Question about HP PSC 1350 All-In-One Thermal Printer
Document locked in que
I have a document locked in the que that won't let me print. I have tried to cancel it several times as well as turning off the printer, unpluging it form the computer and so forth. I am able to delete documents behind this on but can't get rid of the first on. The que says deleting printing but has for hurs now. All other functions of the printer seem to be working.
  • 1 more comment
  • Anonymous Mar 13, 2014
    printer will que document but wont print
  • Anonymous Mar 19, 2014
    no communication between computer and printer
  • 4 Answers
Solution #1 Have you tried to power off the computer itself? The document is most likely locked in the PC not the printer. Unplug the printer's power, power down the computer, wait a minute or so then restart the computer. Once the machine has loaded check the print queue to verify the document is no longer there, if so you can plug the printer back in and the issue should be resolved.
Solution #2
From the Start menu, select Control Panel. Then follow this path:
Administrative Tools > Services > Print Spooler
Once at the Print Spooler, right click on it. Select Stop. Leave this window open. Turn off your printer.
At the open Print Spooler window, right click on the Print Spooler, and select Start.
Go to the Start menu, and select Printers & Faxes. Find the printer you are having problems with and double click on it. From the menu, select Printer, then select Cancel All Documents. The documents should clear.
Turn on your printer. You sould now be able to print.
Posted on Oct 15, 2008
How can I clear the print que? I tried to cancel printing a document, and now the que says cancelling, but won't let anything else print
1) Try to restart you system with the printer unplugged.
2) Try to Pause the printer and then delete the items in the que
3) If this doesn't help Delete the printer and re-install it.
Aug 29, 2014 | HP Photosmart C6180 All-In-One InkJet...
Won't print it always says document in queue
This sometimes happens if a print job freezes before, or during the print. I would suggest two things. Open up your print que, which you should be able to access from the bottom right hand side of your screen in your task bar. Right click, and open print que. If there is a print job in the que that says printing, try to right click on the job and cancel it. If this does not work and you have not done so already, restart your computer and your printer! Go back into the que if you have to and if the job is still there, right click and cancel job again. Then, retry printing a something different from your printer. This should solve your problem.
Sep 20, 2011 | Canon Pixma MX420 All-In-One Printer
I want to clear the que. I tried to print a page and it will not print. It has remained in que for two days. I have tried to cancel it, didnt work. I unplugged the printer and usb cable, it still did...
If you are using windows operating system than go to Printer and Faxes, Double click on the printer icon. A window with printing document que will appear, click on "Printer" and select "cancel all documents" and then switch off the printer for few minutes. the document que will disappear.
Aug 12, 2011 | Lexmark X5650 All-in-One InkJet Printer
Hp Business inkjet 1000 wont stop printing garbage - a bit on lots of paper. It ran out of black ink - now replaced - but now wont stop printing .... Have tried unplugging power and usb. turned...
You need to view the print que and cancel all prints.
Do the following:
1.) Navigate to windows control panel and double click Printers and Faxes.
2.) Now double click on your Hp Business inkjet 1000 Printer it should come up with the que.
3.) Click Printer and then click Cancel all documents. That is the Printer tab on the top left of the box.
That should cancel the documents in the print que and you printer should be able to rest now.
Till next time!
Apr 13, 2011 | HP Business Inkjet 1000 Printer
Today i was trying to print a document, but then when it came out of my printer, its not how i wanted it to be printed. So i pressed cancel on the printer itself. When i tried printing the document again,...
You must clear the que.
You should be able to download the print driver. Id try clearing the que first. do the three finger wave if necessary to find the process - terminate it - then reopen the que - see if the document is gone.
Unplug your printer - ower and signal ... go get a soda . when you get back plug the stuff back in ... remember - shut the stuff off first!
I hope this helps
Sep 23, 2009 | Office Equipment & Supplies
Printing status frozen and won't delete or print
Have you tried unpluging your printer from the computer as well as unpluging the printer from the electrical? If that doesn't work you should start from scratch... that is remove the printer from the computer memory, delete it, turn off the computer, turn on the computer and go through the installation process as if you just purchased the printer. Barring any mechanical problems as in jams or the such, the printer should return to operational status.
Oct 07, 2008 | HP DeskJet 5150 InkJet Printer
Problems with print runs
Turn off the printer.
Go into the print que and cancel all pending documents.
Sep 24, 2008 | HP LaserJet 4700N Printer
HP PSC 1350 All-In-One Thermal Printer Logo
231 people viewed this question
Ben Johnson
