SIM CARD REJECTED MESSAGE ON SCREEN AFTER PUK 10 ATTEMPTS FAILED
Sim card rejected phone i was putting a password in for my phone and after that it said sim card rejected and i really need some help because i don't know what to do and how you do it so please help me
thank you :)
My sim is rejected please solve this problem
You can contact the service provider..........
SOURCE: sim card rejected
this happen if there is some problem in the sim card holder port ....
there
will be loose contact inside the sim card holder is not touching the
circuit board inside due to this your sim card is getting rejected ...
as
you have told that the phone is a brand new one so i am sure that you
will be having the warranty so just make use of it by contact the
dealer with whom you have purchased or contacting the company customer
care number to get more information about how to make use of your
warranty ......
if you dont have the warranty then you must open the handset
and
just remove the circuit board & sim card holder and insert it again
so that the sim card holder touches the circuit board correctly ...
after this refit the phone then surely your sim will be accepted ....
it is better to use of warranty if you have ......
this is a simple problem if you dont have the warranty also you can only fix it ..
if
you just open the handset & set that sim card holder to touch the
circuit board that s enough everything will be done and works fine ...
if you are afraid of opening then you must just contact the technician ...
it is just a matter of very little bucks if you contact him also ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
SOURCE: my nokia c3-oo is saying sim card rejected,tried
you can check it with other sim card ,if it remains the same problem ,it may be locked to particular network wont accept any sim card other than the particular network ,you can unlock it and used to other network,try here http://www.mobile-unlocker.com/nokia-c3/rs2wp9/
contact service provider ,they will provide you the puk codes
hi
you can call the company from another phone and fix the problem by giving them the PUK number.
i hope this will work
SOURCE: Hi I have a nokia
PUK means "personal unlocking key" .
The PUK code is asked if you enter a wrong pin 3 times.
You need to call the phone company that released the SIM card, they can retrieve the puk code from a database for free.
In your case you need to contact your SIM card provider technical support to unlock the SIM.
The PIN and PUK are related to the SIM card, not to the phone.
If you replace the SIM card with a different one, then the phone will not ask for the PUK anymore.
SOURCE: my Nokia n 72 says sim card rejected
you need to replace your SIM card now the PUK is a PERSONAL UNLOCK KEY code that changes on a daily basis and if you dont call the provider for this and enter the wrong code too many times it "burns" the sim (security feature)
