My wireless connection keeps on disconnecting every few minutes - i have repaired the connection and ran the windows configuration zero and still disconnects - I think there is something with the bt home hub - what should i do?
  • kirstymearns Oct 15, 2008
    there is another wireless computer connected 2 it - and when i get disconnected so does the other computers connection - also when i take my laptop round to my boyfriends house and use his internet connection it works fine
  • 1,879 Answers
Check for Interference first
to identify if it is the BT Home hub, get another wireless computer and connect it
Posted on Oct 15, 2008
  • monk3ybidzness
    monk3ybidzness Oct 15, 2008
    nice - cut's the troubleshooting
    if the computer's report "wireless connection" disconnection - not a browser error "cannot find page" , try upgrading / re-flashing the firmware.
    BT's kind enough to provide this here
D link adapter losing signal
Wireless Zero Configuration is a Windows service on Windows XP and Windows Server 2003 that is used to configure and manage wireless network connections on a wireless adapter. The service name for Wireless Zero Configuration is WZCSVC. On Windows XP, the display name for the WZCSVC service is Wireless Zero Configuration. On Windows Server 2003, the display name for the WZCSVC service is Wireless Configuration.
The Wireless Zero Configuration service is normally started at boot time. The programming interface for the Wireless Zero Configuration service can be used only if the Wireless Zero Configuration service has been started. If the Wireless Zero Configuration service is not started, then the Wireless Zero Configuration functions will return an error.
To enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
The Wireless Zero Configuration can also be started and stopped from a command prompt. To start the Wireless Zero Configuration, run the following command:
net start wzcsvc
To stop the Wireless Zero Configuration, run the following command:
net stop wzcsvc
Apr 10, 2013 | D-Link Computers & Internet
My Belkin USB 10/100 Ethernet adapter is detecting as a buetooth device when I connect to my laptop... I am using Windows XP as an operating system. I guess WIDCOMM in windows is causing that...
Wireless Zero configuration is a utility that connects your computer to a wireless network.
If Wireless Zero configuration is not enabled, the following message will appear: "Windows cannot configure this wireless connection."
Note: If you have the Belkin utility installed, you'll need to change the Program Choice in the Options tab so the Windows XP Utility is selected.
Setup steps:
  1. Go to the XP Start menu and select Control Panel.
  2. Change the view to Classic View.
  3. Double-click Administrative Tools.
  4. Double-click Services.
  5. Find Wireless Zero Configuration within the Services list.
  6. Right-click Windows Zero Configuration and select Properties.
  7. Select Automatic from the drop-down menu next to Startup type.
  8. Click Apply and restart your computer.
Jun 06, 2011 | Belkin Ethernet Adapter F5D5050 Network...
I have a acer 6930 that keeps losing wireless connection when everything else in the house is still working
Configure Windows to manage your wireless network by right-clicking the wireless network icon and select view avalable networks... then click change advance settings... then click the wireless tab... If you don't see a wireless tab, then close it and click start then run and type service.msc and press ok. doublde-click the wireless zero configuration and set it to automatic then click start to start the service. then do the first few instructions until you see the wireless tab. Bullet-mark the "Let windows manage wireless network" then click apply or ok.
Try to reconnect to your wireless network and you should be able to maintain your connections wirelessly.
Jun 09, 2010 | Acer Aspire 6930-6771 Laptop
I am trying to connect to a wireless router. I
possibly, you could try and disable the acer connection tool and try and use the windows wireless zero configuration
Nov 03, 2009 | Acer Aspire 5315 Notebook
My wi-fi keeps randomly disconnecting but is not bc a weak signal
Your card is ok. There is interference between the router and your computer.
1. The router or the PC may be "hidden" behind a metal cabinet, refrigerator, etc.
2. Move router higher
3. Microwave ovens and some cordless phones (not cellphones) that use 2.4GHz will interfere with the 2.4GHz WiFi signal.
4. Point the router antennas in-line with the direction of the PC.
5. Move the router closer to the PC.
Oct 06, 2009 | HP (319468-002) (319468002) 802.11b...
How to fix intermittent wireless signal with Dell Inspiron 1501
It's the Wireless Zero Configuration service that's doing it. Every 10 minutes or so, the WZC service goes out and tries to look for wireless networks. During this time, it can sometimes disconnect from your wireless network. Usually its brief, merely a few seconds, but long enough to kick you out of games, messaging clients, etc.
There is no easy way to resolve this other than stopping the WZC service after startup and successful connection to your wireless. Unfortunately, if you disable this service altogether, your computer will never connect to any wireless and when looking at the Wireless networks list, it'll mention the WZC service is disabled.
You will also need to re-enable this service everytime you take your PC to places where you'll be connecting to other wireless networks. To stop this service, follow these steps:
  1. Go to Start -> Run -> and type "services.msc" (without quotes)
  2. Scroll to the very bottom of the list
  3. Right click on the Wireless Zero Configuration and choose stop
Once it stops, continue working with your wireless network. If you no longer have disconnection problems every 10 minutes roughly, you've solved your problem. Repeat the above steps after every reboot as the service will be re-enabled after the computer restarts.
Mar 05, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
My WZC (windows zero configuration) keeps getting turned off
Open Control Panel
Right click on Wireless Network Connections and select properties
The Properties window should open, click on the Wireless Networks tab
Put a check in the box for "Use Windows to configure my wireless network settings"
Click Ok
Sep 28, 2008 | Intel PRO/Wireless 2200BG 802.11g/b
Windows zero configuration
Uninstall the software, keep the wireless card disconnected, restart the computer, reinstall the software, install the wireless card.
Aug 10, 2008 | ParkerVision Signal Max USB1500 1 Mile USB...
Actiontec GT704-WG wireless connection not working
you say it suddenly stopped working, if you can connect to the router via ethernet cable then try to access the router's web utility page and make sure your router is in mixed or G-only. If you can't still connect to the router through wireless then try restarting the Wireless Zero Configuration from windows. This is how it's made: Go to control panel and double-click "administrative tools", then double-click "services". You will see a list, scroll down to Wireless Zero Configuration and click "stop", you'll see a progress bar. After that click "start", you'll see another progress bar. Now try connecting to your router via wireless connection. If you still can't connect then repair the connection by right-clicking the wireless icon at the bottom right corner. Keep repairing until you connect.
Hope this works!
Feb 16, 2008 | Actiontec GT704WG Wireless Router...
Belkin f5d7132uk keeps disconnecting
have you tried turning off Wireless Zero Configuration
Go to Start | Control Panel | Administrative Tools | Services
Scroll down to Wireless Zero Configuration, right clicking properties, and Stopping the service in Service Status.
Do this on all the Pcs,
If this solves the problem, turn off Wireless Zero Configuration permanently by changing Startup type to Disabled
Dec 09, 2007 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
