Question about Dryers
Tumble dryer put the belt back on
How do i put a new belt onto my dryer
    Genius:
  • 1,122 Answers
Don't know the make or model but you can go to sears .com click on parts put your model number in(inside dryer door)and it will show you everything you need to know,let me know how you do-mike
Posted on Oct 15, 2008
How to assemble belt
Hello Denise, I have seen this problem many times. The sneakers by themselves in the dryer cause a shock effect , when the weight of the sneakers tumbling onto the drum overloads the skinny belt and the belt breaks every time. Usually. if you dry the sneakers along with other clothes or towels this will not happen.
Feb 27, 2014 | Estate TEDS840JQ Electric Dryer
My belt is broken on my tumble dryer.took it apart and don't know how to put the new belt on
The belt goes around the drum, through the idler pulley onto the pulley on the motor. The idler fastens into several holes on the floor of the dryer.
Sep 29, 2011 | Dryers
I am trying to change the belt on my electra tumble dryer but cant get it onto the spindle as there is a spring loaded pulley wheel also?!!!1
put the belt onto the tension pulley first then use the large diameter drum to assist you in in LEVERING the belt on with tensioner spring in place . Failing that remove and replace spring with vice grips (put spring back on as it came off ).
Aug 13, 2011 | Dryers
The Drive belt of my ;G Tumble Dryer snapped. I bought a new belt and need to learn how to replace it. Can the expert explain to me, step by step how to replace it in a safe and efficient way without...
put the new belt onto the small pulley or drive pulley first- you will then be able to turn the belt onto the larger pulley by turning it by hand . All of this is done with power off and plug pulled out . good luck
Jul 21, 2011 | Dryers
I have a Creda 37374 Tumble Dryer and the belt has snapped. ive managed to get to the insides of the machine but how do i replace the belt as it looks as if it came off two pulleys next to the motor and...
remove the timer knob and you`ll see a small screw. remove that and the from control panel should slide upwards. once thats off you will see two metal rods/arms which fit onto the rear and the front of machine. remove the 2 screws holding the 2 rods/arms. the front of the machine can now be moved forward enough to get the belt over the drum. when the belt is over the drum, place belt onto the motor drive shaft (ribbed part of belt to ribbed pulley) then put belt between the sprung rollers and onto both rollers. make sure drum is then re aligned onto the bearing sliders on the front panel of machine. fasten back up. job done.
Jan 20, 2010 | Dryers
Fitting new belt to Hotpoint9320w tumble dryer
Put belt around spindle then pull pulleys apart and rest onto belt.
I am assuming that the spring which holds the pulleys together is still in place.
Please post back if any further assistance needed.
Thankyou for using Fixya.
Jan 29, 2009 | Hotpoint TDL14 Electric Dryer
Hotpoint tumble drier TDL52S
you dont need to take the back off. to get inside, first remove the panel on the bottom of the front, that will allow you to remove the front panel and you will be able to get inside the dryer. as far as stretching the belt, i have never heard of that. there is a belt tensioner that holds the belt tight though. good luck!
Sep 24, 2008 | Hotpoint TDL15 Electric Dryer
Creda tumble dryer repair
with great difficulty - these belts are so tight!there is a special tool for doing it but there are other ways
one way i have used is to make a spanish windlass from belt to bottom of machine. when belt is level with motor spindle, push belt on and release spanish windlass. could also try levering belt on with a screwdriver
another method is to get a short piece of tubing that will fit over motor spindle. put belt over tube, lever down and slip belt on. this is the best way
Jul 20, 2008 | Dryers
Tumble dryer
pull the front off then put the belt around the drum then pull the idler pulley back to put tension on it and put the belt around the motor pulley let the idler pulley back against the belt to keep it tight replace the front and your done
Mar 12, 2008 | Dryers
Dryers Logo
113 people viewed this question
Top Dryers Experts
