Question about Samsung YP-U3 MP3 Player
Unable to connect mp3 player to pc
Wen i plug in mp3 it says connecting then it says disconnecting
  • sunydee Oct 15, 2008
    cant connect
  • 54 Answers
U uninstall the mp3 program and again u install it and try
Posted on Oct 15, 2008
Wen i connect my i pod to computer it does not connect
Check to see whether your iPod shuffle is the original stick version or the newer version, which plugs into the iPod dock connector.
Turn your PC on.
The PC needs to be on to transfer music and charge the iPod shuffle.
Place the iPod shuffle in the iPod dock connector if you have the newer version.
If you're using the original version, then plug it directly into a high-power USB port on your PC.
Check the monitor to ensure iTunes has loaded.
This means a connection was established.
hope this helps
Oct 11, 2012 | Apple iPod shuffle MP3 Player
I erased all the songs from this mp3 play to put new ones on after erasing the songs the play won't be picked up by pc and am unable to put new songs onto mp3 plaey the players just displays please wait...
yes...unplug from pc shut mp3 off for a minute...plug it to pc (did it come on turn it on)...please get into the habit of disconnecting any usb connection with the safety disconnect...(green icon in task bar when usb is connected)...since you already deleted all files (format it now) start fresh...now you are able to put your songs on it...but to disconnect do not....do not just unplug the usb
Jun 20, 2010 | RCA M2000 MP3 Player
The mp3 is getting connected to the pc.but its not opening itno a folder..n wen i switch on the button ..its not working..basically its not working at all
WAIT A WHILE, THIS HAPPENS IF THE BATTERY IS COMPLETELY DRAINED. LET IT CHARGE A WHILE. OTHERWISE CHECK THE CABLE, IT MAY HAVE A PROBLEM. I HOPE THIS SOLVES THE PROBLEM
May 15, 2010 | Creative Labs Zen Stone Plus MP3 Player
Craig mp4 player duz not stay on wen unpluged
Sounds like either you battery is low or defective or your device is set on a very fast sleep mode. The screen goes blank because it is set to go to sleep after 1 second. Go to menu and look for settings for the sleep mode
Sep 14, 2009 | Audio Players & Recorders
WHEN I CONNECT TO PC MY APPLE IPOD HANG UP
Reconnect ipod to pc..After ipod says connected in computer remove hardware click on ipod..wen says safe to remove hard ware look on ipod to it saying disconnecting..Afetr full disconnecting push and hold pause/play button down for more than 5to 10 seconds..Should work properly..
Apr 04, 2009 | Apple iPod MA446LL/A MP3 Player
MY ipod nano 4GB silver has a white sreen and i cant see anything
my friend bought me a ipod for me ... it works nicely for nearly nine months but suddenly wen i connected my ipod with my handsfree everything was fine but all content was lost that i stored in ipod so i doubtly connected to my pc ..it shows everything that wat all previously stored in ipod even i can play but wen i disconnected my ipod again it shows no music no videos and no photos but the space was occupied .....
Jan 20, 2009 | Apple iPod nano
Need help
Uninstall all Philips software.
Then, re-Install the CD that came with player.
Then plug in the mp3 player to pc.
Try again.
If no go, try every usb port on pc.
If still no go, then:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Oct 30, 2008 | Philips GoGear HDD1830 MP3 Player
Philips go gear
Make sure you run the installation CD, or grab the software from the Philips website - this device will not work properly if Philips Device Plug-In is not installed. Does Windows Media Player 10 recognize the GoGear? If so, then the absence of a drive letter will not be a huge problem. If not, restart the computer and try one more time. A word to the wise - running this GoGear on a PC running Windows Media Player 11 will cause irreversible damage to the player. If you have Windows Media Player 11, rollback to WMP 10 - instructions are on the Philips and Microsoft websites.
If all else fails, try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Jun 10, 2008 | Philips GoGear HDD1830 MP3 Player
My mp3 is not being rcognised by pc
Solution:
1)Recovery mode - to get PC to recognize player -
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
2) To prevent future occurrences - make sure you have downloaded the installation CD or software - open Philips Device Manager (Start --> All Programs --> Philips D) - click on Update - twice - the player will upgrade to the latest firmware
-Tha Mp3 Doctor
May 25, 2008 | Philips GoGear SA6044/02 MP3 Player
Why is it not finding it
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Oct 05, 2007 | iLO (2 GB) MP3 Player
Samsung YP-U3 MP3 Player Logo
64 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
