Question about Itronix GoBook IX250 Notebook
Replacing the hard drive
I want to replace the hard drive in my IX250 with a higher capacity unit. I can see where it is physically mounted next to the battery but how do I open the case to remove the old one? It looks like I may have to remove the keyboard and motherboard and access it from the top. Please offer suggestions.
  • albentley1 Nov 08, 2008
    flymore:
    Thanks for the tips, I am an experienced electronics technician but didn't want to find out "the hard way" and make a stupid mistake. Your tips got the job done. Yes, please post again when you install the 160gb drive. I know the 40gb works but I need at least 80gb for my huge library. If the 160 works I will go with that. Thanks again!
  • albentley1 Nov 09, 2008
    Flymore:
    Thanks for confirming that a larger drive will work. I have one of those Hitachi 160GB drives in my Dell Insprion and it installed easily and works great.
    You are a real time saver! Thank You!
No problems, Al - been there, done that!
Sorry to be slow responding, just signed on here.
You need to go in from the top - undo the panel between the keyboard and the screen, not forgetting the screws behind the screen on the hinge covers.
Then you can move the keyboard and expose the HDD lid, which you unscrew and remove - but take care since the lid is tight (maybe watertight) and it is possible to damage the electronics if you slip when prising it off - so take extra care. Mind that flat cable!
The drive and connector are now exposed inside a padded cell - carefully separate them without straining the wiring.
You can now remove the drive and replace it with almost any good standard height or smaller 2.5" IDE laptop drive. We have used IBM/Hitachi, Samsung and a few others - need to have the machines here to be sure just what - mostly small drives so not sure how big a drive the BIOS will address. Up to 40GB size works for sure.
If you are still interested we could post again when we have tried a 160GB drive that just arrived.
These are great little latops, ours (3 of them) arrived with Win2K installed, it runs OK in 128M RAM, better in 256M, but slows down seriously if Norton/AVG/SDefender and a firewall are in place.
XP is really sluggish, almost stops when protected for web surfing. Vista? Forget it!
Recommendation: Try a lightweight Linux if you want to surf in safety
Xubuntu 8.04 is good in 256 RAM, with compositing XFCE desktop if you like some Vista Bling. tens of thousands of free programs to download with some stunning stuff amongst it.
Puppy LInux 4.1.1
goes really well in 128M, it is unusual but fully featured, no need to install fully, just put a Pup-save file inside Win2K, optionally put system files (SFS) there too for faster boot.
You can use that for surfing safely, save any downloads to the Win2K filesystem, then log off and drop back into Win if you want.
For some delightful insanity try 'MacPup Foxy' with an OS X look! Too c o o l for me ;^)
6-year-old Gabriel loves his Xubuntu GoBook with Spiderman theme and music - surfs safely behind the industrial grade firewall and the parental controls on Firefox.
Hope you get yours running well.
PS Hi to Jeff-Smart - there is nothing extra special that we can see about these HDDs. Off the shelf and easy to replace with a little care - it is a waterproof case after all!
External drives are great, we use a 120gb USB-powered one - BUT the GoBook has USB 1.1, slow as a snail. Pays to not have anything on the USB drive that you want in a hurry. Yes, PCMCIA
Posted on Nov 08, 2008
  • 1 more comment
  • Ben Derr
    Ben Derr Nov 08, 2008
    OK Al, will do - maybe next week - we are going sailing on Sunday! Ben
  • Ben Derr
    Ben Derr Nov 09, 2008
    Hi Al - the 160GB Hitachi works perfectly - all formatted up and running right now.
    Hitachi Model No:- HTS541616J9AT00
    We have re-installed Win2000 from our Ghost backup disk - which did look a bit flaky at one point since it only seemed to be seeing 65GB of drive - but our Win2K partition is only 20GB so no worries there, and no problems with the installation.
    The 65GB thing was probably something to do with the skeletal DOS implementation used by Ghost, since the BIOS recognises all of the drive at boot time.
    Win2K sees all of the other partitions and reports them correctly as far as I can see. The machine now has (in addition to Win) Puppy Linux 4.11, Fluxbuntu, and Vector Linux on it, still struggling to get Slitaz Linux to do its thing and install to HDD although the live CD works fine. The same stack of installations was (ahem) a 'bit' tight on the old 20GB drive.....
    Yes, it's a portable Linux demo, amongst other things.
    May your installation go as smoothly.
    All the best, Ben
    PS Slitaz is a bit weird, but it fits into 25MB - yes, that is twenty-five meg, and no error. Runs entirely in RAMdisk (no HDD needed) and likes 128MB of RAM to do that. Fast, or what?
    PPS unfinished comment (above, previous msg) on PCMCIA add-ins - not all of these work 100%, usually OK in Win, but can have (supplied) driver funnies to add to the excitement. The ones that say Linux 2.4+ compatible on the box (yes, they do that these days) usually work best under Win or Linux. We used one to fix the lack of USB2, but the laptop is now on the other side of the world so I cannot give you the part number or maker of the card.
  • Ben Derr
    Ben Derr Nov 10, 2008
    It's a pleasure, mate!
