Question about Coleman Heating & Cooling
Hello! Okay, my problem is with my Coleman propane forced air furnace. MobileHome-DGAA. I am getting 2 green Flashes which the diagnostic Flash codes indicates it's the 'Combustion Air Switch stuck closed', it also seems to be a hit and miss in following thru with ignition and when it does and it begins to act normal it's also a hit n miss with if I get any heat mostly it's No Heat just a lot of blowing the cold air around the house. Can u help me please? Ty very much. Susie / emkatsc_07
    New Friend:
Try turn it off of heat they back on again.
Posted on Jan 19, 2012
SOURCE:
I have a gas furnace model # 2sg13b36090p-1a green light flashing 2 times slow
Hello, Maybe this will help you some.
http://home.howstuffworks.com/how-to-repair-gas-furnaces.htm
I hope it does, Mike
Oct 26, 2011 | Coleman Propane Forced Air Heater...
My Coleman propane furnace kicks out once and a wile and flashes a 10 flash code (gas flow with no call for heat) what need to be fixed the furnace is only 1 year old.
This sounds like you have an intermittent main board problem. It may be turning on you furnace when the thermostat is not calling for heat. It also could be a short in your low voltage(thermostat wire) going to your furnace. Either way you need to have it checked. It's under a year it should still be under warranty.
Jan 23, 2011 | Coleman Propane Forced Air Heater...
Have a Evcon Coleman Furnace shows three green blinking lights but will not ignight what could be wrong
I have had the same problem with mine for the last 2 years. Remove the motor on the side of the furnace(usually held on by 3 screws) and turn the fan blades inside by hand. after sitting all summer it seems to get stuck. If it moves freely, replace the motor and try to start it again. This fixed mine the last 2 years! Hope this helped.
Sep 29, 2010 | Coleman Propane Forced Air Heater...
Coleman furnace wont fire
Check inside the door panel next to the wiring schematic, you should find the diagnostic codes. Look up 7 blinks. This should narrow down the problem. ( It sounds like a bad hot surface ignitor).
Good luck.....
Mar 31, 2009 | Coleman Propane Forced Air Heater...
Running out of LP??
Yes. The ignitor is trying to find fire and it can't. That's an ignition error. It should go away once you get fire to the sensors. You might have to hit a reset button, it all depends on the heater.
Feb 05, 2009 | Coleman Propane Forced Air Heater...
Coleman evcon Dgato7obdc
Small blower motor? Are you talking about the combustion blower if so then check your vents for blockage.. if the vents are blocked won't work... if it has a control board init it will give you a diagnostic code. Flashing light on the board... count the flashes and look up the fault on the chart in your owners manual ot on the furnace door..
Jan 13, 2009 | Coleman Propane Forced Air Heater...
Furnace shuts off
Defective combustion air switch. The 3 blinks are an error code. You didn't say, but I'm guessing you have a Coleman Evcon. They had alot of defective Combustion air switches. Your specialists were not that.
Jan 05, 2009 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
187 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Paul
Paul
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
