Posted on Oct 15, 2008
    Novelist:
  • 159 Answers
Power board is starting to have capacitors fail. They will get worse !
If it were a computer signal issue your power light color would change or you would get a no signal note.
A year ! yep about that time for an overhaul based on the parts they used.
ebays
bammbammfran
search and you shall find me !
Hello My acer 1916W LCD Monitor Screen will not light up after turning my desk top Computer on.. Although the start light lights up okay My Screen stays Black. It only lasted over 6 months I am now using a...
you need to reset the bios in the computer take the littel battry out inside with the power of then wait a min or two re insert boot and c if that works
Apr 05, 2011 | Acer AL1916W 19" LCD Monitor
Everything works great except after you touch a button or something there is like a 5 second delay and the screen turns black. but lights up everytime you do something to it....
Blackout Mode On and Off
When the Blackout mode is turned on, the display will
turn off to reduce power consumption.
This additional power enhances the sound quality.
1 Press and hold the B.OUT button for at least 3
seconds to start the blackout mode. By doing so the
display will turn off.
NOTE
If any button on the unit is pressed during the blackout mode, the
function will be displayed for 5 seconds to show the operation
before returning to Blackout mode.
To cancel the blackout mode, press and hold the
B.OUT button for at least 3 seconds.
Mar 31, 2011 | Alpine CDA-9827 CD Player
How do i set the monitor so the text and icons appear clean and crisp?
go to acer website and download driver for monitor or graphics monitor. Make sure you download AL 1916W and NOT AL1916. Make sure after, you set your resolution to 1440 x 900. That should do the trick.
Feb 03, 2011 | Acer AL1916W 19" LCD Monitor
I have a 19" ACER model AL 1916W wide screen and in the middle of doing something, the screen will black out and then come back on showing the ACER logo and continues on the page I'm working on...this will...
It proably has dying DC filter caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER and other monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Aug 13, 2010 | Acer AL1916W 19" LCD Monitor
ACER Al 1916W Asd service manual
dac-19m005 power light comes on then goes off
Jan 08, 2010 | Acer Computers & Internet
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
Aug 01, 2009 | Alpine Car Audio & Video
Repairing the MB for the (Acer) AL1916 monitor
http://www.eletromaniacos.com/Downloads/Monitores/Acer/acer-AL1916v.pdf
Apr 24, 2008 | Acer AL1916W 19" LCD Monitor
Monitor screen blackout
check for any DRY SOLDER , specifically around the INVERTER TRANSFORMERS on the PC board . hope it helps
Mar 28, 2008 | Computers & Internet
Acer AL1916W 19" LCD Monitor Logo
188 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
