Question about Teac Audio Players & Recorders
I have been given a Teac 1000M reel-to-reel recorder. Having followed all the directions in the user manual, cannot get it to work. When I pree "start" there is a clunk as a solenoid clicks in and the tape startrs to move, but almost immediately there is another clunk and it stops. " HELP " Jack Middlehurst < j.middlehurst@homecall.co.uk
  • JohnJackM Oct 15, 2008
    Teac R-to-R recorder X1000-m
    Thanks so far. Yes it will fasst forward and backward. So what does that tell us?
    Jack M
  • 899 Answers
If you still need help , I"m here waiting
I think the solenoid that engages the heads won't hold for some reason that will need to be tested and seen visually
Posted on Oct 16, 2008
    Genius:
  • 1,124 Answers
But from what you have described, this does not sound like a belt problem. What you failed to mention is if it is the takeup, or supply reel that goes loose.
Something inside your active electronic tension servo mechanism is not working properly.
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Posted on Oct 15, 2008
    Top Expert:
  • Teac Master
  • 77,169 Answers
Pull the front cover under the reels and check the belt, I have a similiar Teac reel to reel and that was the issue with mine, the belt was worn and and needed replacement, I found the part on Ebay.
    Brigadier General:
  • 6,966 Answers
Normally, on most reel to reel, there would be two arm that swings. They must be positioned in such a way that the tape hold them in a certain place. These arms auto-stops the reel motors.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
  • Louie  Role
    Louie Role Oct 16, 2008
    Hi again,
    Other than the tape tensioner arms, another possible problem is the small belt that turns the mechanical counter. I seem to remember that an autostop sensor is also built-in to the counter.
  • Louie  Role
    That should be electronic counter. Additionally, you may want to reference this page for tape and tensioner arm positions.
    Guru:
  • 1,894 Answers
I think there is something stuck inside the unit
i will suggest you to do a full service
    Master:
  • 538 Answers
That sounds like the tape tensioner relay is kicking in..can you fast forward and reverse the tape?
  • A Womans Computer Man
    A Womans Computer Man Oct 15, 2008
    tells us the motor that moves the tape has that function. now, this incremental issue..does it happen when the tape is all on one side, or does it also happen when tape is even on both reels..what i am getting at here is that the tensioner may be out of whack, and when there is too much load on one side, this can happen..
Need manual for Teac 3300 tape player
The TEAC 3300 made in 1972 is an extremely versatile tape deck, designed for the beginner through simplicity of design, yet built to the high technical requirements demanded by the semi-professionals and experienced audio enthusiasts.
The unit will operate at 7.5 or 15 per second and is available in 2 or 4 track configuration.
Specifications
  • Track system: 4-track, 2-channel, stereo/monaural system Motor: 2 x reel, 1 x capstan
    Reel size: up to 10.5 inch reel
    Tape speeds: 3 3?4 7 1?2 ips
    Wow and flutter: 0.06% (7 1?2 ips)
    Frequency response: 25Hz to 24kHz (7 1?2 ips)
    Signal to Noise Ratio: 58dB
    Total harmonic distortion: 1%
    Crosstalk: 60dB
    Input: 100mV (line), 0.25mV (mic)
    Output: 0.3V (line)
    Dimensions: 440 x 440 x 235mm
    Weight: 20kg
    Accessories: empty reel, reel holder, connection cord
Download your manual here: Login HiFi Engine TEAC 3300 Stereo Reel to Reel Tape Recorder HiFi Engine
Sep 18, 2017 | Teac Audio Players & Recorders
Looking for a Teac X10 reel to reel recorder User manual Not service manual Can anyone help please?
It should be found as a Pdf file on Hi FI Engine or for $5.00 at owners-manuals. com as these places usually have the common manuals.
Mar 19, 2015 | Teac Audio Players & Recorders
Reel recorder
The A4070G can record in each direction but has a switch that needs to change to switch the heads. This must be stuck after all this time and so the deck needs service. They are not easy unit to work on. I have one in my shop now. The bad news is that they use combo record and erase Ferrite heads that can not be sourced anymore.
I am very familiar with this model as I worked at Teac and fixed many of them.
Apr 20, 2014 | Teac Audio Players & Recorders
Teac A-5300 reel to reel service manual
Try Hi Fi Engine first and then owner-manuals.com and the best solution is from stereomanuals.com which is where I get my manuals.
http://www.stereomanuals.com/index.htm
Jan 04, 2013 | Audio Players & Recorders
Teac A-7010 take up reel not pulling
If this is a direct drive deck, the takeup reel motor may be ng
Jul 04, 2012 | Teac Audio Players & Recorders
I have a teac 3340 reel to reel recorder and believe it can only function in 2 speeds 7 1/2 ips and 15 ips. I have many reel to reel recordings that are 3 3/4 ips. Is there an adapter or gadget I can use...
In short, no. if you look closely you will see the Teac 3340 has a much larger/thicker capstan shaft than other Teac reel decks. This feature allows the faster tape speeds...7 1/2 and 15 ips. In order to slow down the Teac 3340 you would have to change the flywheel to one from another deck that was made to run at 3 3/4 and 7 1/2. Which is possible but some work..plus you would have to find a slower speed flywheel from another Teac deck. Also to maintain performance, the bias and Eq positions for the slower speeds would have to be readjusted from 7 1/2 and 15.
May 11, 2010 | Audio Players & Recorders
Would the owners/service manual for the Teac X-1000R reel to reel tape deck be available for download??
You can download the user manual from:
http://safemanuals.com/user-guide-instructions-owner-manual/TEAC/X-1000R-_E
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks for using FixYa
Jan 08, 2010 | Teac Audio Players & Recorders
How to start to play
Go here for a picture:
http://www.proaux.com/TEAC-A4010-GSL-Reel-to-Reel-Recorder,name,1638,auction_id,auction_details
http://www.angelfire.com/electronic2/vintagetx/index.html
The two arrow buttons on either side of the FAST key will play it Forward or Reverse. Combining the FAST key with a direction initiates a fast forward or rewind.
May 16, 2009 | Teac GF-600 Turntable
Teac x1000r tension arms drop take up reel stops
terrysrubberrollers.com might be able to help
Jan 23, 2009 | Audio Players & Recorders
Teac X-10 connections to a dbx 224
connect the x10 outputs to the dbx 224 line in connect the dbx 224 outputs to the cd recorder anlog line in windman
Jan 29, 2006 | Pioneer PD-R509 CD Recorder
170 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
