Question about Samsung LN-S3251D 32 in. LCD HDTV
Sound Disappeared for Samsung LCD - Unit is only 8months Old
Hello
I was watching earlier today when I decided to turn the unit off for a minute. When I came back the sound disappeared. I checked the internal mute and the volume for each channel but I still couldn't determine what the problem was. I decided to turn it off for a few hours (around 2hrs) when I tried the TV again the sound was back. Unfortunately when I turned it off and on again the sound disappeared. I tried using my old ps2 to check the sound and I couldnt get any out of it. What could be the problem? Thanks for your help.
  • kenrod_ps Oct 15, 2008
    Thanks for your help eletech1. Whats crappy about this is Ive read a lot of horror stories about the samsung service centers here in Manila taking 2 - 4weeks to fix the problem and charging extra for whatever parts theyve replaced. I hope I get this fixed. Do you think the hdmi cable has something to do with this problem? What could have caused this?
  • Anonymous Dec 14, 2008
    When turning off the television, I hit a wrong button on the remote. Now the sound is not working at all. I have tried everything I can think of. It does still make the bleeping sound when turned off and on. Any suggestions?
  • 899 Answers
This would be the pre amp. transistor , audio second pre amp volume control chip or audio amplifier , they will need to be tested to determine which one or ones should be replaced
Posted on Oct 15, 2008
Have flat panel hdtv monitor 1080i samsung no picture or sound
Tv has no picture or sound; will go out while watching. The picture will go into a line and sound and picture will go out; shortly after that tv will turn off. Did this last nite and I did not turn back on until this morning, it worked no problem. On for couple of hours and now it's out again. What could be problem and how do I fix myself
Feb 27, 2010 | Televison & Video
I have a samsung 15 inch LCD TV. When I turn the
kcs36dd, Lcd TV's also have, just like LCD monitors, an AC to DC voltage power supply. It is called a "switch-mode-power-supply" and generates the DC voltages required for all the other important electronic circuits inside the unit. 98% of all 14" to 22' lcd panels have backlighting provided by "cold-cathode-fluorescent-lamps" (CCFL) that produce WHITE LIGHT so you can see all the pretty colors that the glass LCD PANEL produces on the screen. The INVERTER circuit requires 12vdc to 20vdc from the SMPS to convert into 500 to 1000v ac to light-up the CCFL's. IF the SMPS detects a FAULT CONDITION with itself or the INVERTER it will go into what is known as FULL or PARTIAL SHUTDOWN MODE to try and save itself from a catastrophic, nonrecoverable failure. e.g. sparks, smoke, fire. lmistyrel on aim.com I could give you more assistance if you had provided following informatiom.
1. How old is the unit? 2, Approximate total "ON" hours unit has? 3.Has unit failed within the WARRANTY period? 4. Will SAMSUNG do a cash+old unit swapout because of PREMATURE FAILURE? 4. Do you know enough to do a unit TEARDOWN and inspection to possibly determine ROOT CAUSE of SMPS/INVERTER failure? 5. Can you handle a soldering iron and solder to make DIY repairs to unit. 6. Since your unit is just a little more complex than a LCD MONITOR, have toy viewed on YOUTUBE short video clips of "LCD monitor disassembly" or "LCD monitor repair" for the most common cause of BLACK screen complaints? If further assistance is required do additional post to original. 12fixlouie aka louie12fix on fixya
Dec 05, 2009 | Samsung 153b-sliver (Silver) 15 in. Flat...
Samsung LE40B550 - No Picture
I had exactly the same problem with my LE40B550 which I bought in July. I phoned the place I bought it online (eBuyer) and they put me in contact with a Samsung repair centre who fixed it under warranty. It took them 2½ weeks to fix it and get it back to me. The note that came back with the TV said they had replaced the IP board. I think the part number was H40F1 9HS.
The repair centre paid less than £50 for the board (it shows on the returns paperwork).
If you only bought yours in August, and haven't had it fixed yet, I suggest you just get in contact with whoever you bought it from and get it done under warranty.
Oct 18, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Sony receiver DA5ES. Unit start arc and shoot off.
Marko,
I own the same unit (since 2001) & have had no problems. I would get it looked at & see what the issue is & what it would cost to fix. Would it be worthwhile? Well you'd have to ask yourself how much $$ you'd be willing to spend on a replacement vs repairing this unit & based on how much you'd be willing to spend, would the specs on a replacement unit measure up. You'd have to ignore things like HDMI inputs to keep it apples to apples.
I've owned various Sony components for a long time. I only had to get one unit fixed one time (a CD player that my one year old decided to do a chin-up on :( ). The unit was 7 years old at the time and my son is now 12!!. the unit still functions flawlessly since being repaired. Sony builds their stuff to last, even after beiung abused.
Dec 11, 2008 | Sony STR-DA5ES 6.1 Channels Receiver
Sound but, no picture
it could be the main, x or y, or buffer board
Jul 23, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
LG 47" LCD TV - 47LC7DF Clicking Noise
the old saying is that any issues will likely show up in the 1st 3 days if you run it for 72 hrs. if it dosent fail then it will last.
other than going to the show room and seeing if their unit does the same.
they will likely want to send a service guy to check it out and decide for himself.
Feb 25, 2008 | LG 37LC7D 37 in. LCD HDTV
No picture on samsung lcd tv
I have the same problem. I brought a Samsung 46" in July 07 and on Jan 8, 2008, video went blue.
I called Samsung and sent out technician and they replaced the motherboard.
Two hours later, same problem occured. I called today and Electronic Company thinks I have a bad LCD panel.
Jan 19, 2008 | Samsung LN-R328W 32 in. HD-Ready LCD...
Samsung LN-S3251D 32 in. LCD HDTV Logo
181 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
