Konica 2223 J72 alarm
I have a Konica 2223 with a J72 alarm sorter jam would anyone know what the likely part would be? It doesnt seem like the paper sensor but I dont have one to swap out. I guess if you know what the most likly solutions would be or even which parts to order that would be very helpful?
Thanks,
Hospital worker
  • 145 Answers
ST216, J72.
Solution:
PROBABLE CAUSES:
1. Paper is caught on the flapper assembly (p/n 12TK-4510). The indexer is not adjusted high enough to have the flapper correctly positioned. This symptom usually occurs after the last copy enters the top bin. To properly adjust the indexer position, perform the following:
a. Power copier OFF.
b. Remove the front and rear covers.
c. On the sorter CB, set dipswitches SW1-1, SW1-2 and SW1-3 to the ON position.
d. Ensure both sorter interlocks are closed (PS208 and MS201).
e. On the sorter CB, press and hold PSW1 while powering ON the main body (code 70-00 will occur; this is normal).
f. Release PSW1, then press and release it one time. The indexer will lower to the adjustment position (approximately at the 4th bin).
g. Open the conveyance section.
h. Insert the indexer positioning shaft adjustment tool (p/n 7050K0020) into the access hole on the rear side frame of the sorter. The hole is located to the right of the conveyance door interlock switch (MS201). The shaft should be positioned under the indexer and into another hole in the front side frame.
Note: The indexer positioning tool is the same tool used for optics alignment on the 7050.
i. Rotate the indexer motor encoder plate to lower the indexer until it contacts the adjustment shaft.
j. Loosen the fixed screw located on the front side of the indexer.
k. Slide the front of the indexer up or down until it is positioned parallel with the adjustment shaft. Retighten the indexer fixing screw.
l. Loosen the screw that secures the PS203 4-slot encoder plate and adjust the 4-slot encoder plate until LED 1 is lit. Retighten the encoder plate.
Note: Either or both interlock sensor/switch (PS208/MS201) must be opened during this adjustment.
m. Remove the indexer positioning shaft and reset all 3 SW1 switches to the OFF position.
n. Power copier OFF/ON to return to the normal mode.
2. The sorter top front frame is slightly bent and not parallel with the rear top frame. This, in turn, allows the top cover to be out of position and bind the flapper gate (p/n 12TK-4510). This gate should normally open when the indexer lowers to bin 2, allowing the paper to enter the bins.
Reform the sorter top frame so the top cover, when mounted, does not bind the movement of the flapper gate.
3. Mylar guides are installed on the exit unit of the main body.
Remove the mylar exit guides when a sorter is installed. The guides help eliminate static when paper exits into the catch tray. When a sorter is installed, the guides can cause exit misfeeding.
4. The flag for the sorter entrance sensor (PS201) is stuck on the guide plate below the sensor. This happens when the top of the sorter is lifted as it is moved away from the copier.
Lift the top of the sorter and place the flag back into its proper position. Instruct the operators not to lift the top of the sorter when it is moved.
HOPE THAT HELP
THIS IS ONLY FOR ST216 MODEL SORTER
Posted on Oct 17, 2008
What may be the problem for the jam code J72-22
paper weight incorrect setting. bad sensor or acturator is broken
May 18, 2016 | Konica Minolta bizhub Pro 1050 Corona Wire...
Toner Level Sensor konica 2223
what about the toner level sensor for the Konica 2223????
Jun 25, 2014 | Konica Minolta Minolta 2223 Laser Printer...
When i switch on my photocopier tohiba 2860, it asks for service and gives an error code 08221-918100. what could be the problem?
Hi tkasirye,
Welcome to Fixya.
