Question about Kenmore 53542 / 53544 Side by Side Refrigerator
Kenmore Side by side model # 25357682790
I first noticed the fridge not getting cold, Now I think it's the defrost not working and I'm not getting air flow to get into the fridge. I took it apart last night and this morning it seems the freezer has been running all night it's below freezing but some of the items are not frozen and the fridge is at 60 degrees
  • Mowdog Oct 15, 2008
    The Fan is working there is no frost that I can see on the walls but the coils have frost build up on them. I don't know where the defrost timer is
    Genius:
  • 1,122 Answers
Is the freezer fan working?is there frost in the freezer on the walls?can you find the defrost timer?let me know and we can go from there-mike
Posted on Oct 15, 2008
  • MIKE major Oct 15, 2008
    most of the time the defrost timer is on the front bottom behind the grill, or back bottom near the compressor or inside the frig on the console or in the console,it has a little dial you turn slowly till it clicks and your in defrost ,now you need to see if the heater in the freezer has come on,you will see the frost melting,let me know how you do-mike
Freezer side works fine. Fridge side not as cold as should be. Fan is working on freezer side
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jun 16, 2010 | Kenmore 44109 / 44102 Side by Side...
Freezer works, Fridge doesn't
The defrost timer inside the fresh food compartment is most likely the problem. Need to turn the timer slowly clockwise until compressor stops. I should remain off for about 25 minutes. During that time the freezer should be in defrost. You may be able to open the freezer door and hear the crackling and sizzle of the defrost taking place. If the timer does not restart the refrigerator after 25 minutes the turn the timer clockwise again until the compressor restarts. Number 6 in photo below is the defrost timer. The replacement timer part number is 482493. Here is a photo. Thanks Sea Breeze
http://servicepartstec.blogspot.com/
Aug 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I have a kemore elite fridge wont get cold
It can be the defrost timer,defrost element or defrost thermostat or a blocked vent into the fridge
Aug 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore fridge not working, ice cubes wet, freezer frosting up
You may need a new defrost module. The coils ice up when it is not working. This makes the fridge and freezer only a little cold. About 150 to 250 bucks to fix if you call a service person. Under a hundred for the part.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Side by side Model #53271... not cold
you have a defrost problem in the freezer,it is one or more of 4 things,freezer fan,defrost timer,defrost bimetal switch or defrost heater,check all until you find your bad part-mike
Jan 07, 2009 | Kenmore 53262 / 53264 / 53269 Side by Side...
Kenmore side by side refrigerator model 106.56532400
Thanks for taking this question.
Kenmore 22 cft side by side does not have air circulation. Freezer is cold at the bottom (ranges 5-45 deg from bottom to top). Refrigerator section is 30- 60 deg from bottom to top. Thermostat is good; compressor is working; no ice deposit on the evaporator coils; condenser coils have been cleaned; defrost heater is working. I do not feel the air draft I used to notice whenever opened refrigerator door. Is it possible that the air recirculation fan not operating. Location of this fan in the refrigerator? Regards, Prem
Feb 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridge running but not staying cold
you have a defrost problem, if SxS ref. most likely bad defrost heaters. They are behind interior back wall. Sounds like you have a GE.
Jan 05, 2008 | Refrigerators
Kenmore 53542 / 53544 Side by Side Refrigerator Logo
423 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
