We have a coleman evcon furnace. The furnace runs constantly. It'll get to the temperature but then the fan doesn't quit and it only blows out cool air the the reset switch pops up and needs to be be reset before it'll blow out warm air again.
  • Anonymous Dec 16, 2008
    The fan runs continuously and does not appear to have a reset button.
It sounds as if your furnace is exceeding the limit tempperature of the manual reset switch. The coleman is designed for the fan to continually run when this limit switch is tripped in order to keep the heat exchanger cool.( it is a safety feature) afew things may be happening.
1. the manual limit switch( the one you have to push) may be defective.
2. The fan may be running at too low of a speed. Turn power off at circuit breaker. locate circuit board on the board there will be one terminal that says heat if the red wire from the blower is on it tthen you may need to up the speed. follow the wires from the blower to the board if it has multiple speeds then you can isolate the red and put the blue or orange on the heat terminal.
3. the board may have an adjustable fan on and fan off pin selector if it is set up to come on to long or go off to soon it may not be controlling the temp of the heat exchanger properly.
4. I would also suggest checking to see if the orifices and gas valve are set up for your sytem correctly.
these are just simple ideas let me know how things go.
Posted on Oct 15, 2008
I have a Coleman Evcon electric furnace, the blower fan runs constantly and I have to shut the breaker off inside the front cover to turn it off. The switch is on auto and it runs even when the thermostat...
It could be a thermostat problem. Also it will seem to run constantly as it tries to heat and one of the elements are working which could be a sequencer problem.
Nov 28, 2013 | Heating & Cooling
Coleman Evcon furnace. Can i make it circulate air?
Your thermostat should have a "continuous blower" setting. Use that instead of fooling around with the A/C setting
Jul 17, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Heating sequence failure.
check for flashing trouble codes on mother board
Oct 27, 2017 | Heating & Cooling
Draft blower stays on all the time on my Colman Evcon that is in my mobile home.What could I check for, any sensors? Furnace runs fine otherwise.
there is a temperature sensor in the fire box that keeps the blower going til it cools down after the burner shuts off, could be faulty and keeping the fan on
Feb 14, 2011 | Tools & Hardware - Others
I have a coleman evcon gas furnace in a 95 trailer the draft fan stays on until you tap on furnace
Most Coleman units in a trailer dont have a draft fan. Are you talking about the fan that blows air through the floor registers? If yes, then you will probably need a new fan/limit control. If you do have a draft motor, you would probably need a new circuit board or draft fan relay.
Jan 02, 2010 | Coleman Propane Forced Air Heater...
Draft fan keeps on running after furnace shuts
That sounds pretty normal for most furnace/heater products. They run the heating element with fan for a cycle then after the heater reaches temperature it will shut off and the fan will continue to run to cool the element and to circulate the heat that it produced. If you want the manual for this product it looks like you can get it here: http://homeappliance.manualsonline.com/ex/product/headline/m/Coleman%2BEvcon/d/furnace/p/DGATO75BDC
Oct 26, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Air conditioning runs all the time
I assume this is a manufactured home, this is probably a two transformer system, either your contactor is welded in the on positon or wyou have control wiring issues, (could be the thermostat)
Jul 12, 2009 | Coleman Heating & Cooling
I have an coleman evcon furnace when i turn a/c on the outside unit will run but the inside wont run
put the just the fan on turn off the ac and the heat and just fan on make sure the blower motor works cause thats really the only thing you utilize from the furnace in the summer and let me know
then if so does your heat work fine
May 30, 2008 | Heating & Cooling
Heating & Cooling Logo
325 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
