Question about Sony Cyber-shot DSC-W30 Digital Camera
The USB connection is not initiating
Screen reads USB mode connecting and lower selection says switch on Menu. I've tried all settings and have generated no results. I am unable to download my photos on either the PC or the laptop. So the problem lies in the camera.
  • 2 more comments
  • Azwaverider Oct 15, 2008
    Sorry, I didn't ask "how to do it" that would be a waste of time, that info is in the manual.
    There is a problem with the camera, as stated.
  • BCHIURLIZA53 Oct 27, 2008
    HELP ..... HELP... HELP....
  • Anonymous Nov 06, 2008
    I have the same problem, and it just started happening today. =\
  • adriaana Dec 07, 2008
    screen reads USB mode connecting and lower selection says switch on Menu. I've tried all settings and have generated no results. I am unable to download my photos on either the PC or the laptop. So the problem lies in the camera. A memory card reader is an option, but i dont have one now. How do I fix the problem on my camera?
    Filmmaker:
    Uploaded 5 video answers.
  • 41 Answers
There is 2 ways to transfer/download pics from cam to pc (i) the USB connection and (ii) by memory card all you ned is to get the memory stick of your cam and attach it to a card reader and your card reader to a USB port of your PC that way you can download pics from your cam to PC. if still cant understand check this video...
i hope i was able to help you with your problem. gud luk!
Posted on Oct 15, 2008
I have a DSC-S85.It came with a disc for MGI photo suite 8.1 I down load it to the pc which has a vista program but I can get the pictures on my pc
Posted on Oct 17, 2008
My sansa m230 driver mp3 player is not detected as removalble disk i mean as a flash drive on my laptop how can i fix this issue
When you're able to change USB mode in the display:
- From the Main Menu, select Settings > USB
- Select in "Auto Detect", "MTP" or "MSC": choose MSC for viewing the player as a removable disk.
When you cannot select MSC mode in the player's menu, force MSC mode with the player switches/buttons:
1. Turn device OFF.
2. Facing the hold switch: slide it to the right so an orange color would show, putting the device on Hold.
3. Connect the device to the PC with the provided USB cable.
note
In MSC mode: Before disconnecting the USB cable always go through the safely remove hardware icon in the lower screen of your computer on the right. Left click the icon to see all removable disks and left click on the removable disk drive letter of the player to disconnect: after the message you can take out the USB cable.
Jul 03, 2010 | SanDisk Audio Players & Recorders
Keeps turning off
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS ALSO >>>>> Check the Device Manager 1. Right-click My Computer, and select -- > Manage. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. *** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-- Copy this address into a new window. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Mar 05, 2010 | SanDisk Sansa Fuze MP3 Player
Sandisk Fuze 4GB locked lights on will not do anything what do I do ?
Mar 05, 2010 | SanDisk Sansa e260 MP3 Player
I don't know how to reset my Sandick Sansa e260 4g?
Mar 05, 2010 | SanDisk Sansa e250 MP3 Player
Fuse is completely frozen. no functions work. will not turn off, screen says "disconnected" . just charged it.
Feb 27, 2010 | SanDisk Sansa Fuse MP3 Player
It is stuck on the disconnected screen and it won't turn off or on. It had been charging and when i took it off, it is frozen. It is a new laptop with norton antivirus. So I don't understand.......
Feb 26, 2010 | SanDisk Sansa Fuze MP3 Player
My sansa won't turn on
Feb 23, 2010 | SanDisk Sansa e250 MP3 Player
On my mp3 i had washed it on accident but the battery was dead when i did i tried to plug it into the computer it did nothing; i dried it it finally worked with my computer reading it and all; i instantly...
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS FIRST >>>>>
Feb 23, 2010 | SanDisk Sansa E280 MP3 Player
My MP3 player is frozen and it dosent show up on the computer?
Reset the player:
Then try this
Solve your MP3 Player Connection Problem.
Refresh the drivers
Feb 22, 2010 | SanDisk Sansa e250 MP3 Player
My mp3 was on but now it won't come back on or charge.
Reset the player:
Then try this
- If the player does not turn on try other USB ports2_bing.gif or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub2_bing.gif.
If you receive the error "USB Device2_bing.gif Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
MTP mode is the recommended and default method for Sansa Players when used with Windows OS2_bing.gif.
Refresh the drivers
Feb 21, 2010 | SanDisk Sansa Clip MP3 Player
Sony Cyber-shot DSC-W30 Digital Camera Logo
155 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
