Question about Sony KV-36XBR400 36" TV
My tv won't come on
A few months ago, I noticed a color change, like the tv brightness got brighter and lost some color. But today, I can't get it even to come on. It sounds like it's coming on but I get no sound or picture, it just stays like a black screen, where it appears not to be on. Please help, I hope the picture tube did not go out.
  • 905 Answers
The picture tube did not go
this could have been the flyback transformer and or some components, but the tv will need to be tested to determine what has cause the tv not to come on
Posted on Oct 15, 2008
Hi we have lost all channels of our hisence tv just blue screen saying no signal please help had channels yesterday
Nothing to worry, You change to AV mode to TV mode and wise verse,
If nothing happen then call the service center, It only two months old.
Jul 23, 2012 | Hisense LCD1504 15 in. Television
I have a 42 in Sony HDTV model # KDF-42WE6555. I notice a few months ago a blue line down the left side. TV still wking good. Today I notice a yellow patch on the right side. TV is still wking good except...
i have the same problem but mine has a blue line surrounding the screen the tech took out the fly wheel part from inside this part has the 3 main colors with strips the blue side strip if you look at the glass it has the problem you see on your screen you have to replace that one section
Mar 10, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Still, bright images on my PS3 change the color of my TV in areas
hi verifies if you are connecting good the video cable i mean the red, the yellow, and the white, if this dont serve you, is because your tv is to old.
Sep 19, 2009 | RCA TruFlat 27F520T 27" TV
99 jetta headlights wont turn on, replaced 4mo ago.
If the bulbs and relays are good, then the switch is faulty.
Sep 13, 2009 | 1999 Volkswagen Jetta
Bright blue patch in center of screen.
The optical block is going bad. Contact Sony support and have your model and serial numbers handy. Sony sometimes warranties these even after the 1yr factory warranty.
May 16, 2009 | Sony KDF-42WE655 Television
Screen getting dark
If you have never changed the lamp this is more than likely the issue, as the tv ages the lamp looses brightness. Most lamps are rated for 3000-5000 hrs of use. Replace the lamp assembly part # UX21514 and you will notice a much brighter picture. You do not mention if the tv plays the right colors on the entire screen. These have had light engine issues.
Good luck with it
JOTVGUY
Apr 07, 2009 | Hitachi 50VX915 Rear Projection Television
I have a sony kf-42sx3oou, i have just had the lamp replaced, since replacing it a few blue spots appeared in the top right corner but today a yellow line has appeared on bottom left hand corner, could you...
This problem was probably there before, but you only noticed with the new "Brighter" bulb.
This TV will require replacement of the LCD Prism unit.
This Prism blocks and allows colors so that the 3 LCD images may be mixed to produce the final image you see on the screen. When this becomes damaged or defective, it leaks colors (light). This Color Leakage apears as spots on the screens.
Where you see the spots is where the specific spot on the prism that is leaking light, the specific color that is leaking also.
This parts cost alone is normally $500 to $1000 dollars but is usually replaced under warranty. If out of warranty, I suggest living with it or selling it if out of warranty. Turn down the Brightness and it will not be as noticeable. I am sure you only see this with bright images.....like white backgrounds and such
Good luck.....
Mar 04, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Brightness gone again?
go to menu.then brightness use plus button to get it brighter
Feb 07, 2008 | Televison & Video
Visible bands moving up the TV
The bands are caused by unsheilded power cables that are near the
set. sometimes your tv cable or antenae cable is near a power
source and it is picking up unsheilded EM signals. Remove all
power sources near your tv and tv cable.
Nov 09, 2007 | Toshiba 62HMX84 62" Rear Projection HDTV
JVC AV-27530 Sudden changes in brightness
This sudden changes in brightness are caused by the change in voltage inside the tv,not in the outlet in the wall but inside the set,The changes are an indication something is going wrong and it needs to be corrected,the set does have a brightness limiter but it only works when the set wants to get brighter than normal,You need the assitance of a servicer to correct this problem.
Oct 04, 2006 | JVC AV-27530 27" TV
Sony KV-36XBR400 36" TV Logo
143 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
