Question about Epson Stylus Photo R300 InkJet Printer
Printer R300 Printer will not print error message says paper not inserted corrrectly, but printer s making funny clicking noise andwillnot accept paper. canyou advise
    Problem Solver:
  • 4 Answers
Make sure you have the paper where it hits the part that sucks in the page to be printed (you can see the gray stucture by removing the paper and looking into where the paper is put) this might cause your papers, if you have a small amount, to bend to where the dip of the curve is facing the front of the printer. *Also the best way to prevent this is by having a LOT of paper where its fed (if the bending thing doesn't work.* Also the clicking noise is the sucking part not getting a piece of paper. This is because the paper not inserted correctly means that the pronter detects that paper is in the pronter but it can't get it.
Posted on Oct 17, 2008
Hp j6480 printer wont print keeps sending a paper mismatch message
Paper mismatch errors occur because the product scans the width of the envelope before printing. If the paper size setting in the printer driver does not match the paper actually loaded in the product, the product reports a 'Paper Mismatch' error. The message saves paper and ink by preventing print jobs from accidentally printing on the wrong paper. For example, the print job might be for a 101.6 x 152.4 mm (4 x 6 inch) photo, but there is letter-size paper loaded in the product. The error message displays to make sure that ink is not wasted on the wrong paper type. try this out , disable the automatic paper type sensor.
  1. Open the Print dialog box.
    1. In Word 2003, click File , and then click Print
    2. In Word 2007, click the Office button (c01850900.gif ), and then click Print .
  2. Make sure that your product is in the Name drop-down list box, and then clickProperties .
  3. Click the Features or Paper/Quality tab.
  4. In the Paper type drop-down list, click Plain paper .
  5. Click OK to close the Properties dialog box.
  6. Click OK again to print the current print job.
Feb 24, 2011 | Digital Products Hewlett Packard OfficeJet...
Trying to print CD label and error message "CD/DVD guide open" will not print CD . . . but it will print on paper.
to cure fault on r300
press and hold 3 buttons
stop, power &
Maintenance (the one with red light over)
for 10 seconds
a message will come on screen
counter is reset and turn off
turn back on
if this dose not help your problem try to download the latest firmware and drivers from below link.
Click Here to download the firmware and drivers.
Please let me know if you have any further questions or concerns.
Thanks.
May 02, 2010 | Epson Stylus Photo R300 InkJet Printer
Document wont print
It could be a hardware issue.
Check first if the printer is working fine. Keep on holding down the paper button while you turn the printer on. Let go of the paper button when the power light starts to flash. if it printed out a color test pattern successfully, check if you are using the corrrect driver.
Tell me more if you need assistance in trashing and re-installing the proper driver for your printer. Include the full version of the operating system you are using too.
Goodluck.
sherlyn c.
May 23, 2009 | Epson Stylus C66 Photo InkJet Printer
EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
Take all the paper out,Make sure non of the paper is folded under on the stack. check the paper-feed area for debris,(papreclips, staples post it notes etc).
Check the tray and its guides are secure and it the correct positions.
Open the machine check the paper path for debris, bits of paper or anything the looks out of place.
Once you have checked and cleared everything, close uo the machine and try again.
If you are inclined, you can clean the paper rollers with alcohol.
Hope this is of some help
Ed
May 11, 2009 | Epson Stylus R380 InkJet Photo Printer
my epson r300 makes all the right noises when feeding paper but will not draw the paper through can you help
adrian
Nov 26, 2008 | Epson Stylus Photo R300 InkJet Printer
My printer, makes a grinding noise, when the paper is feeding through when printinig?
Look to make sure that there isn't a small bit of paper caught in the wheels that push the paper through. Over time, even a small bit in the corner can destroy your printer.
Mar 22, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson R300 printing only in top left corner of page
Change the paper settings in the driver when you go to print. If you have it set to 10x15 it will only print a 10x15 patch in the corner.
Go to START, PRINTERS AND FAXES then right click on R300 and select PROPERTIES. Click PRINTING PREFERENCES and set the correct paper properties. Click OK all the way to desk top and the settings will be saved.
On the printer panel press ADVANCED, scroll down 3 times to PAPER SIZE and press OK. Select A4 and press OK.
Dec 01, 2007 | Epson Stylus Photo R300 InkJet Printer
Printer stopped printing. Error message
Thjis is indication the Waste in collector pades need changing eventually.- but no now. you have plenty of warning
Reset Epson R300/200
press three buttons to reset the counters
The buttons are "STOP" "Maintenance" and "POWER"
or down load the epson utility www.ssclg.com and use the reset counter feature
The printer will sound like its going to blow up, but thats normal.
You can do this about 5 times before your printer starts to piss out ink over the table because the Waste Ink Ink Pad is full
To avoid eventual flooding go to rear of the machine- remove the little door and rake around for a small plastic pipe buried under some padding under the left side.
Fix to this a thin piece of ploythene tube[Fish tank air supply], extend it to our side the machine and place in a suitable container to collect the waste ink..
Nov 21, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
56 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
