You need to make sure you have a Casio cable to connect the two machines. If you have no serial port in your computer, make sure you have a USB to serial converter as well as the Casio link cable.
If anyone needs a Casio TE-2000 manual, c-tech collective have it here:
http://the-checkout-tech.com/manuals/cas...
SOURCE: Casio TE-2000
VAT is value added tax which is straight percentage. program tax one or two for the percentage and make sure your departments are set up taxable or non taxible. prgm 2 is vat probably and program 1 will be for dept. generally with casio.
SOURCE: Iwant casio cash register te
If you go to a dealer, you should be able to buy a Casio link cable for a PC and the Casiovision utility software.
Mark
SOURCE: Need free programming manual for Casio TE-2000 cash register
Hi. I don't have any downloads, but I know this model, so I can help with programming.
Mark
SOURCE: Casio TE 2000 Electronic Cash Register doesn't work.
u mean no power at all?
If yes, try to reset it. (NOTE: This method will RESET all of ur programmed data!)
1. Off power
2. Take out the AA size backup battery
3. On Power
4. The machine should show "0000000000"
5. Fix the AA battery in
6. Program the Date & Time
7. Ok
SOURCE: date setting for cash register casio TE-100
Turn key to program mode.
Type date as YYMMDD
Press X/TIME (maybe labelled X/ DATE TIME)
Press CLEAR
For those of you needing a Casio TE-100 manual, c-tech has it here:
http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Testimonial: "My problem might be very simple, but, the response is superb.. I'm glad I was asking to the right place.. Thank you very much.."