  • 29 Answers
Drear Albentley1,
Are you really sure you want to replace your HDD ? For 1 you may need to replace with the correct manufactured one as i believe its a IBM special one. Then you'll have to go through the process of backing up your files to something else and reformatting and installing the new drive with the O.S. this can be cumbersome , time consuming and expensive.
Instead, why don't you look into a external/portable USB hard drive, you can back up your C drive from your lap top, and add more files to this and its not only portable but you can transfer files to any other comp.
Give it a thought! Let me know how you make out. JLS
Posted on Oct 15, 2008
I have a Gen 8 Hp server with 5No 600GB HDD. The first two disk are mirrored, the other 5 are on raid 5. 1 of the 3 on raid 5 is flagging amber colour. How do I replace the HDD without losing Data?
Before replacing drives • Be sure that the array has a current, valid backup. • Confirm that the replacement drive is of the same type as the degraded drive (either SAS or SATA and either hard drive or solid state drive). • Use replacement drives that have a capacity equal to or larger than the capacity of the smallest drive in the array. The controller immediately fails drives that have insufficient capacity. In systems that use external data storage, be sure that the server is the first unit to be powered down and the last unit to be powered up. Taking this precaution ensures that the system does not, erroneously, mark the drives as failed when the server is powered up. Replacing drives The most common reason for replacing a drive is that it has failed. However, another reason is to gradually increase the storage capacity of the entire system. NOTE: In fault-tolerant configuration, hot-plug hard drives can be replaced when server is ON, but in case of a Non-hot-plug hard drive, it should be replaced when server is OFF. For systems that support hot-pluggable drives, if user replace a failed drive that belongs to a fault-tolerant configuration while the system power is on, all drive activity in the array pauses for 1 or 2 seconds while the new drive is initializing. When the drive is ready, data recovery to the replacement drive begins automatically. For systems that support non-hot-pluggable drives, if user replace a drive belonging to a fault-tolerant configuration while the system power is off, a POST message appears when the system is next powered up. This message prompts user to press the F1 key to start automatic data recovery. If user do not enable automatic data recovery, the logical volume remains in a ready-to-recover condition and the same POST message appears whenever the system is restarted. Automatic data recovery (rebuild) When user replace a drive in an array, the controller uses the fault-tolerance information on the remaining drives in the array to reconstruct the missing data (the data that was originally on the replaced drive) and then write the data to the replacement drive. This process is called automatic data recovery or rebuild. If fault tolerance is compromised, the controller cannot reconstruct the data, and the data is likely lost permanently. Time required for a rebuild The time required for a rebuild varies, depending on several factors: • The priority that the rebuild is given over normal I/O operations (user can change the priority setting by using HP SSA/ACU) • The amount of I/O activity during the rebuild operation • The average bandwidth capability (MBps) of the drives • The availability of drive cache • The brand, model, and age of the drives • The amount of unused capacity on the drives • For RAID 5 and RAID 6, the number of drives in the array • The strip size of the logical volume • Firmware versions of the Smart Array Controller and Hard Disk Drive • Presence of BBWC/FBWC CAUTION: Because data rebuild time may go upto the rate of 200GB/15 minutes, the system could be unprotected against drive failure for an extended period during data recovery or a drive capacity upgrade. When possible, perform rebuild operations only during periods of minimal system activity. When automatic data recovery has finished, the drive status LED changes from flashing green to solid green. If the drive status LED on the replacement drive changes to flashing or solid amber, the rebuild process has terminated abnormally. If an abnormal termination of a rebuild occurs, identify the cause and appropriate corrective steps. Abnormal termination of a rebuild If the activity LED on the replacement drive permanently ceases to be illuminated even while other drives in the array are active, the rebuild process has terminated abnormally. The following table indicates the three possible causes of abnormal termination of a rebuild. Cause 1: An uncorrectable read error has occurred. 1. Back up as much data as possible from the logical drive. CAUTION: Do not remove the drive that has the media error. Doing so causes the logical drive to fail. 2. Restore data from backup. Writing data to the location of the unreadable sector often eliminates the error. 3. Remove and reinsert the replacement drive. This action restarts the rebuild process. If the rebuild process still terminates abnormally: 1. Delete and recreate the logical drive. 2. Restore data from backup. Cause 2: The replacement drive has failed. Verify that the replacement drive is of the correct capacity and is a supported model. If these factors are not the cause of the problem, use a different drive as the replacement. Cause 3: Another drive in the array has failed. A drive that has recently failed can sometimes be made temporarily operational again by cycling the server power. 1. Power down the server. 2. Remove the replacement physical drive (the one undergoing a rebuild), and reinstall the drive that it is replacing. 3. Power up the server. If the newly failed drive seems to be operational again: 1. Back up any unsaved data. 2. Remove the drive that was originally to be replaced, and reinsert the replacement physical drive. The rebuild process automatically restarts. 3. When the rebuild process has finished, replace the newly failed drive. However, if the newly failed drive has not recovered: 1. Remove the drive that was originally to be replaced, and reinsert the replacement physical drive. 2. Replace the newly failed drive. 3. Restore data from backup. More Resources: • Click here for ProLiant Self Solve. • Click here for Creating and Managing Hard Drive Online Spare Technology. • Click here for 17xx Power-On Self-Test (POST) Errors and fixes. • Click here for HP Dynamic Smart Array RAID Controller User Guide. • Click here for HP Smart Array Controllers for HP ProLiant Servers User Guide. • Click here for HP Smart Array Controllers for HP ProLiant Gen9 Servers User Guide. • Click here for Configuring Arrays on HP Smart Array Controllers Reference Guide. • Click here for Array Configuration, Diagnostic, Storage Administrator and SmartSSD Wear Gauge Utility Software and User Guides.
