Question about HP Office Equipment & Supplies
Officejet 7140xi all-in-one printer is making a loud clicking noise and will not print from scanner or computer
    Problem Solver:
  • 11 Answers
An audible noise is a definite indication that you have some type of hardware malfunction (broken or misaligned part).  if you feel confident enough in your skills you can try and locate the problem yourself, however unless you have done this several hundred times before i do not recommend it.  first i would suggest that you hit the HP site and find the authorized service locations in your area, call them and find out how much they charge for out of warranty work and how much it will take to have them look at it.  then weigh is the printer worth the investment, or would it be cheaper simply to replace the defective device.  good luck.
Posted on Oct 15, 2008
Loud clicking noise on my hp printer 4500
hi, your priner complaint i 2 chance 1 is the carrage cable is damaged or 2 is printer mechanism complaint please verifing
Mar 26, 2014 | HP Officejet 4500 All-in-One -...
HP 8600 makes clicking noise takes long time to start printing
Solved!
Found a misfed page jammed inside the printer on far
right side ( by the ink service station) - after removing the
"hidden" wad, the printer no longer makes "clicking" sounds
and prints right away!
Officejet Pro 8600
Feb 18, 2013 | HP Officejet Pro 8600 Premium e-All-in-One...
Where is the battery on 7140xi
It's on the main logic pcb on the right side. You have to remove the back cover, unplug the scanner cables, remove the scanner and top cover and then the right side cover. The battery is on the circuit board on the inside side, so you have to remove the board to see it.
Oct 30, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Wont run even though i have changed the black cartridge as it requests
turn off the printer.
pull out the black ink cartridge and reseat it. make sure there is no shipping tape attached and it "click" in the carrier.
turn on the printer, close the cover.
May 22, 2009 | HP OfficeJet 7140xi All-In-One InkJet...
Won't print. makes loud clicking noise from right side front of unit (ink cartridge parking area)
Please have a look at the noise troubleshooter available for your printer at the HP online support site. Click here
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 29, 2009 | Office Equipment & Supplies
Printer problem
Mine does the same thing, it appears to be a scanner sensor that has failed. The machine starts by lighting up the scanner, then moving out of park position, then repeatedly trying to move it back into the parked position. It appears to be a sensor that is not working, and needs a part replacement.
Oct 05, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Makes noise
Click HERE for HP troubleshooting for your printer.
Jun 06, 2008 | HP Officejet 5610 All-In-One InkJet...
Officejet 7140xi print problem
Try getting the printer to re-initialize itself, also make sure that the copper contacts on the cartridge and printhead are clean.
You may be able to fix this issue by unplugging the unit while it is on and holding the # and 6 while plugging the unit back in (semi full NVM reset)
Apr 01, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Scanner failure
All over the web the concensus seems to be disassembly and cleaning bulb, mirros and/or the glass and a calibration strip. Mine has the same error, and I'm gonna try the cleaning those locations. This forum mentioned a disassembly procedure for the D145, I hope it's the same for the 7100 series (7140XI) I'll post back my success.
Dec 06, 2007 | HP OfficeJet 7140xi All-In-One InkJet...
108 people viewed this question
Ben Johnson
