Question about HP Computers & Internet
Printer is hooked up but will not print, or scan my disk to add my printer is broken how do I print. I have unplugged and restarted printer but will not work.
    Master:
  • 538 Answers
Hmm..what does the front panel show?
Posted on Oct 15, 2008
Izaakzakei cant get my printer connected to my laptop i have downloaded the driver but its still not working
You need to install the softeware first with the printer unplugged from the computer!
Insert your softeware disk and restart your computer, if computer doesn't detect new software when it is rebooting....than go into your control panel...click on install new software.
Once that is installed, you'll need to restart again with the printer hooked up this time.
Again, if computer doesn't detect new hardware, go into control panel, click on install new printer, you will have to select the make and model, or if you have the disk, select have disk, then next...you computer should install the hardware for you printer.
After installed, restart again...to see if if new software and hardware is detected and is being installed.
Go to your printers, from your control panel, and see if your printer is there, if not select, add new printer, it will take you through the process from there. Make sure you select this to be your default printer!
Happy printing!
Sep 13, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Printer status reads "printer offline"
Could be several things causing this. You said it is a network printer, but then said primary computer is XP. Is it hooked to the XP machine? From my experience, printers on XP machines occasionally lose their drivers. Go to the XP machine and make sure the printer is in the printer folder, and active. Do a test print to be sure. Then make sure it is still shared (things like this can change with updates). If all this is OK, go to the Vista machine and remove the printer. Then go to add printers, and add a network printer. Sometimes, if it is a network printer, it will show up in "my network" - if so, right click and add printer. If you add the printer usually the computer will use the currently installed drivers. If it is a shared printer, go to network, double click the XP machine, and the shared printer should be there. right click and add. Once you have it working, go to printers and delete or remove the faded-out printers that don't work and be sure to set the newly installed printer as your default.
Sep 06, 2017 | HP OfficeJet 7310 All-In-One InkJet...
Won't scan but prints and copies
turn off computer. turn on - does a test page print? You need to unplug the USB cable from the printer and put the test page on the scanner - push scan. This should scan the page. Turn off computer, hook USB back up. Try to scan whatever you are scanning.
Hope that helps!
Apr 20, 2010 | Dell 924 All-in-One InkJet Printer
Not able to print but can scan
Printing can only be done from the computer.
You need to add printer before before you try to use it. Add Printer from control panel, then see if it search and find the printer software. If it does not.
turn off the computer and unplug the printer. wait a little then restart the computer. after it is started,and windows loaded,plug in the printer and see if the computer recognizes it and it will search for the driver. if the driver is not available,it will ask permission to search the internet. then it will download and install it with your permission. then it should work if it is serviceable. good luck.
Jan 06, 2010 | Lexmark X2500 All-In-One Printer
Lexmark x5470
When you got this message were you trying to scan?
What I want you to do is a copy. Doing a copy will generally not require you to be hooked to the PC.
Scanning and Printing all require communication from the printer to the computer. Failure in communication can either be something on the computer, something wrong with the cable or rarely something wrong with the printer.
I'm assuming you have done the following:
1. Power off your printer and your computer.
2. Unplugged the power from the printer
3. Unplugged the USB cable from both the printer and the computer.
4. Reconnect the USB cable to the printer and the computer.
5. Plug the power back into the printer and make sure the printer is on.
6. Turn on the computer.
Those are general troubleshooting steps that can be done for any communication problem.
If you have done all of those try this:
Press and hold down the Windows key on the keyboard, and then type the letter R.
Type "devmgmt.msc" and then click OK on the Run dialog.
Find the item Universal Serial Bus controller.
Click the + sign next to the word Universal Serial Bus controller.
Do you see USB Printing Support?
Yes:
Right-click on USB Printing Support, and then click Properties.
Does the Device status say “This device is working properly.”?
Yes:
Have you tried uninstalling and reinstalling the software?
No:
Click the Troubleshoot button to try to resolve the problem.
