Question about Hotpoint Refrigerators
ICE MAKER OF MODEL HSS25GFTAWW NOT FUNCTIONING WITH NEWLY INSTALLED MAIN BOARD WR55X10552
THE SUBJECT SIDE BY SIDE REFRIGERATOR WAS PLUGGED INTO A 220V POWER THAT IS WHY A NEW MAIN BOARD WAS INSTALLED.THE ICE MAKER WAS STILL FUNCTIONING FOR SOMETIME EVEN AFTER IT WAS PLUGGED BUT EVENTUALLY OFF.WE THOUGHT THAT WITH THE NEW MAIN BOARD IT WILL FUNCTION BUT IT'S NOT?
catriver
  • 878 Answers
SOURCE: Ice and water on bottom of freezer
sjlobo, sounds like your defrost drain pan is frozen over or has some gunk in it. When the unit goes into defrost the water is running onto the freezer floor and out the front. Remove the lower bin and check the drain hole. You may have to remove the freezer back panel. If you can, just use some very hot water and some sort of baster to unfreeze the drain. Check this first, Catriver..post back.
Posted on May 06, 2007
fridgetech
  • 473 Answers
SOURCE: Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Posted on Oct 05, 2007
fridgetech
  • 473 Answers
SOURCE: Items sometimes freeze on refrigerator side of unit - model GSS25LGMA
It is most likely a bad damper motor.  This is where the cool air comes out into the fridge section.  On this model it is a fairly common problem and comes a whole assembly.  The part # is WR49X10091 and will cost anywhere from $100 to $122.  Knowing this model I would bet this is your problem.  If the damper is bad and stuck open cold air will just keep blowing in.  It is suppose to open and close based on the temp setting.  Let me know if you have any other questions.
Posted on Oct 11, 2007
the dr
  • 447 Answers
SOURCE: How to install a frigidare ice maker IM115.
the wires should be behind a cap that covers the hole for the water tube on the pack panel in the freezer.
Posted on Nov 19, 2007
  • 1462 Answers
SOURCE: re: Kenmore Top Freezer formed ice, main refrigerator area is not cooling
not easy to diagnose. the basic fault is that the defrost system has packed up.
check that there is continuity thro the defrost heater. there may also be a thermal fuse in series with the heater so check that also.
if those ok, then points to a fault in the main module
Posted on Jun 22, 2008
Everything is working but the electronics went out in it. Can't use ice maker although it's making ice, can't use any functions. Can't read tempetures
Newer refrigerators have a main mother board (computer board) that all parts and functions are channeled through. I have seen your problem happen with a defective mother board but it could be something else. Not even sure you have a mother board without a brand and model number.
Jun 28, 2015 | Refrigerators
PSS26LSRD
Apazm1, unfortunately your main control board is the culprit for your woes. The part number is WR55X10552 and retails for ~$115.00. There's good news, though! It's readily available, (all the appliance parts retailers have them) AND they are easy to install. After you have the new part in hand, open the box and read the instructions CAREFULLY. These boards have been modified from the original OEM's and work on all fridges like yours. UNPLUG YOUR FRIDGE! Pull it away from the wall, locate the aluminum panel that covers the computer and remove it (4 screws). The board is held in place by 4 white clip tabs. They poke through the board at (roughly) the 4 corners of it. Look closely at these with a flashlight... you'll see where you need to squeeze them with a pair of needle nose pliers to release them (squeeze the clip and pull that area of the board at the same time). Then remove all the connectors from the board. Now snap the new board into place and reconnect all the wires. This is where you need to pay attention to the instruction sheet! Look out for that white "jumper" in "pin #2"... if you don't get this right your fridge won't work right. Here's the reason I know it's the main board and not the board behind the dispenser area... the dispenser board is low voltage, the main board is high voltage. The dispenser board only sends a signal to the main board. From there, the main translates this input into a high voltage command for the component you have selected (water, ice crushed, cubed, etc...) The components that aren't working on your fridge are high (120) voltage parts controlled by the main board... ergo, failed main board. Hope this helps! Let us know how it goes, will ya?
Aug 22, 2007 | GE Profile PSW26P Stainless Steel Side by...
Samsung model rs2530BWP cubed ice icon is blinking what does that mean
mine was doing this, i replaced the main board and power supply, it was still doing. i checked all the sensors and still didnt fix the problem, i then looked at the ice maker, there is a sensor on the ice maker that has two white wires off it, i used a jumper wire and touched them together at the plug in the freezer and it started working like it should, now i have to order a new sensor from what i can tell. part number DA97-00258E to replace the ice maker.
Oct 12, 2012 | Samsung RS2530BWP (25 cu ft) Side by Side...
Gene i need thi installation instrutions for a main board GE refrigerator WR55X10552 please
please send me your e-mail address so that i may send you the installation instructions.
Oct 21, 2010 | Refrigerators
GE Side By Side not cooling on refridgerator side.
Look on the back panel inside the freezer for ice beginning to show. Most times when this happens the fresh food section is the first to notice. Your refrigerator has a control board on the back. If not defrosting the air flow to the fresh food section is greatly reduced. Let me know, Sea Breeze
Jul 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Electronics on the blink
there is a circuit board in the back right side embedded in the unit has about 6 screws holding a cover plate this ill need replaced part # WR55x10552 you can look it up at www.apdepot.com
Aug 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool icemaker
your refrigerator relies on a emitter and receiver control board to tell it when to turn on and off. this could be the problem. the guy at fixitnow.com sums it up best
  • What are the manufacturers thinking when they put out this overblown garbage? It’s as though they had a bunch of electrical engineers sitting around one day and said, “Oh, I know! Let’s design an icemaker that uses a bunch of flimsy, expensive electronics to replace a function that could be done more reliably and less expensively by a simple mechanical feeler arm!” Brilliant.
http://applianceguru.com/forum1/10111.html
this site has some good info on the subject of diagnosing these boards.
Jul 16, 2008 | Whirlpool ED2FHEXN Side by Side...
GSS22jerfww ice dispencer?
Main Ctrl board bad WR55X10552 is the part you need the board has a short it is on the back wall of the unit I will bet when you press it in the compresser turns off as well !!!
May 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer fan noise
What you need is a new updated computer main board. Thay are fairly cheap and easy to install. My GE Side By Side did the same thing and the new motherboard worked like a charm. I think that this is the one you need but you can email the seller with your model number and he will tell you which one to get WR55X10552 GE Refrigerator Mother Board fits WR55X10335s.gif GOOD LUCK
Jan 11, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Refrigerators Logo
69 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
