Question about Nintendo DS Lite Console
Where is the L and R button - I must be blind???
I just can't figure out where the heck the buttons are?I see "X", "Y", "A" and "B" - start and select but darn if I can find a Land R button. How do I access them?
  • 20 Answers
TOP LEFT AND RIGHT CORNERS
Posted on Oct 15, 2008
How to play omaha
To start a new hand two "Blind" bets are put up or "Posted." The player immediately to the left of the player with the dealer button puts up or "posts" the small blind which is approximately half the minimum bet. The small blind for the $2/4 game is one dollar. The player to the left of the small blind posts the big blind which is equal to the minimum bet which is three dollars for this game. The rest of the players do not put up any money to start the hand. Because the button rotates around the table, each player will eventually act as the big blind, small blind and dealer. It will cost you three dollars every time the deal makes a complete rotation around the table.
The Opening
After the blinds are posted each player is dealt four cards face down with the player on the small blind receiving the first card and the player with the dealer button getting the last card. The first betting round begins with the player to the left of the big blind either putting in two dollars to "Call" the blind bet, or putting in four dollars to "raise" the big blind or folding his hand. The betting goes around the table in order until it reaches the player who posted the small blind. That player can call the bet by putting in one dollar since a dollar bet was already posted. The last person to act is the big blind. If no one has raised, the dealer will ask if they would like the option. This means the big blind has the option to raise or just "check."
The Flop
e cards are dealt and turned face up in the middle of the table. This is known as the "Flop." These are community cards used by all the players. Another betting round begins with the first active player to the left of the dealer button. The minimum bet for this round is also three dollars.
The Turn
When the betting round after the flop is completed, the dealer burns another card and turns a fourth card face up in the middle of the table. This is referred to as the "Turn." The minimum bet after the turn is now six dollars and begins again with the first active player to the left of the button.
The River
Following the betting round for the turn, the dealer will burn another card and turn a fifth and final card face up. This is called the "river," and the final betting round begins with six dollars being the minimum bet. There is usually a three or four raise maximum during all betting rounds except if the play becomes heads up with two players. Then the raises are unlimited.
The Showdown
To determine the winner, the players MUST use two of his hole cards and three cards from the "Board" to form the highest five-card hand. In some cases two players will tie which happens quite often in Omaha Hi/Lo. In that case the players will split the pot. A sixth card is never used to break a tie.
Jun 30, 2011 | Carrom Game Board Large
Hunter Douglas Powerrise blinds don't go up and down smoothly
Hello: First of all how old are the shades? Duette/Silhouette? Try raising the shade and then removing the batteries for 10 sec and holding down the manual button for that 10 seconds, then run the shade thru a cycle. Feel free to call I can help you.
Sincerely,
Christy Campbell
Hunter Douglas
CIC Technical Consumer Support Specialist
1-888-602-8059 ext. 3548
May 13, 2010 | Kitchen Appliances - Others
I have the same problem...Ever figure out how to fix it?
Mar 22, 2010 | Kitchen Appliances - Others
Cant figure out how to set the time
1> Press and hold the select button. The setup display appears. 2> Press the select button repeatedly until "CLOCK-ADJ" appears. 3> Press (DSPL). The hour indication flashes. 4> Rotate the volume control dial to set the hour and minute. To move the digital indication, pres (DSPL). 5> Press the select button. The setup is complete and the clock starts. To display the clock, press (DSPL). Press (DSPL) again to return to previous display. The clock uses a 12-hour digital indication.
Jun 15, 2009 | Sony CDX-GT300 CD Player
92 GMC Sonoma, How to change the time on radio clock?
If it's the original radio, you have to hold the "set" button and press some of the other buttons to change the hour and minutes. Sorry, can't remember which ones exactly but the "set" button for sure.
Mar 05, 2009 | 1992 GMC Sonoma
The clock
you need to press and hold the select button button till it goes to demo, then press the next track button. then the hour will flash (use the volume to change the hour) then press the next button again it will go to the minute (use the volume to change the minute) once done that just press select again and the clock will be set!
Jul 16, 2008 | JVC AM FM CD DET FACE CAR STEREO
Can't scan or copy...looks all fuzzy
When you say fuzzy, do you mean that you are getting cast or moire? try this and keep me updated on the result
If you are seeing a grey cast to all stand alone copies made with the CX7800 please try the following:
1. Select the SETUP UTILITIES button on the CX7800
2. Press the RIGHT arrow (photo options) button until you have an option for copy quality then press the START button.
3. Use the UP or DOWN arrow (copies) buttons to select the desired copy quality you want then press the START button again.
Now press the copy button and select the START button. Pls rate as fixya if it resolve it, and if you need anything else pls inform me. Thanks!!
Jun 12, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Deleting the voice recording
Press and hold the MENU button to move to menu and select [Settings] → [System].
1 Use - or + to move to the file you want to delete and press the NAVI button.
2 Move to [Yes] and press the NAVI button.
● The selected file is deleted.
Feb 07, 2008 | Samsung YP-T8 Digital Media Player
Picture problem
If you're having like a bright picture with venetian blinds, you could try the steps below:
POWER RESET:
- Turn off camera
- Remove batteries for a minute
- Return batteries
- Turn on camera
MASTER RESET
- Turn on camera
- Press MENU button
- Scroll to the right until you see SETUP
- Scroll down and look for RESET
- Press right button so you could see YES or NO
- Select YES
- Press MENU button
- Turn off camera for a few seconds so that
settings will be refreshed
* If it still does not work, call the Manufacturer so they
could tell you how to send camera for repair.
Dec 13, 2007 | Samsung Digimax S500 Digital Camera
Nintendo DS Lite Console Logo
24 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