Does the Device status now say “This device is working properly.”?
Yes:
Try your print again (might need to restart)
No:
Might have a problem with your Printing Support
No:
Let me know - if you have a problem with your printing support you'd really need to contact your PC MFG for help - but you can always try uninstalling the USB Printing Support and reinstalling it (only if you have your disks that came with your printer).
Sep 10, 2008 | Lexmark X5470 All-In-One InkJet Printer
My comp. says my printer i s hook up put will not print the fax copy od scan works fine
check your print queue is empty, if not clear it (double click onprinter, select cancel all docs on printer menu. if that doesn't work, uninstall the software and drivers completely, unplug printer, restart computer then download and install latest drivers. plug the printer in when the software tells you to
Aug 30, 2008 | Lexmark Office Equipment & Supplies
HP Deskjet F380 - NOT PRINTING - only scanning
Solution:-
Step one: - Restart the computer
Click Start and click Shut Down.
Click Restart or select Restart from the menu.
Click OK.
After the computer restarts, double-click the Printer icon in the system tray located at the bottom, right of the computer. The print queue opens. If no documents appear in the print queue, the issue is resolved.
If the issue continues, proceed to the next step.
Step two: - Check the product cable
Disconnect the USB cable from the product and from the computer.
Wait 5 to 6 seconds.
Reconnect the USB cable to the product and computer.
After the product is connected to the computer, the product should start printing the jobs in the print queue.
Step three: - Determine whether the product is paused or offline
Click Start and click Printers and Faxes. The Printers and Faxes window appears.
In the Printers and Faxes window, right-click the product icon and click Open . The Printers folder opens.
On the menu bar, click Printer.
Make sure that the Pause Printing and Use Printer Offline options are not selected. If a check mark appears next to either option, click to remove it.
If the menu includes Use Printer Online , click that option.
If neither Pause Printing nor Use Printer Offline is selected, press Esc to leave the menu without making changes.
Step four: - Stop the print queue
Double-click Macintosh HD.
Double-click the Application/Utilities folder.
Open the Print Setup Utility folder.
Double-click the appropriate product in the product list to open the print queue.
Click Start Jobs.
Step five: - Delete the print jobs
Click a print job and click the Delete icon. Repeat the steps for all the jobs in the print queue.
Click Start Jobs.
When the print queue is empty, click Start Jobs.
Try the print job again.
Step six: - Remove and re-add the product to the printer list
Select the appropriate product.
Click the red X to delete the product from the computer.
Disconnect the USB or Ethernet cable from the product.
Close all open windows and restart the computer.
After the computer is restarted, double-click Macintosh HD .
Reconnect the USB or Ethernet cable to the product.
If the product is not automatically added, click Add.
Select the product to add and click the Add button. After a few seconds, the product appears in the printer list. Try the print job again.
Jul 12, 2008 | HP DeskJet F380 All-In-One Printer
Print problems
Please uninstall the printer drivers using cd or from add remove programmes from control panel.
and then unplug the printer and restart the computer without printer plugged in
Then install the printer using the printer driver cd and when prompted connect the printer to the computer.
this should work if still doesnt work please get back to me.
Regards
Mohammed.
Dec 17, 2007 | Lexmark X1240 All-In-One InkJet Printer
Mfc 7420
Unplug your printer from the computer.
Go to your start menu, and open your control panel. From there, doubleclick on the printer icon. You should see your printer listed. Right click on your printer and choose 'uninstall' (it might be 'remove' or something like that.) Unistall the printer.
Restart your computer (make sure the printer is still not hooked up). Reinstall the software that came with your printer. Then you can go back into your control panel, printers, and look for an option that says 'add printer' Add your printer (maybe even restart the computer) and finally plug the printer back in.
See if that works, and let me know if it doesn't, or if these directions are too technical.
Thankyou,
Oct 29, 2007 | Brother MFC 7420 All-In-One Laser Printer
Computers & Internet Logo
18 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
