Question about HP 530 Notebook PC
HARD DRIVE IS NOT WORKING
I have noot book HP 530 S/NP.CND 7321JBO
Just install the window then i get lots of problem like computer no restart through window then i try to reinsatll the window again after formating previous window but problem remain same and also my drivers not working properly and after that then again i install the window after formating then now message which appear is that SETUP DID NOT FIND HARD DRIVES so not window is not moving forward and i am very worry now what can i do please help me?????this is 6th month noot book
which window i install WIN XP With service pack 3
    Sergeant:
  • 196 Answers
If you have a recovery CD that came with your notebook insert it into the drive and then re-boot the machine... the recovery program should start and let you factory reset the computer (put it back to new) it should work then
Posted on Oct 15, 2008
My book hard drive was hooked up to my new computer last thursday (64 bit Windows 7 professional) and worked great came to work today and computer will not recognize it no matter what I plug, unplug and...
This drive should work with Windows 7. Contact WD support and they can send you diagnostics to run.
You may try the drive in another computer, and try restarting the 7 system.
Feb 01, 2011 | Western Digital My Book Essential Edition...
Im using hp 530 and when trying to re install xp
you need to change native SATA settings in bios. then you can install windows xp. The steps are below
  1. Turn off the computer.
  2. Press the power button and press f10 to open the BIOS Setup.
  3. Use the cursor to navigate the Configuration options to locate the Native-SATA setting.
    • If there is a SATA setting, select the Disable option, and then press F10 to save the change and restart the computer
May 05, 2010 | HP 530 Notebook PC
My 6 month old HP computer with windows vista has your wd hard drive hooked to it. lately I can not open any file without the computer locking up on me. My HP tech support has said that the wd's working...
It's not True.. Windows Vista will detect fat32 system and read the content without any problem.
First you try to connect the WD into different USB port and check. Also check whether your USB drivers have been installed on your system.
2nd Option: Connect the WD and restart the system.
3rd Option: Check whehter the WD has been detected and check whehter the drive letter has been assigned by the system automatically. for this go to disk management and check the same.
Revert back for more assistance and give your valuable feedback/rating for the soluton provided.
Thank you for using Fixya.
Mar 01, 2010 | Western Digital My Book Essential Edition...
NP Nx7010 restarts itself.
your NP Nx7010 is always restarting. that part is having some trouble with your hard drive. or the partition which called the NTFS not function or unknown anymore to find the system inside your hard drive. let your technician ask or try to remove your hard drive and run it to another pc.
Jun 16, 2009 | HP Compaq nx7010 Notebook
Will not install windows xp
might cd is not valid or ur computer is not compatible
if above both things r wrong than do in this way
1) put the cd into ur drive ......,,,,,restart ur computer and than select cd-rom as first devie
2)press f10 and enter when it comes to booting from cd-rom
when windows start the set up
3)delete c drive by pressing d and then create c by pressing c
4)enter now to install window
5)it si done now after installing the window restart ur computer and select hard drive as ur first drive in bios features
Jun 11, 2009 | Western Digital 500GB My Book World...
HP 530 BIOS
tap f10 to enter the bios setup
first restore defaults then
go to device configurations and disable the Sata drive, save ur changes and see if u boot. just solved mine now.
Mar 24, 2009 | HP 530 Notebook PC
How to install win xp sp2 from cd on hp 530 laptop
1 - Place CD in the Drive
2 - Restart PC and go into Bios by pressing Del, F2 or whatever instruction the start up screen says.
3 - Go to Boot configuration and set it to Boot from CD
4 - Save and Exit
5 - Follow onscreen instructions untill you get to the Windows install screen.
6 - You may have to create a partition (Drive Letter) on your hard drive if nothing was there before, you can assign as much hard drive space as you want to this. If your not sure just use all the space available. This will be your C drive.
7 - Pick the drive you just created and install windows on it using the on screen menu. It will ask you if to format the drive, say yes and use NTFS not FAT as NTFS has more features.
8 - Just say yes to all questions asked after this point.
When windows is installed it will ask you for a CD key and to activate by going on the net, I'm afraid I can't help you with this.
Jan 19, 2009 | HP 530 Notebook
How to install windows xp sp2 on hp 530 laptop
Place cd into drive.Keep pressing enter until the computer reads the cd.Follow the directions on the screen. That is all their is too it. How did you get an HP without an operating system having been installed? thsi is a windows disk, correct? Not a reinstall disk?Should work the same either way.  If it gives yuo an error or doesn;t work please tell us what happened and we will direct you more. Thanks
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=3375953&submit.y=2&submit.x=7〈=en&cc=us
External hard drive not recognized
I have a WD3200 usb Hard drive. I am looking to partition it. The problem i encountered is when I go to the disk management, the drive shows up as disk one but below it , it says no media. its like the computer knows that there is an external storage device attatched but cannot access it. Also if I try to get into the disk from my computer, it says "insert disk"
Any suggestions?
-Oliver Fernandes
Sep 03, 2008 | Western Digital (WD3200JS) 320 GB Hard...
How to install xp on hp 530
Press F10 to enter BIOS setup...
find and disable the SATA native support
Now save and exit then when you reboot and attempt to install XP you will have no problem.
Download the drivers you need from here
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3375995&prodTypeId=321957&prodSeriesId=3375953&swEnvOID=1093&taskId=135&swLang=8
Mar 11, 2008 | HP Pavilion dv6000z Notebook
HP 530 Notebook PC Logo
83 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
