Question about Bypass Essentials pkh34 Immobilizer Override Honda/
1988 acura lengend
My car over heat last week. I was driveing on the freeway then my car start to get hot I pull over try to cool it off I put water in it start back driveing I got about 8mils down the road then it over heat again before I pull over to the side of the road the car stop running. I got a manual the car it say it the main relay but I bot one from the junk yard off another car I replays the furl pump,furl pressure regulator,Electronic Ignition distrib.
Three rubber pipes for your coolant have cracked... And they get bigger so you should replace them.. It's really cheap if you know how to work on cars. parts are like maybe $20 in all... But if you take it to the shop... Expect $200 or more
Posted on Feb 08, 2009
  • 112 Answers
I think you might have better luck posting this in the Cars forum, and not in the security forum...
Posted on Jan 26, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I have a 1986 Acura Lengend it runs and drives ok but the PGM-FI light comes on when driving it. If you are on the freeway with the cuse control on and in engaged it feels like it is surging. This ca
so why not , get the PGM-FI flash codes, insert the Diagnostic jumper
and let it false the DTC error codes. then post them.?
ever do the 60k tuneup this decade? nows the time....
Jan 30, 2014 | 1986 Acura Legend
2002 acura running hot, Cooling fans are not comimg on and blower for A/C heater not working
Test both the cooling fan relay and the fuse (located under the hood and inside the control module box).
For the inop blower fan, test the switch if the fuse checks out.
Apr 11, 2013 | 2002 Acura RSX
How do i check or know if i need a new oxygen sensor for my 1988 acura legend
What you do is pull the engine error codes. On the other hand, oxygen sensors can be replaced, based on time. A good running engine keeps the sensor hot enough to last a really, really long time.
Oct 19, 2010 | 1988 Acura Legend
My 1988 Ford Bronco 5.0 has been stalling / acting like its run out of gas. (Has always run great before) I know it has plenty. Today 7.28.10 It stalled twice, first time it did it had at least 1/4 tank,...
You might have what is called vapor lock. The fuel gets so hot that it boils in the fuel pump or the lines. Do this test spay water on the fuel pump to cool it off . ( this only works for a few minutes before it gets to hot and vapor locks again ) If you can Keep the engine heat Off the lines and the Fuel pump it might help. If you have metal fuel lines near a heat source rap them with something such as rubber fuel line sliced down the middle to keep the heat off them If you are using an aftermarket electric fuel pump relocate it down low near the gas tank ( they work better pushing than pulling ) away from any heat source such as exhaust If your using the stock fuel pump try replacing it with a new one it might be getting weak Replace the fuel filter while your at it.
Jul 28, 2010 | 1988 Ford Bronco
1999 cadillac will not start, plugs are dry
yes a fuel pump can give out at any time to check put your head by the gas tank and have someone turn the key if you hear a buzzing from the tank then you know it works. if you here nothing its bad and will have to drop the gas tank to replace it.
May 04, 2010 | 1999 Cadillac DeVille
I have an 1988 oldsmobile toronado trofeo. I was driving down the freeway last week when my car suddenly turned off, all the electronics went out and i was stuck on the freeway. Luckily i was able to start...
On the passenger front fender, just behind the battery is a main junction block for almost all power to the car. It is red, disconnect the battery, open the red cover and make sure the two copper nuts are tight and free of corrosion. Also check your battery connection and make sure those are clean and tight.
Oct 25, 2009 | 1988 Oldsmobile Toronado
Over heating leading to resevior geting full of hot , no fans
CHECK YOUR FAN RELAY WHEN YOU STOP AFTER A DRIVE THE FAN SHOULD COME ON AUTOMATICALL TO COOL DOWN THE ENGINE ;;YOUR RELAY MAY BE BAD
Sep 16, 2009 | 1989 Acura Integra
Overheats once in a wile no codes on scanner.
I have a 2002 Honda Civic Ex, it has been over heating but only in stop and go traffic, never on the freeway, i have replaced, timing belt, water pump, cooling fan relay, cooling fan switch, flushed radiator. There is no white smoke coming from the tail pipe and the oil is clean, when the car gets hot i can smell the coolant pretty strong, car has never completly overheated gets about 3/4 of the way til red.
Jul 01, 2009 | 2003 Honda Civic
Car stalled
these vehicles overheat real fast when u noticed the water pump leak yu should have replaced it now i think that you have over heated the head and the heads have to be removed , check for cracks and most probably you will end up doing a valve job and replacement of the head gasket, water pump and the timing belt. sorry not very cheap at all
Nov 11, 2008 | 1994 Acura Vigor
Bypass Essentials pkh34 Immobilizer Override Honda/ Logo
103 people viewed this question
Top Acura Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Bill Boyd
Are you an Acura Vehicle Part and Accessory Expert? Answer questions, earn points and help others