Feb 15, 2017 | HP Computers & Internet
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Problems hl-dt-st dvdram gsa-t40n ata device
Dvd needs replacing sometimes they just fail, like you can have hard ware and not software the reverse also applies
dvd are cheap enough now
Apr 26, 2017 | Dell Vostro A860 Notebook
Seagate's DiscWizard, Extended Capacity Manager didn't recognize a hard disc with MBR partition style larger than 2TB when trying to maximize the capacity of the 3TB Seagate ST32000641AS drive...
Seagate Extended Capacity Manager
Seagate Extended Capacity Manager lets your operating system support large size discs with MBR partition style, so then you are able to use the space beyond 2 TB: this free space will be recognized as a separate disc, and will be accessible by your operating systems and applications as if it was a regular physical hard disc.
Seagate Extended Capacity Manager wizard will display all hard discs larger than 2 TB (unallocated or with MBR partition style). You can see, which disc space is recognized and allocated by Windows - this space is called Native Capacity in the wizard.
The space beyond 2 TB is displayed as Extended Capacity Zone. You can enable Extended Capacity Discs, and once it is done, this space will be visible by the operating system and ready for disc management operations.
Click Allocate space to see the possible disc space allocation in the next step.
After clicking Apply changes now button, the Extended Capacity Discs will be emulated on your physical disc. In case your physical disc is larger than 4 TB and the host operating system does not support a GPT partition layout, there will be several Extended Capacity Discs.
Note these Extended Capacity Discs are not bootable, and most properties will be the same as a physical disc's.
After allocating the space, you may temporary switch off Extended Capacity Discs by clicking the corresponding option. This will make Extended Capacity Discs invisible for Windows Disc Management tools, though the disc space will remain allocated.
To disable Extended Capacity Discs, click Remove partitions from Extended Capacity Zone and then click Apply changes now button in the next step: these discs will be removed from your system, and as a result - the disc space beyond 2 TB will become inaccessible
Sep 15, 2011 | Seagate Technology Barracuda Xt...
Error code 2000-0146 do i need new hard drive if so what is the replacement hard drive for a dell inspiron 1525 notebook pc thx
that error actually refers to a hard drive issue/failure. You may attempt a reformat and reinstall, but if it fails, you can proceed to get a new hard disk. You can get in touch with Dell for warranty replacement if applicable, or order a new hard drive. You may then decide either to get the same capacity or upgrade to a higher capacity drive.
Sep 03, 2010 | Dell Inspiron 1525 Notebook
Install extra hard drive
There's no place in a notebook where you can install an extra hard drive. There isn't room. You can replace the hard drive with a higher-capacity one. Or you can get a USB external drive. I personally like the external drive idea since it gives unlimited capacity.
Feb 23, 2010 | ASUS Eee PC 1000H Laptop
Bought 2130 from work . The IT person there removed both hard drive and the shuttle in which the hard drive is loaded, need specs on replacing these Model #'s a drawing if possible. I have a samsung model...
Ask the IT person for the shuttle/carrier for the hard drive, it does not affect the company's data. You can also ask the IT person for the details and hard disk capacity so you can purchase a replacement hard drive.
This model Compaq uses a 2 1/2" IDE hard drive probably 20 to 40 Gb capacity, It is near impossible to purchase one with this small capacity, you might get a 80 Gb capacity or higher.
Aug 08, 2009 | Compaq Evo N800c Notebook
I would like to upgrade my hard disk capacity from 80 GB to higher ones. please suggest the list of compatible hard disk which i could connect to FOXCONN MOTHER BOARD MODEL 865G7MF-SH. Thanks.
It doesnt matter which hard drive you use there all compatible but make sure you check make connection they have either a sata or ide connection. Most people are using 160gb or higher, 1tb are very popular check with your local computer stores on the prices.
Jun 20, 2009 | Foxconn 865G7MF-SH Motherboard
Hard Drives
You can use that drive .. be sure that what you use tho has the same interface as your laptop .. IDE or SATA drive .. that is really your only restriction
Jan 31, 2009 | Itronix GoBook IX250 Notebook
Itronix GoBook IX250 Notebook Logo
330 people viewed this question
Top Itronix Computers & Internet Experts
Steven Wander
Steven Wander
Larry Chandler
justwinwin
Are you an Itronix Computer and Internet Expert? Answer questions, earn points and help others
