Question about Frigidaire FRS26R4A Side by Side Refrigerator
Water dispenser lever on door broken off.
Almost entire plastic arm that hangs down to dispense water has been broken off. There's only a tiny piece still connected to be able to dispense the water. Is there a replacement part? Also, both cube and crushed ice lights stay on, so it gets confused as to which we want. Not a problem for us, as we just press the correct button, but visitors don't know realize it. How can this be repaired?
  • 2 more comments
  • krudman Nov 06, 2008
    I have a FRX26HF and the same thing happened yesterday....any solutions yet?
  • Anonymous Nov 30, 2008
    Our water dispenser lever on our Frigidaire is not even 4 years old and broke off and is dangling. We can only get crushed ice.
    can you help with this
  • Anonymous Dec 04, 2008
    Missouri here I have the exact same problem and lowes stated that it I will have to replace the whole door..any feedback from anyone??
  • Anonymous Dec 09, 2008
    Help! Our ice dispenser and water dispenser lever have broken, kids too rough with it! can these parts be replaced?
Yes, the levers are easily ordered and replaced.
get manual, obtain part number, order part, replace part. use these websites for help
Posted on Dec 02, 2010
My Samsung Model: RF4287HARS refrigerator stopped DISPENSING ice. It makes it, but only water comes out of both push levers now. I get ZERO help from samsung customer service. There is nothing in
The problem is actually in the dispenser lever. The paddle that you press to dispense ice has a plastic lever/arm that extends behind it (you can't see it, it's up high in the assembly.) This plastic lever presses upwards when you push the paddle and presses into a switch. The switch actuates the ice. This little lever is also the ONLY thing that stops the paddle from continuing to press into the water paddle. So when the lever breaks, it creates your two symptoms - no ice and if you press further, you press the water switch and get water.
You need part# DA97-08519A. This is the lever assembly with the switches. You pry the control panel assembly (the whole digital display above the water/ice dispenser) out by inserting a slim pry bar (I used a pocket knife and didn't damage the finish) on one side and working my way around. The assembly is held in place by five plastic tabs (two on each side and one on the top.) When this is removed, the part# above will be obvious.
Sep 08, 2012 | Refrigerators
Broken Water Dispenser Arm - GE Monogram Side-by-Side
First, what is the entire model # from the sticker inside the fridge section?
Nov 11, 2007 | GE GSS20IEP Side by Side Refrigerator
I have a jenn-air jcd2389ges. The hole in the door where the ice comes down into your cup is broken. i believe the foam piece is busted
Here is a kit of the most likely parts that you are talking about=> 12001991 Ice Dispenser Solenoid and Door Kit Just disconnect the power and turn water off before beginning to ddisassemble the fispenser components seen here=> JCD2389GES Dispenser Components
1. Unplug the refrigerator power cord.
2. Remove the overflow grille from the housing.
3. Unsnap front cover at the bottom of the housing.
(using a flat blade screwdriver, and tape or pad, twist the screw driver, or pry out the bottom trim using the molded slots in the bottom of the trim panel).
4. Disconnect the front cover switch harness connector and set the cover aside.
5. Disconnect the power wire harness connector (BL/BK and W wires)
6. Disconnect the flapper door heater wire harness connector (if one is present).
7. Release the dispenser microswitch retainers and slide the switches off of their locator pins. Carefully handle the switches so they do not come apart.
8. Disconnect the wires from the terminals of the lamp holder.
9. Remove the two 1/4. hex head screws from the control bracket and remove the control bracket.
10. Remove the 1/4. hex head screw to remove the water fitting (fill spout) from the water dispenser lever.
11. Unsnap the ice guide and remove it from the ice dispenser lever.
12. Remove the air pot by sliding the rear of the air pot out of the slot molded to the dispenser housing and slip the linkage out of the flapper door mechanism assembly.
13. Unsnap the flapper door and remove it from the ice dispenser lever. While you remove the flapper door, carefully guide the flapper door heater wire and connector over the door mechanism assembly.
