Question about Sansui HDLCD-2600 26 in. LCD Television
NO SOUND FROM DVD
I ALSO HAVE A SANSUI HDLCD-2600 TV HOOKED UP TO A IWDVD-100 DVD PLAYER. WHEN I PLAY A DVD I GET NO SOUND. AT FIRST I WOULD GET BACKGROUND SOUND BUT NO SOUND OF THE ACTORS WHEN THEY SPEAK. NOW NO SOUND AT ALL.
  • icarvesigns Oct 23, 2008
    I was able to figure out that the speaker switch on the DVD unit must be set to "A". Now I only have sound coming from left front and right rear speakers.
    Scholar:
  • 135 Answers
Hi. It is possible that your DVD Player's sound is set to prologic or surround and not stereo. If you use audio out from the DVD Player straight to TV then your setting on output should be set to Stereo.
Hope this helps. Regards, JUS004
Posted on Sep 02, 2014
  • Sansui Master
  • 520 Answers
Try different sound settings in the dvd menu.
Posted on Oct 22, 2008
Cant program rca universal remote to a sansui tv
Unless the designated codes are mentioned for Sansui TV , it might not match. If with an auto selection mode , check to scan to self detect.
If not the model is out of the frequency range available.
Sep 25, 2010 | Sansui HDLCD-2600 26 in. LCD Television
PIP ON SANSUI LCD TV
Lets start at connections. What is your cable source? Do you have a converter or cable box connected to your TV?
YES : You must have two connections, so you will need to run a second coax cable from the wall. This can be a $10 fix and a 15 min hook up. (Ask if needed). You will also have to be using your TV through caox inputs (TV Source on TV)
NO: You will need a second line ran and hooked up to your TV input. (Ask If need specific hookup on model)
Feb 23, 2009 | Sansui HDLCD-2600 26 in. LCD Television
New Sansui cuts off tops of heads
Check the remote for a button labeled "aspect" or "zoom" or "format".
Feb 09, 2009 | Sansui HDLCD-2600 26 in. LCD Television
I have a Sansui HDLCDVD260, 26in Television that I can't get the monitor to work on. TV works fine, DVD player works fine but when I hook up the SVGA cable to use as a computer monitor it just shows a...
After you have set the refresh rate to 60hz and the display mode to the recomended setting, shut down the computer. Turn on the tv and select the pc input on the tv. Connect the computer to the tv and then power up the computer.
Dec 25, 2008 | Sansui HDLCDVD260 26 in. LCD Television
Speakers on the tv vibrate and it distorts the sound
The speakers on the Sansui aren't very good. Its better to buy a surround sound speaker system to compliment your tv.
Dec 08, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Sansui 26 HDLCD DVD Audio DVI/HDMI
Does Sansui HDLCD 19WB have a HDMI outlet
Oct 18, 2008 | Sansui HDLCD-2600 26 in. LCD Television
SANSUI HDLCD2600 TV W/DIGITAL TUNER
This is likely your DVD player, not the tv.
First go into the setup menu of your DVD player and make sure "subtitles" are turned off.
Next, put a DVD into the player and when it gets to the menu, go into the audio setup.
If subtitles are turned on, turn them off. If subtitles are turned off, turn them on and exit the menu, then go back into the menu and turn them off again. I've seen this reset this same problem on some DVD players.
May 06, 2008 | Sansui HDLCD-2600 26 in. LCD Television
No audio for my 26" sansui hdlcd
use a cable box and external speakers they sound better anyway.
the circuit for your tv is not available yet.
Mar 01, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Hooking up the RT 2600
connect all the devices into the receiver inputs then there should be 1 set of outputs to the tv. This is to play everything using surround sound as all the video and audio is going through your recevier... if you want to do HD and have surround sound you will need a new receiver as this one has no hdmi inputs or outputs.
Feb 26, 2008 | RCA RT2350 System
Sansui HDLCD-2600 26 in. LCD Television Logo
252 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
