Cant connect xbox and my router at same time how do i configure it so i can.
  • soutar-1 Oct 17, 2008
    its a sum vision 802.11b/g
  • Aris C.
    Aris C. May 11, 2010
    What is the model number of your router?
    Novelist:
  • 173 Answers
Okay and who is your internet service provider?
Posted on Nov 04, 2008
I changed my password and I cant get back on xbox live
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Sep 02, 2012 | Belkin Wireless Surf Router (F7D2301)
Will not assign IP address
Steps for these found on http://support.xbox.com/en-US/xbox-live/connecting/error-cant-obtain-ip-address-router-modem-978976 and include
1. Restart modem and router2. Check wireless password3. Configure IP settings manually 4. Set an alternate MAC Address5. Turn on DHCP.6. Bypass router entirely and connect instead to the modem using a wired connection
Aug 09, 2012 | D-Link DGL-4500 Wireless Router
Hi i have 2 xbox, 1 off them is fine up and running on xbox live but the other i cant seem to get up and running, it shows my belkin wireless router sayin connected but wen it comes to the connection test...
If the problem is between the network/modem and the Xbox then you will need to configure your modem/router to pick up the other xbox. Have you got both xbox's connected on xbox live on the same router? Or are you trying each one separately?
Let me know.
Thanks
Jason
Jan 18, 2011 | Microsoft Xbox 360 HardDrive 250GB Slim...
Cant connect to XBOX LIVE through wireless adapter it says to trouble shoot connection
Are you running through a wireless router? Most commonly, if this is a recent problem after purchasing wireless adapter, that your wireless router needs to be reset and it's configurations changed to allow for connection to your Xbox. If you can connect to Live with an ethernet cable, then this is most likely your issue.
Oct 28, 2010 | Microsoft Xbox 360 Console
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
Cant grt xbox360 wireless adapter conected to wireless router on pc down stairs
I assume the wireless router is configured correctly and the PC can connect to the wireless router and the Internet.
The problem could be that the signal is too weak upstairs for the XBox especially if you have a concrete floor between the XBox and the wireless router. Try moving the wireless router around to increase signal strength to the CBox.
The other problem could be the XBox is not configured correctly.
Follow these instructions to configure the XBox.
  1. In the Xbox Dashboard, go to My Xbox and open System Settings.
  2. Select Network Settings, Configure Network.
  3. On the Basic Settings tab, select your wireless settings.
  4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
  5. If your network has wireless security, enter your WEP or WPA key.
  6. Try to connect to Xbox LIVE again.
Dec 23, 2009 | Microsoft Wireless Network Adapter Xbox...
Cant find IP address
You need to make sure that DHCP is turned on for the router and the the Xbox is set to automaticallly get network settings. If not, then you will need to manually configure the adress and settings. If this is the case, please post back the address of the router and all other devices on your network and we can help you make a suitable choice and get it configured.
Aug 15, 2009 | Linksys (NH1005) 5x10/100 Mbps Networking...
Cant connect xbox live to my wirless router
Typically that is located in the software of your router. Which means you need to open a web browser on a connected computer. Usually the URL to access the router's configuration page is: http://192.168.1.1
default username: admin
password by default: admin
in the configuration from there under wireless, and then wireless security, there would the location of the WPA key be.
Apr 20, 2009 | Microsoft Xbox 360 Console
Xbox live - no connection
hey im having almost same problem, i got a motorola s8vs SURFboard cable modem with a battery in it and my ethernet ccord runs from my modem to my xbox but yet my xbox cant read my ip adress, why is this.. do you know?
Dec 28, 2008 | Microsoft Xbox 360 Elite Console
Having trouble connecting to another console on the router
You have to configure your dlink router to run with the xbox 360. Go to the dlink website and follow the instructions on configuring your router.
Nov 22, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
