Windows 7 disk lets me drop out to dos from drive (x) ???...but I dont know how to format my drive to ntfs as I have no idea what it is called? help! I want rid of ubuntu!
You can use the windows disk to over-write the ubuntu installation. Just boot from the windows disk, and when it asks where to install, tell it to format the disk and create a partition from the unpartitioned space. Windows will format the disk and you should be good to go. Keep in mind, everything on the disk will be lost.
SOURCE: ubuntu fixing ntfs filesystem
If u have problem with fixing NTFS so please visit this website
http://www.ubuntu.com/ so that this a new operating system
even i am waiting for the CD's to check this operating sytem
If u have more clarifications u can go through this website
SOURCE: Ubuntu Desktop
First you will want to open Nautilus, the Unbuntu file manager. From here go to -Edit/preferences Then select the tab that says -behaviour Then clock on "Single click to Activate files" That should do the trick!
SOURCE: How do i use ubuntu fixing ntfs file system?
Use apt-get from the terminal to install the ntfsprogs package - sudo apt-get install ntfsprogs
Then you can use the tool ntfsfix from the terminal to attempt to repair a ntfs partition.
Example:
* unmount the drive if it's mounted already
sudo umount /dev/sda1 - read below for device naming info
then type: sudo ntfsfix /dev/sda1
Note:
A typical home pc or laptop has 2 or 4 IDE channels as follows:
For example:
and so on...
SCSI & SATA devices are listed as devices sda, sdb, sdc, sdd, sde, sdf, etc. in the /dev directory. Similarly, partitions on these disks can
range from 1 to 16 and are also in the /dev directory.
Now each hard drive has 4 primary partitions (limit of PC x86
architecture). First partition is denoted by number 1. For example:
And so on.
You can run command fdisk -l (lowercase L) to display a list of partitions:
WARNING! These examples may result in data loss. Use fdisk command with caution as it can manipulate / overwrite your partition table.
SOURCE: Ubuntu Grub error 17
i've just explained it in another threads..hope it'll help you.. http://www.fixya.com/support/t888401-ubuntu_repair_grub
I have no idea of advanced Ubuntu terminal commands so posting them wont help!
Linux has formatted my drive and uses it all so I may need to repair my MBR but not sure at what point i do that. I can get by in DOS