14. Remove the 1/4. hex head screw securing the dispenser levers pivot retainer to the dispenser housing and remove the retainer.
15. Remove the water dispenser lever.
16. Remove the ice dispenser lever by maneuvering it around the door mechanism assembly.
17. Pull the pin from the door mechanism assembly and remove the spring and mechanism assembly.
18. Reassemble in reverse order.
Need Help let me know, Thanks Sea Breeze
Jul 02, 2012 | Jenn-Air JCD2389G Side by Side...
Internal water dispenser rf266ab rubber cover came off and it appears there is a piece missing that holds the plastic piece down to dispence water
Had same problem. Ordered a part that appears to just snap in and replace the broken water dispenser face at this website.
Apr 19, 2012 | Samsung Refrigerators
I have a Hotpoint HSS25GFTA BB. The water is not dispensing. I know the microswitch is making and water is pumping because I disconnected the tube on the bottom of the frezzer door and it squirts water...
Water is frozen inside the water tube that runs inside your freezer door. If you empty out the food in the door, you can use a hair dryer on medium heat to warm the frozen piece so it loosens enough the dispense out. Every 5 minutes, close the door and check if water dispenses. It takes between 15-30 minutes.
GE makes a dispenser water tube heater that attaches to the top of the dispenser tube to prevent frozen tubes. The part is WR49X10173. Check to make sure it is compatible with your refrigerator. Amazon and sells the part. Good luck!
Mar 16, 2017 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Whirlpool side by side with a broken water dispenser
you may have a sticking water lever or a bad water valve.
the lever can be changed from the front and you should know if it sticks.
the water valve can be replaced from the rear of your unit. it is the plastic part where the water line hooks up to the unit.
Jan 03, 2010 | Whirlpool GS6NBEXR Side by Side...
Ice Maker Works, Water Dispenser Doesn't
I have a whirlpool side by side. water and ice in front. ice working and water not. the hose is not frozen and it is not humming when you push the water dispenser. It would give us water and quit but now we have nothing.
Jun 25, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Broken water dispenser arm
I just fixed this today. 01/2/08
First, I got some super glue from Lowes especially designed for plastics.
I first glued some metal strips to the back or the broken off lever, so it will have extra support once glued back. I then applied glue to the broken surface of the lever arm and the support arms I glued earlier.
Super glue it awesome, just had to hold it in place for 1 minute, then let it cure for a few hours... working good as new.
I'm glad this worked for me, as I did not want to have to search for the part and then worry about taking the refrigerator apart.
After repair, I had to educate my wife on how to slam a cup into the arm HEHE.
Dec 10, 2008 | Frigidaire PLHS267ZA Side by Side...
Whirlpool refrigerator water dispenser not working
My older whirlpool side by side refrigerator has stopped dispensing water. The icemaker works fine, and I have adjusted the temperature a week ago so I don't believe the line is frozen. I do not hear any noise when the dispenser is pushed down, and feel that is where the problem is. The line is clear on the bottom of the fridge behind the kick plate, but water does not come out freely when I disconnect the couplings...
Any advice?
Jan 17, 2008 | Whirlpool GS6NBEXR Side by Side...
No water from dispenser
If the ice maker is still working then water of course isn't an issue. The water dispensor has a solenoid valve that opens to let water flow... do you hear a "click" from the back of the frige when the water lever is pushed? If not, the valve is likely bad. Another possibility is the switch behind the water lever itself is not being pressed hard enough or even broken, see if you can press the switch with your finger up inside behind the lever area (flashlight needed to see up there). If that lever isn't hitting the switch it won't work of course but it could be a bad switch too. Sometimes the little plastic pins that hold the switch in place get broken by slamming a glass into the lever over time. In other words the switch is fine but just hanging inside the door area never to be hit by the lever again. I would be good to check it by pulling the cover off that are and visually inspecting the whole back side of the lever area/switch are for broken parts. The link below may help you with parts and diagrams to see the unit better.
Nov 23, 2006 | Kenmore 53642 / 53644 Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
336 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