You may need to check again the error code. According to the manufacturer's checklist for error codes, only the following are documented;
  1. Error Codes - Toshiba 2860
  1. "E01" Paper jam inside machine. "E02" Paper jam near the fuser. "E03" Paper jammed inside machine when power supply is switched on. "E04" Front cover open while copying. "E05" Paper jam near the aligning roller "E08" Paper jam at stacking area in the ADU "E11" Paper feeding jam at the ADU "E12" Manual feeding jam "E13" Paper jam from cassette 1 "E14" Paper jam from cassette 2 "E15" Paper jam from cassette 3 "E16" Paper jam from cassette 4 "E17" Paper jam from cassette 5 "E19" Paper jam from the LCF "E21" Paper jam in transport route 1 (LCF) "E22" Paper jam in transport route 2 (COPIER) "E23" Paper jam in transport route 3 (ALIGNING) "E25" Paper jam in transport route 4 (PFP) "E71" Original feed jam in ADF "E72" Original transporting jam in ADF "E73" Original exiting jam in ADF "E75" 2nd original feeding jam "E81" Paper jam before sorter "E82" Paper jam in sorter "E83" Sorter early arrival jam "E84" Paper in sorter when power is turned on "E85" Joint open jam while copying "E88" Paper jam outside the sorter bin "C01" Abnormal operation of the copier main motor "C04" Abnormal operation of the PFP main motor "C05" Abnormal operation of the ADU main motor "C11" Abnormal operation of the ADU side motor "C12" Abnormal operation of the ADU end motor "C13" Abnormal operation of the upper cassette tray "C14" Abnormal operation of the lower cassette tray "C15" Abnormal operation of the PFP upper cassette tray "C16" Abnormal operation of the PFP middle cassette tray "C17" Abnormal operation of the PFP lower cassette tray "C18" Abnormal operation of the LCF tray "C21" Optics carriage initialize error "C22" Lens initialize error "C23" Mirror initialize error "C26" Faulty exposure lamp "C33" Easy set-up is failed "C35" Developer material exists at the transfer separation adjustment "C41" Faulty thermistor or heater "C43" Faulty thermistor "C44" Faulty heater "C45" Sub thermistor is open
Shoulg you not find any of these mentioned error codes, I suggest you contact the tech support especially if the machine is still under warranty.
Hope this helps.
Takasashi
Jul 05, 2011 | Toshiba Office Equipment & Supplies
Malfunction Detected code C-12CB konica Minolta
Hi bellotasuelt,
I can't find any reference to that code in the Bizhub C250 Service Maunual.
Having said that, all C-11xx codes relate to the finisher/sorter.
Try opening and closing it. Have a general look in the finisher for jammed paper.
Make sure nothing is obstructing the unit from moving.
Sorry I can't be more specific.
Good luck.
Dec 28, 2009 | Konica Minolta bizhub C250 All-In-One...
Trouble getting ''copy'' from copier to sorter. gets stuck in btwn
Clean the exit parts rollers,lever and the sorter roller and bins.
Nov 23, 2009 | Office Equipment & Supplies
Sharp SF 2030 check sorter problem
follow the small holes on the sorter trays to the bottom and top there you will find the sensors that tell the copier that ther is paper in the trays make sure that they are clean and ther is no obstruction
Mar 24, 2009 | Sharp SF 2020 Copier
Frequent paper jams with my Konica 2223 photocopier
I wish I could help you, You need to call for service for your copier. An authorized dealer or Konica minolta branch service in your area. You might need a fuser unit that the upper separating claws disloge or broken, exit paper detect actuator is broken or disloged, or you need a new developer.
Feb 05, 2009 | Konica Minolta DiALTA Di200 Copier
I have a Konica 2223 copier - wont print on edges
check all edge settings .f28 is code for charger corona just clean corona assembly with cerosene oil and change corona wire with new one.
Dec 16, 2008 | Office Equipment & Supplies
PAPER FEED
you can disconnect the sorter.if that's all you need
Oct 16, 2008 | Minolta EP1083 CS/PRO Copier
Jammed paper at the Sorter Unit
Do you get a paper jam or is the finsher not showing that is empty? You may have a broken bin or a miss alined bin or you have a lazy sensor flag. The copier should give you a idea where the paper jam is... May need more info. on this one..
Jun 06, 2008 | Canon NP 6050 Copier
126 people viewed this question
jasbo
jasbo
